    Joint Push Pull will not work. Uninstalled and reinstalled.
    extensions
    13 Posts 9 Posters 4.0k Views 9 Watching
      ltrain5000
      I Can not get Fredo Joint push pull to work. I have uninstalled the extensions, the LibFredo tools, reinstalled the the extensions and then when that didn't work, I uninstalled SU 2019 and installed SU 2020 and reinstalled all new extensions.. It still wont work. When I click any of the options to use any of the push pull tools, nothing happens.
      I have the following Fredo tools extensions installted.
      fredoTools_v4.2e.rbz
      Libfredo6_v12.4a.rbz
      Jointpushpull_v4,4e.rbz
      Curviloft_v1.8a.rbz
      RoundCorner_v3.3a.rbz
      TopoShaper_v2.6a.rbz
      None of the Fredo Extensions are working on this computer. Anyone know what the problem could be? TIA.
      windows 10, SU 2020 Pro
        You might have a permissions issue...
        First close SketchUp and [re]run its installer's exe file [usually in your Downloads].
        Right-click on that exe and choose 'Run as administrator'...
        When prompted choose 'Repair'.
        Now SketchUp's permissions will be set right.
        If permissions were wrong the first time you ran one of Fredo's tools then its preferences right be corrupted or otherwise unobtainable.
        To fix this find the following folder and delete it [along with all of its files and subfolders].
        C:\Users\**YOURUSERNAME**\AppData\Local\LIBFREDO6_DATA_Dir
        It's hidden by default, but it can be found...
        When SketchUp next runs and you use one of Fredo's tools everything should now be recreated with good permissions.
          archzag
          I followed TIG's suggestions but unfortunately Joinnt PP still doesn't work. So too Fredo Scale.
            Can you share more details?
            Error messages, Ruby Console output, SketchUp version if different than your profile....
            • BoxB Offline
              Ignoring the original post and Tigs reply, it is a few months since the OP posted and at some point after that Fredo's JPP became a commercial plugin, so have you bought a license?
              • W Offline
                wentihidayah
                install LibFredo6 v13.4a, It will work.
                • F Offline
                  fjrrswnd04 Newcomers
                  "script JoinPushPull is loaded but menus will show up only at next startup of sketchup"
                  please anyone help me, why my plugin like this. i've uninstall and reinstall, but still cant use
                  • fredo6F Offline
                    fredo6
                    Did you upgrade to LibFredo6 v13.6a?
                      archiprosody7908
                      Mine says "Incorrect installation of LibFredo6 - Remove rb files" β€” but I don't know which files.
                      I also am having a problem with JPP Interactive; the toolbar is there but it doesn't function. I select a surface, click the icons, and nothing happens.
                      I am running LibFredo6v13.9a, SketchUp Pro 2021. I even purchased a set of licenses on Dec. 20, 2022 and have installed and activated them correctly.
                        Go to...
                        https://i.imgur.com/vqnZvrX.png
                        Paste your text output here
                          archiprosody7908
                          Go to...
                          Fredo6 Plugins Information on 2023-02-27 16:09:59 -0500
                          • Platform: x64-mswin64_140 - Ruby: 2.7.2
                          • Sketchup: 21.1.332
                          • LibFredo6: v13.9a
                          • LibFredo6 Binary loaded
                          • Sketchucation ExtensionStore: 4.3.0
                          • SCFLicense: v6.0e - 72
                          • Fredo6 Plugins
                            LordOfTheToolbars v1.3e
                            Curviloft v1.9a - licensed FULL
                            Curvizard v2.4b - licensed FULL
                            FredoCorner v2.5a
                            FredoScale v3.5a - licensed FULL
                            FredoTools v4.3a
                            HoverSelect v1.5a
                            JointPushPull v4.6a - licensed FULL
                            RoundCorner v3.3a - licensed FULL
                            ToolsOnSurface v2.5a - licensed FULL
                            TopoShaper v2.6a - licensed FULL
                            VisuHole v1.4b - licensed FULL
                          • SCFLicense directory present
                            Signature File: 2022-12-20 12:23:27 -0500
                            Curviloft: 2023-02-24 11:15:45 -0500
                            Curvizard: 2023-02-24 11:15:27 -0500
                            FredoScale: 2023-02-27 14:11:43 -0500
                            JointPushPull: 2023-02-24 11:11:33 -0500
                            RoundCorner: 2023-02-24 11:16:16 -0500
                            ToolsOnSurface: 2023-02-24 11:14:28 -0500
                            TopoShaper: 2023-02-24 11:15:59 -0500
                            VisuHole: 2023-02-24 11:14:54 -0500
                          • fredo6F Offline
                            fredo6
                            You seems to have a corrupted installation of LibFredo6. Go to the plugin directory, remove the folder Fredo6_!LibFredo6 and then reinstall LibFredo6.
                              archiprosody7908
                              That appears to have solved it, thank you very much!
