    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 238.2k Views 76 Watching
    • free agentF Offline
      free agent
      @cadfather said:
      Hi TIG, Thank you for the gem..
      could be me doing something wrong.. i noticed that if i draw a circle on any plane (as path) and an edge in elevation (profile), the script always considers the circle the path
      thats because the the script doesnt rotate the profile along the path so it apears as if the circle is being extruded, to which TIG will reply: if you want that function use Follow Me or Follow me and Keep.
      Tig: it seems people would really really like that function 😄 👍
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
        And if you want multiple curves along a path use "Simple-Loft" by Chris Fullmer 😉
        The extrudeEdgesbyEgdes is for particular uses as sections are always parallel!
          dylan
          Thanks TIG, this is a big script and works so well 👍
          http://dmdarchitecture.co.uk/
          • CadFatherC Offline
            CadFather
            gotcha!.. 😒 😆
            ..the script does lead you into 'lofty' considerations..
            • mitcorbM Offline
              mitcorb
              TIG:
              Did you notice the plugin will displace the resulting group a distance away from the originating groups? I don't know if this is a random distance or a proportional distance, or if it is dependent on the geometry of the originating elements. This is just an observation, and not necessarily a problem.
              mitcorb
                @mitcorb said:
                TIG:
                mitcorb
                The result sometimes displaces... It's to do with the translations of the two groups, I haven't yet worked out how to ensure it always snaps over the original - the displacement is the bounds of the new group v. the originals...
                  majid
                  Thanks for the ideas...
                  Peace, hello: I am happy that the website is active ?
                  My Farsi is not so good...
                    Ben Ritter
                    TIG,
                    Very grateful for your talent, and for sharing.
                    Thank you.
                    • majidM Offline
                      majid
                      thanx dear TIG .. it is great. maybe the next step is adding options so that it could do something like Follow me ,+ FollowMe&Keep, but whit a noncouplanar profile (like your scrip is doing)... again :it is great TIG 👍
                      تیگ عزیز،ممنون از سخاوت تو
                      • plot-parisP Offline
                        plot-paris
                        wow, really a nice plugin! thanks a lot, TIG! jumps out of his seat
                        (and thanks Gaieus, for pointing me here...)
                        that is quite a useful tool.
                        next step: birial operation? (two different path-curves and/or several different base-curves...) 😉
                        • mitcorbM Offline
                          mitcorb
                          As Plot-paris said: "next step: birail operation? (two different path-curves and/or several different base-curves...) 😉 and then morph along rails to preset sectional outlines, and who knows what else?
                          I am currently enjoying some experimentation with this plugin-- craggy curtains, canyon walls, insect "skins"....
                          Thank you TIG
                          mitcorb
                          • olisheaO Offline
                            olishea
                            does it work well for mac?
                            oli
                              dylan
                              Works perfectly on the Mac Oli 😎
                                putnik
                                Thank you TIG!
                                http://keshas.info
                                • olisheaO Offline
                                  olishea
                                  amazing plugin, works really smooth too. gonna have some fun with this! 😆
                                  oli
                                    Version 1.1 20090625
                                    Speed improvements - face making time ~halved,
                                    typename >> kind_of?, triangulation glitch trapped
                                    and orientation improved.
                                    It's here http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                                    Another example...
                                      The funny of your plug 😉
                                      (Click the image)
                                      • MALAISEM Offline
                                        MALAISE
                                        Great TIG, thanks a lot for this SU enhancement.
                                        MALAISE
                                        • JClementsJ Offline
                                          JClements
                                          Congratulations TIG!
                                          A very useful and well executed script.
                                          Questions/Suggestions:
                                          1- I assume the order in which the two groups were assigned determines the alignment of the mesh; to the last defined of the two selected groups.
                                          2- Not critical, but could there be a Smoothing Dialog that prompts: "a)Smooth or b)Smooth and Soften"?
                                          3- A defaults dialog triggered by pressing the [Tab] key? You'd would then be able to assign defaults of a Yes or No for each prompt and which which dialogs would be shown (if shown, then user could temporarily change their default as the script is playing).
                                            Here's an update...
                                            Version 1.2 20090625
                                            Orientation speed optimised.
                                            Glitch on groups erase fixed.
                                            Get it here... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                                            • 2 / 10
