    Joint Push Pull will not work. Uninstalled and reinstalled.
    extensions
    13 Posts 9 Posters 5.0k Views 9 Watching
      You might have a permissions issue...
      First close SketchUp and [re]run its installer's exe file [usually in your Downloads].
      Right-click on that exe and choose 'Run as administrator'...
      When prompted choose 'Repair'.
      Now SketchUp's permissions will be set right.
      If permissions were wrong the first time you ran one of Fredo's tools then its preferences right be corrupted or otherwise unobtainable.
      To fix this find the following folder and delete it [along with all of its files and subfolders].
      C:\Users\**YOURUSERNAME**\AppData\Local\LIBFREDO6_DATA_Dir
      It's hidden by default, but it can be found...
      When SketchUp next runs and you use one of Fredo's tools everything should now be recreated with good permissions.
        archzag
        I followed TIG's suggestions but unfortunately Joinnt PP still doesn't work. So too Fredo Scale.
          Can you share more details?
          Error messages, Ruby Console output, SketchUp version if different than your profile....
          • BoxB
            Ignoring the original post and Tigs reply, it is a few months since the OP posted and at some point after that Fredo's JPP became a commercial plugin, so have you bought a license?
            • W
              wentihidayah
              install LibFredo6 v13.4a, It will work.
              • F
                fjrrswnd04 Newcomers
                "script JoinPushPull is loaded but menus will show up only at next startup of sketchup"
                please anyone help me, why my plugin like this. i've uninstall and reinstall, but still cant use
                • fredo6F
                  Did you upgrade to LibFredo6 v13.6a?
                    archiprosody7908
                    Mine says "Incorrect installation of LibFredo6 - Remove rb files" β€” but I don't know which files.
                    I also am having a problem with JPP Interactive; the toolbar is there but it doesn't function. I select a surface, click the icons, and nothing happens.
                    I am running LibFredo6v13.9a, SketchUp Pro 2021. I even purchased a set of licenses on Dec. 20, 2022 and have installed and activated them correctly.
                      Go to...
                      https://i.imgur.com/vqnZvrX.png
                      Paste your text output here
                        archiprosody7908
                        Go to...
                        Fredo6 Plugins Information on 2023-02-27 16:09:59 -0500
                        • Platform: x64-mswin64_140 - Ruby: 2.7.2
                        • Sketchup: 21.1.332
                        • LibFredo6: v13.9a
                        • LibFredo6 Binary loaded
                        • Sketchucation ExtensionStore: 4.3.0
                        • SCFLicense: v6.0e - 72
                        • Fredo6 Plugins
                          LordOfTheToolbars v1.3e
                          Curviloft v1.9a - licensed FULL
                          Curvizard v2.4b - licensed FULL
                          FredoCorner v2.5a
                          FredoScale v3.5a - licensed FULL
                          FredoTools v4.3a
                          HoverSelect v1.5a
                          JointPushPull v4.6a - licensed FULL
                          RoundCorner v3.3a - licensed FULL
                          ToolsOnSurface v2.5a - licensed FULL
                          TopoShaper v2.6a - licensed FULL
                          VisuHole v1.4b - licensed FULL
                          Signature File: 2022-12-20 12:23:27 -0500
                          Curviloft: 2023-02-24 11:15:45 -0500
                          Curvizard: 2023-02-24 11:15:27 -0500
                          FredoScale: 2023-02-27 14:11:43 -0500
                          JointPushPull: 2023-02-24 11:11:33 -0500
                          RoundCorner: 2023-02-24 11:16:16 -0500
                          ToolsOnSurface: 2023-02-24 11:14:28 -0500
                          TopoShaper: 2023-02-24 11:15:59 -0500
                          VisuHole: 2023-02-24 11:14:54 -0500
                        • fredo6F
                          You seems to have a corrupted installation of LibFredo6. Go to the plugin directory, remove the folder Fredo6_!LibFredo6 and then reinstall LibFredo6.
                            archiprosody7908
                            That appears to have solved it, thank you very much!
