[Plugin] FredoBend - v1.5a - 30 Jun 26
NEW RELEASE: FredoBend v1.2g - 01 Apr 26
Requirements
- LibFredo6: v15.9a or above
- Sketchup version: SU2017 and above
FredoBend 1.2g is a maintenance release including:
- Bug fixing for SU versions prior to SU2021.1
Home Page of FredoBend for information and Download.
@fredo6 Just checked it out, It works now! I am soo happy to have an extension like this for my line of work. Thanks for all of your hard work and dedication!!
NEW RELEASE: FredoBend v1.2k - 09 Apr 26
Requirements
FredoBend 1.2k is a maintenance release including:
- Bug fixing related to replicas
NEW RELEASE: FredoBend v1.2l - 10 Apr 26
Requirements
FredoBend 1.2l is a maintenance release including:
- Major bug fixing related to directions
NEW RELEASE: FredoBend v1.3a - 01 May 26
Requirements
FredoBend 1.3a is a major release including:
- Introduction of the Circular Bend tool
- Adjustment of the bending algorithms
- Bug fixing
- Other evolutions
Circular Bend: Overview
NEW RELEASE: FredoBend v1.3b - 04 May 26
Requirements
FredoBend 1.3b is a maintenance release including:
- Bug fixing for Circular Bend tool
Hello!!
I am a user from Greece. Thanks for this amazing plugin.
Nevertheless I noticed that Circular bending deforms a little bit the object which I think is not convenient for the accuracy I don't know, is this a bad handle by me or is a small bug in the code? (I attach a screenshot trying to show what I mean).
Thanks for your attention in advance!! -
This is a choice you have to make.
There is a thread on this question in the Sketchup forum.
In your case, you can play with this parameter (Offset Mode)
@fredo6 Hello!!
Thank you very much for the instructions. I choose Vertex-to-Vertex end everything is fine. Now I Know that I have two options to use.
I saw the topic in the forum and I somehow understood the mechanism of bending, and the difficulties that appears.
Thanks again! -
@fredo6
I think it's best for a bent object's geometry to follow a 'curve' and start perpendicular to the start/end segment. But if the path is a full circle the bending should start perpendicular to a mid-segment, to keep the objects 'endmost' dimensions correct: and if it's around an arc [partial circle] that's user-defined it should be treated like any other curve: but if it's a swept form around a notional partial-circular path, that should then start/end perpendicular to a half-segment - that way the bent form stays as dimensionally true as it can be. -
NEW RELEASE: FredoBend v1.4a - 20 Jun 26
Requirements
FredoBend 1.4a is a maintenance release including:
- Bug fixing
- Technical adjustments
- functional adjustments
Note that applying the Circular Bend tool to a component will impact all other instances. So, if this is not intended, please make sure you make the component instance unique before.
NEW RELEASE: FredoBend v1.5a - 30 Jun 26
Requirements
FredoBend 1.5a is a major release including:
- Introduction of the Dome tool
- Bug fixing
Note that applying the Circular and Dome Bend tool to a component will impact all other instances. So, if this is not intended, please make sure you make the component instance unique before.
@fredo6 Dome works great. Do you plan to add support to maintain UVs?
@fredo6 Do you plan to add support to maintain UVs?
Maybe, although I am not entirely sure there is a technical solution. What is sure is that it is not trivial and there will be an impact to performance.
I really need to investigate deeper what is going on.
The generation is done by deformation, that is, without creating geometry, just moving vertices.
In the meantime, there is ThruPaint to correct the issues.
Hi. Would editing radius be a possibility as well as angle ??
@fredo6 Yes, it would be nice to either give angle value, or radius. Maybe following: If you change angel in the angle value, the radius automaticly update, and if you then if you change the radius value the angle value would update.. If that is possible. If this make sense
Yes, indeed. Rdaius and angle are related. My question is whether you know in your model what value of radius you would enter?
