    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.4k Views 76 Watching
      dylan
      Thanks TIG, this is a big script and works so well 👍
      http://dmdarchitecture.co.uk/
      • CadFatherC Offline
        CadFather
        gotcha!.. 😒 😆
        ..the script does lead you into 'lofty' considerations..
        • mitcorbM Offline
          mitcorb
          TIG:
          Did you notice the plugin will displace the resulting group a distance away from the originating groups? I don't know if this is a random distance or a proportional distance, or if it is dependent on the geometry of the originating elements. This is just an observation, and not necessarily a problem.
          mitcorb
            @mitcorb said:
            TIG:
            mitcorb
            The result sometimes displaces... It's to do with the translations of the two groups, I haven't yet worked out how to ensure it always snaps over the original - the displacement is the bounds of the new group v. the originals...
              majid
              Thanks for the ideas...
              Peace, hello: I am happy that the website is active ?
              My Farsi is not so good...
                Ben Ritter
                TIG,
                Very grateful for your talent, and for sharing.
                Thank you.
                • majidM Offline
                  majid
                  thanx dear TIG .. it is great. maybe the next step is adding options so that it could do something like Follow me ,+ FollowMe&Keep, but whit a noncouplanar profile (like your scrip is doing)... again :it is great TIG 👍
                  تیگ عزیز،ممنون از سخاوت تو
                  • plot-parisP Offline
                    plot-paris
                    wow, really a nice plugin! thanks a lot, TIG! jumps out of his seat
                    (and thanks Gaieus, for pointing me here...)
                    that is quite a useful tool.
                    next step: birial operation? (two different path-curves and/or several different base-curves...) 😉
                    • mitcorbM Offline
                      mitcorb
                      As Plot-paris said: "next step: birail operation? (two different path-curves and/or several different base-curves...) 😉 and then morph along rails to preset sectional outlines, and who knows what else?
                      I am currently enjoying some experimentation with this plugin-- craggy curtains, canyon walls, insect "skins"....
                      Thank you TIG
                      mitcorb
                      • olisheaO Offline
                        olishea
                        does it work well for mac?
                        oli
                          dylan
                          Works perfectly on the Mac Oli 😎
                            putnik
                            Thank you TIG!
                            http://keshas.info
                            • olisheaO Offline
                              olishea
                              amazing plugin, works really smooth too. gonna have some fun with this! 😆
                              oli
                                Version 1.1 20090625
                                Speed improvements - face making time ~halved,
                                typename >> kind_of?, triangulation glitch trapped
                                and orientation improved.
                                It's here http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                                Another example...
                                  The funny of your plug 😉
                                  (Click the image)
                                  • MALAISEM Offline
                                    MALAISE
                                    Great TIG, thanks a lot for this SU enhancement.
                                    MALAISE
                                    • JClementsJ Offline
                                      JClements
                                      Congratulations TIG!
                                      A very useful and well executed script.
                                      Questions/Suggestions:
                                      1- I assume the order in which the two groups were assigned determines the alignment of the mesh; to the last defined of the two selected groups.
                                      2- Not critical, but could there be a Smoothing Dialog that prompts: "a)Smooth or b)Smooth and Soften"?
                                      3- A defaults dialog triggered by pressing the [Tab] key? You'd would then be able to assign defaults of a Yes or No for each prompt and which which dialogs would be shown (if shown, then user could temporarily change their default as the script is playing).
                                        Here's an update...
                                        Version 1.2 20090625
                                        Orientation speed optimised.
                                        Glitch on groups erase fixed.
                                        Get it here... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                                        • I Offline
                                          ideas_arte
                                          Wow...!
                                          Many thank you very much ...!
                                          Excellent tool, thank you very much again and a hug from Central America ...! 😄
                                          • massimoM Offline
                                            massimo Moderator
                                            Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
                                            • 9 / 10
