    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 238.2k Views 76 Watching
      Ben Ritter
      TIG,
      Very grateful for your talent, and for sharing.
      Thank you.
      • majidM Offline
        majid
        thanx dear TIG .. it is great. maybe the next step is adding options so that it could do something like Follow me ,+ FollowMe&Keep, but whit a noncouplanar profile (like your scrip is doing)... again :it is great TIG 👍
        تیگ عزیز،ممنون از سخاوت تو
        • plot-parisP Offline
          plot-paris
          wow, really a nice plugin! thanks a lot, TIG! jumps out of his seat
          (and thanks Gaieus, for pointing me here...)
          that is quite a useful tool.
          next step: birial operation? (two different path-curves and/or several different base-curves...) 😉
          • mitcorbM Offline
            mitcorb
            As Plot-paris said: "next step: birail operation? (two different path-curves and/or several different base-curves...) 😉 and then morph along rails to preset sectional outlines, and who knows what else?
            I am currently enjoying some experimentation with this plugin-- craggy curtains, canyon walls, insect "skins"....
            Thank you TIG
            mitcorb
            • olisheaO Offline
              olishea
              does it work well for mac?
              oli
                dylan
                Works perfectly on the Mac Oli 😎
                http://dmdarchitecture.co.uk/
                  putnik
                  Thank you TIG!
                  http://keshas.info
                  • olisheaO Offline
                    olishea
                    amazing plugin, works really smooth too. gonna have some fun with this! 😆
                    oli
                      Version 1.1 20090625
                      Speed improvements - face making time ~halved,
                      typename >> kind_of?, triangulation glitch trapped
                      and orientation improved.
                      It's here http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                      Another example...
                        The funny of your plug 😉
                        (Click the image)
                        • MALAISEM Offline
                          MALAISE
                          Great TIG, thanks a lot for this SU enhancement.
                          MALAISE
                          • JClementsJ Offline
                            JClements
                            Congratulations TIG!
                            A very useful and well executed script.
                            Questions/Suggestions:
                            1- I assume the order in which the two groups were assigned determines the alignment of the mesh; to the last defined of the two selected groups.
                            2- Not critical, but could there be a Smoothing Dialog that prompts: "a)Smooth or b)Smooth and Soften"?
                            3- A defaults dialog triggered by pressing the [Tab] key? You'd would then be able to assign defaults of a Yes or No for each prompt and which which dialogs would be shown (if shown, then user could temporarily change their default as the script is playing).
                              Here's an update...
                              Version 1.2 20090625
                              Orientation speed optimised.
                              Glitch on groups erase fixed.
                              Get it here... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                              • I Offline
                                ideas_arte
                                Wow...!
                                Many thank you very much ...!
                                Excellent tool, thank you very much again and a hug from Central America ...! 😄
                                • massimoM Offline
                                  massimo Moderator
                                  Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
                                    Massimo
                                    Have you tried the latest version v1.2 ? I've just tried to reproduce your path/profile and I get all faces made - no gaps - Any edge that can get a face should get a face ? Your faces aren't reversed are they, so look 'gappped' ?
                                    The only problem I have was because of the convoluted result some faces orient wrongly [inside out] - both in the script AND within SUp later - the only fix is to reverse the problem faces manually ...
                                    I had to guess your model's details - I could test it better with the real thing - if after trying with the latest version it still gaps please PM me with the model attached, so I can see if I get the same problem...
                                      Can you subsequently get the face made if you redraw an edge ? If so then EEbyE should have made that face...
                                      I haven't managed to reproduce it, can one of you PM me a [small] model with the problem ?
                                        I have same result but seems normal as this function is not adapted to this!
                                        As the profil stay parallel 😒
                                        At each "rotation" there are creation of an external or internal horizontal face 😄
                                        For ovoid that make just an half circle 😉
                                        And a mirror after 😉
                                        But even with this there some gaps 😉
                                          file of the mirror above 😉
                                          gap.skp
                                            I get no loose edges with either of your skp's... There is orientation weirdness as sometimes threes faces share as edge as it's convoluted in on itself when a circle... to be on the safe side I am adjusting the script to trap any edges without faces... Look out for update...
                                            • 3 / 10
