    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • ntxdaveN
      ntxdave
      I have been rebuilding my Pendulum animation (preparing for Twilight Render) and I have not seen a problem. I thought I did once but went back and redid my sequence and all worked well for me.
      Press F1...thank me later
        Is there a bug there?
        Yes same than Chris!
        Rotation must be from a point outside the object, but result gives from a point inside the object! ๐Ÿ˜ฎ
        • ntxdaveN
          ntxdave
          OK - I understand. My rotations were from inside the object.
          • fredo6F
            fredo6
            When you pick the pivot, the reference component containing the pivot is highlighted in orange. If you wish a pivot at top of model, then right click and select the option.
            • chriC
              chri
              OK
              Thanks Fredo
              • fredo6F
                fredo6
                In the current version, there is a bug when you capture the Rotation movement, but the transformation is actually created correctly.
                Fredo
                  Better indeed! ๐Ÿ˜„
                  • F
                    Falstaff
                    The camera tracking is not working for me - in particular object selection and playback. I am running on a MAC. Video attached.
                    Camera_test_small.mov
                    • ntxdaveN
                      ntxdave
                      This is my first render with Animator using Twilight Render 2.5.
                      I used the lowest quality settings because of the render time. This one took about 1.5 hours. When I looked at a higher quality setting, the render time was MUCH longer.
                      At least it is a start.
                      • fredo6F
                        fredo6
                        New Release: Animator - v1.0y - 11 Jul 16
                        This is a maintenance release fixing bugs in
                        • Tracking cameras
                        • edition of rotation with orbiting
                        See main post for RBZ files
                        • fredo6F
                          fredo6
                          There seems to be a bug when playing it.
                          Could you please open the Ruby console and see what it is.
                          EDIT: don't bother. I think I fixed it in v1.0y
                          Fredo
                          • F
                            faust07
                            @ntxdave: Did you try the twilight render settings 4) Animation 01. Low+ObjectAnimation or 02. Medium+...? The usually give much smoother and faster animation results. I can't test it because I have only twilight hobby.
                            • ntxdaveN
                              ntxdave
                              I am trying another one now. I am trying the Animation 00 Preview Object Animation. That is going to take around 7hrs. We will see how that goes. When I looked at Easy 01 Low+ it I got the feedback that it would be a LONG time.
                              On the Twilight Render Forum, I go feedback that they are working on some presets that are the settings they used to produce the forklift sample they posted.
                              I am trying to remain optimistic that they/we will find a solution that produces some satisfactory results (both quality & time).
                              I just upgraded my license from Hobby to Pro specifically for this reason so I want to help (if I am capable ๐Ÿ˜‰ ) to find a solution that melds Animator and Twilight Render successfully.
                              • F
                                faust07
                                As a late Beta-tester - I must say: great!
                                Very well thought out. Very comprehensive feature set.
                                Very stable and easy to handle. Detailed Video Tutorials.
                                It is recommended to study the video before or better parallel to the first Animation.
                                And the timeline is the hit - Incredible work has gone into the user interface.
                                So far, only a few small questions and comments:
                                • Positioner: How can I delete or overwrite Positions?
                                • Generation of videos: Is it possible to define start and end position with frame numbers? (In addition to the time indication)
                                • Tracking camera: In my understanding, it seems more like a following camera (the camera moves with the target).
                                • Rendering: Export to Indigo (RT) would be cool...
                                Here a small first example. The formula for the rotation of wheels is a good help especially in curves...
                                AnimatorTest_02.skp
                                  The black YouTube embeds are an issue related to Chrome Browsers.
                                  • fredo6F
                                    fredo6
                                    New Release: Animator - v1.1a - 15 Aug 16
                                    This is a maintenance release fixing bugs with small evolutions
                                    • New Circular method for interpolating cameras, closer to what Sketchup does between Scene (see video below)
                                    • History covers all actions and is common to all films and clips
                                    • fredo6F
                                      fredo6
                                      New Release: Animator - v1.1b - 16 Aug 16
                                      This version 1.1b fixes a major bug affecting Repeat and Pursue options and also address a bug in History.
                                      • fredo6F
                                        fredo6
                                        New Release: Animator - v1.1c - 12 Sep 16
                                        This release introduce the concept of Kinematic Constraints, which basically is a declaration of a kinematic relationship between objects.
                                        It also fixes numerous bug and includes some cosmetic adjustments.
                                        • fredo6F
                                          fredo6
                                          New Release: Animator - v1.1e - 08 Oct 16
                                          This release is candidate to be the first one of the public beta program.
                                          It introduces a new Visual effect, Visual Extents, which forces the camera to frame the whole model or a selection of objects.
                                          It also fixes bugs and includes some cosmetic adjustments.
                                            Cool! ๐Ÿ˜Ž
                                            No animation on a path ?
                                            http://sketchucation.com/forums/download/file.php?id=134909
                                            • 30
                                            • 31
                                            • 3 / 31
