    Joint Push Pull will not work. Uninstalled and reinstalled.
    extensions
    13 Posts 9 Posters 5.0k Views 9 Watching
      @archzag said:
      I followed TIG's suggestions but unfortunately Joinnt PP still doesn't work. So too Fredo Scale.
      Can you share more details?
      Error messages, Ruby Console output, SketchUp version if different than your profile....
      • BoxB
        Ignoring the original post and Tigs reply, it is a few months since the OP posted and at some point after that Fredo's JPP became a commercial plugin, so have you bought a license?
        • W
          wentihidayah
          install LibFredo6 v13.4a, It will work.
          • F
            fjrrswnd04 Newcomers
            "script JoinPushPull is loaded but menus will show up only at next startup of sketchup"
            please anyone help me, why my plugin like this. i've uninstall and reinstall, but still cant use
            • fredo6F
              Did you upgrade to LibFredo6 v13.6a?
                archiprosody7908
                Mine says "Incorrect installation of LibFredo6 - Remove rb files" β€” but I don't know which files.
                I also am having a problem with JPP Interactive; the toolbar is there but it doesn't function. I select a surface, click the icons, and nothing happens.
                I am running LibFredo6v13.9a, SketchUp Pro 2021. I even purchased a set of licenses on Dec. 20, 2022 and have installed and activated them correctly.
                  Go to...
                  https://i.imgur.com/vqnZvrX.png
                  Paste your text output here
                    archiprosody7908
                    Go to...
                    Fredo6 Plugins Information on 2023-02-27 16:09:59 -0500
                    • Platform: x64-mswin64_140 - Ruby: 2.7.2
                    • Sketchup: 21.1.332
                    • LibFredo6: v13.9a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.3.0
                    • SCFLicense: v6.0e - 72
                    • Fredo6 Plugins
                      LordOfTheToolbars v1.3e
                      Curviloft v1.9a - licensed FULL
                      Curvizard v2.4b - licensed FULL
                      FredoCorner v2.5a
                      FredoScale v3.5a - licensed FULL
                      FredoTools v4.3a
                      HoverSelect v1.5a
                      JointPushPull v4.6a - licensed FULL
                      RoundCorner v3.3a - licensed FULL
                      ToolsOnSurface v2.5a - licensed FULL
                      TopoShaper v2.6a - licensed FULL
                      VisuHole v1.4b - licensed FULL
                      Signature File: 2022-12-20 12:23:27 -0500
                      Curviloft: 2023-02-24 11:15:45 -0500
                      Curvizard: 2023-02-24 11:15:27 -0500
                      FredoScale: 2023-02-27 14:11:43 -0500
                      JointPushPull: 2023-02-24 11:11:33 -0500
                      RoundCorner: 2023-02-24 11:16:16 -0500
                      ToolsOnSurface: 2023-02-24 11:14:28 -0500
                      TopoShaper: 2023-02-24 11:15:59 -0500
                      VisuHole: 2023-02-24 11:14:54 -0500
                    • fredo6F
                      You seems to have a corrupted installation of LibFredo6. Go to the plugin directory, remove the folder Fredo6_!LibFredo6 and then reinstall LibFredo6.
                        archiprosody7908
                        That appears to have solved it, thank you very much!
