    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 440.3k Views 153 Watching
      johnsenior1973
      Downloaded it again and installed it. It's working for me now.
        REGIS
        downloaded and installed in google sketchup 7 plugins folder.
        Doesn't work
        cheers
          REGIS
          It works fine now.
          Thanks a lot.
          cheers
          • ToboboT Offline
            Tobobo
            Chris,
            I can't get it to work.
            I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
            I've posted the model so you can have a look and tell what i'm doing wrong.
            Thanks in advance.
            Netting.skp
            Toby
            Philippians 4:13
              REGIS
              Hi Tobobo
              It's due to the hidden geometry.
              Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
              Just create the group and choose your FFD setting.
              curtain.skp
              cheers
              Edit
              After some FFD
              curtainFFDv6.skp
              cheers
              • ToboboT Offline
                Tobobo
                Thanks REGIS
                I'll have to think of another way to deform the netting.
                Toby
                Philippians 4:13
                  REGIS
                  Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
                  Cheers
                    SKELL
                    I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                    Thanks,
                    -Tony
                      One possibility
                      Draw a rectangle
                      Pull it with Ctrl any time you want
                      Select all (triple click)
                      Move it one time + CTRL = Copy
                      Type "10*" (or more) = Multiple
                      Group it
                      Select group Right Click / FFD
                      Edit the goup "FFD"
                      Move points
                      Et voilà 😉
                      rec.skp
                        michaelland
                        Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                        Michael Xie
                          BTM
                          Thanks,
                          -Tony
                          There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                            Yes but will be any effect on the subdivide of a simple rectangle!!!
                            Nothing will arrive when you will move a point of the FFD!
                            Seems the only easy methode is draw a rectangle with the Sandbox 😄
                              jonorman
                              Hi..
                              I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
                              can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
                                GJV
                                woooaaaa
                                amazing plugin
                                just what I needed
                                thanx a lot 😄 !!!!
                                  Dee256
                                  Works nice! But "transformations reset" needs sometimes before FFD starts.
                                  • I Offline
                                    ideas_arte
                                    .. thanks a million!
                                    really useful too 👍
                                    • N Offline
                                      niarfe
                                      this looks like a wonderful ruby!!!
                                      too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart!
                                      would have loved to use it 😞
                                      • Chris FullmerC Offline
                                        Its not over yet. If its not working, then its installed wrong or your using it wrong. Or you have version 4 of SU 😄
                                        Could you provide a better description of what its doing wrong? Perhaps screenshots, maybe a video. Just give us some more detail and we'll get it working for you.
                                          sprezzaturon
                                          I'm running Sketchup 7 and just added your FFD tool. I can move points but there is no 'update FFD' option when I'm finished. Is FFD not compatible with Sketchup 7?
                                            remus
                                            The shape should update automatically, you might have to give it a bit of time, though.
                                            If that doesnt work delete the control points, explode the group, regroup and try again.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 18 / 21
