    [Plugin][$] FredoBend - v1.6a - 21 Oct 26
    79 Posts 15 Posters 17.2k Views 15 Watching
    • Spirou4DS
      Spirou4D
      I did not make it translatable yet
      But made here :
      • Spirou4DS
        Spirou4D
        Top-notch @fredo6 the addon run very well now! Thks a lot and congrats.
        • fredo6F
          fredo6
          There is a new video on FredoBend by TheSketchupEssentials.
          • P
            powerglide
            Awesome plugin! I downloaded both the plugin and library and get this error when trying to bend items.
            Date: 31-Mar-26 16:58:45 - SU2021.0 - LibFredo6 - v15.9a
            An error occurred in FredoBend Along Curve
            Error in Bend Generation
            undefined method `glued_to' for #<Deleted Entity:0x54da1088>
            fredobendcurvealgo.rbe: 199 -- tolid_prepare
            fredobendcurvealgo.rbe: 133 -- tolid_construct_mono
            fredobendcurvetool.rbe: 2402 -- generation_step_replica
            fredobendcurvetool.rbe: 3200 -- job_perform
            fredobendcurvetool.rbe: 3139 -- job_notification
            body_lib6webprogress.rbe: 104 -- call
            body_lib6webprogress.rbe: 104 -- process_notify
            body_lib6webprogress.rbe: 388 -- fast_process_next_step
            body_lib6webprogress.rbe: 358 -- fast_process_start
            body_lib6webprogress.rbe: 370 -- fast_process_next
            body_lib6webprogress.rbe: 397 -- fast_process_end
            body_lib6webprogress.rbe: 383 -- fast_process_next_step
            body_lib6webprogress.rbe: 391 -- fast_process_next_step
            body_lib6webprogress.rbe: 346 -- fast_process_top
            body_lib6webprogress.rbe: 123 -- invoke
            fredobendcurvetool.rbe: 3085 -- job_start
            fredobendcurvetool.rbe: 2341 -- block in generation_launch
            • fredo6F
              fredo6
              Would you have the model, because I don't understand how the error can happen. Thanks
              • fredo6F
                fredo6
                NEW RELEASE: FredoBend v1.2g - 01 Apr 26
                Requirements
                • LibFredo6: v15.9a or above
                FredoBend 1.2g is a maintenance release including:
                • Bug fixing for SU versions prior to SU2021.1
                Home Page of FredoBend for information and Download.
                Main post of this FredoBend thread.
                P 1 Reply Last reply
                • P
                  powerglide @fredo6
                  @fredo6 Just checked it out, It works now! I am soo happy to have an extension like this for my line of work. Thanks for all of your hard work and dedication!!
                  • fredo6F
                    fredo6
                    NEW RELEASE: FredoBend v1.2k - 09 Apr 26
                    Requirements
                    FredoBend 1.2k is a maintenance release including:
                    • Bug fixing related to replicas
                    • fredo6F
                      fredo6
                      NEW RELEASE: FredoBend v1.2l - 10 Apr 26
                      Requirements
                      FredoBend 1.2l is a maintenance release including:
                      • Major bug fixing related to directions
                      • fredo6F
                        fredo6
                        NEW RELEASE: FredoBend v1.3a - 01 May 26
                        Requirements
                        FredoBend 1.3a is a major release including:
                        • Introduction of the Circular Bend tool
                        • Adjustment of the bending algorithms
                        • Bug fixing
                        • Other evolutions
                        Circular Bend: Overview
                        1 Reply Last reply πŸ‘ πŸ‘
                        Reply Quote 2
                        • fredo6F
                          fredo6
                          NEW RELEASE: FredoBend v1.3b - 04 May 26
                          Requirements
                          FredoBend 1.3b is a maintenance release including:
                          • Bug fixing for Circular Bend tool
                          • C
                            Chris1219 Newcomers
                            Hello!!
                            I am a user from Greece. Thanks for this amazing plugin.
                            Nevertheless I noticed that Circular bending deforms a little bit the object which I think is not convenient for the accuracy I don't know, is this a bad handle by me or is a small bug in the code? (I attach a screenshot trying to show what I mean).
                            Thanks for your attention in advance!!
                            fredo6F 1 Reply Last reply
                            • fredo6F
                              fredo6 @Chris1219
                              @Chris1219
                              This is a choice you have to make.
                              There is a thread on this question in the Sketchup forum.
                              In your case, you can play with this parameter (Offset Mode)
                              C 1 Reply Last reply
                              • C
                                Chris1219 Newcomers @fredo6
                                @fredo6 Hello!!
                                Thank you very much for the instructions. I choose Vertex-to-Vertex end everything is fine. Now I Know that I have two options to use.
                                I saw the topic in the forum and I somehow understood the mechanism of bending, and the difficulties that appears.
                                Thanks again!
                                • TIGT
                                  @fredo6
                                  I think it's best for a bent object's geometry to follow a 'curve' and start perpendicular to the start/end segment. But if the path is a full circle the bending should start perpendicular to a mid-segment, to keep the objects 'endmost' dimensions correct: and if it's around an arc [partial circle] that's user-defined it should be treated like any other curve: but if it's a swept form around a notional partial-circular path, that should then start/end perpendicular to a half-segment - that way the bent form stays as dimensionally true as it can be.
                                  • fredo6F
                                    fredo6
                                    NEW RELEASE: FredoBend v1.4a - 20 Jun 26
                                    Requirements
                                    FredoBend 1.4a is a maintenance release including:
                                    • Bug fixing
                                    • Technical adjustments
                                    • functional adjustments
                                    Note that applying the Circular Bend tool to a component will impact all other instances. So, if this is not intended, please make sure you make the component instance unique before.
                                    • fredo6F
                                      fredo6
                                      NEW RELEASE: FredoBend v1.5a - 30 Jun 26
                                      Requirements
                                      FredoBend 1.5a is a major release including:
                                      • Introduction of the Dome tool
                                      • Bug fixing
                                      Note that applying the Circular and Dome Bend tool to a component will impact all other instances. So, if this is not intended, please make sure you make the component instance unique before.
                                        @fredo6 Dome works great. Do you plan to add support to maintain UVs?
                                        • fredo6F
                                          fredo6 @Rich O Brien
                                          @Rich-O-Brien said:
                                          @fredo6 Do you plan to add support to maintain UVs?
                                          Maybe, although I am not entirely sure there is a technical solution. What is sure is that it is not trivial and there will be an impact to performance.
                                          • fredo6F
                                            fredo6
                                            I really need to investigate deeper what is going on.
                                            The generation is done by deformation, that is, without creating geometry, just moving vertices.
                                            In the meantime, there is ThruPaint to correct the issues.
                                            FredoBend and UVs.mp4
                                            • 3 / 4
