    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • ntxdaveN
      ntxdave
      @solo said:
      I have the most recent version as well as new LibFredo v8
      I am using SU 2018 pro and Windows 10, I just saved model as V8 for those that do not have new SU versions.
      I am installing a new version of SimLab Composer right now. When it is done, I will update Animator to the latest version and try in 2018 to see if I see any differences.
      Press F1...thank me later
      • soloS
        solo
        I give up, not working for me, this was just a basic test, the whole model has tens of animated sequences including furniture and multiple camera views, it should have been simple as it works so well with SU animation, for some reason Thea has failed me. Can Simlab do this kind of animation? how good is the render quality?
        http://www.solos-art.com
        • ntxdaveN
          ntxdave
          I downloaded the trial version and it does no give me the option to install it for SketchUp 2018. Was going to give it a try for you...........
          Is there something I need to do differently to get a trial version to work with 2018?
          • soloS
            solo
            Maybe they do not have a version compatible with SU 2018 yet, or an installer, try SU 2017
              Sim lab can do it. Not as real as Thea but still pretty acceptable.
              Blender would do this also. But we know where that discussion goes!
              I didn’t try your file yet on my 2018 and Thea. Will do so later.
              • ntxdaveN
                ntxdave
                When I downloaded the trial, it would not give me the option to install for 2018.
                With some of the latest stuff for SimLab composer, you can do what he is trying to do here with Animator. Especially with the VR version plus it has a lot of interactive capabilities.
                Animator also works well with Twilight Render Pro.
                • soloS
                  solo
                  Okay, all fixed, it is indeed a Thea bug and I do have a fix thanks to Tomasz (the Thea plugin author)
                  • fredo6F
                    fredo6
                    What was the fix ?
                    Fredo
                    • soloS
                      solo
                      @fredo6 said:
                      What was the fix ?
                      Fredo
                      I was given a new .rbs file, it's a temporary fix, Tomasz will get that sorted soon, he is very busy with Thea v 2.0 at moment.
                      • ntxdaveN
                        ntxdave
                        Good to hear the situation is being addressed. I had reached out for a trial for 2018 so I could try you model and see what happened on my machine. They did send me a link but I will back off and let you guys get it resolved. 😄
                        • fredo6F
                          fredo6
                          Solo,
                          Thanks. I don't know what the fix can be, as it worked fine on my side.
                          I had to tweak the sunlight setting to remove the black background (not perfect as shadows are projected in the empty space), but I do get a normal movement for the different parts.
                          Fredo
                          Film 1.mov
                          • M
                            Mike598601
                            @fredo6 said:
                            Is Vray 3.6 installed in SU2018?
                            I will investigate on my side
                            Fredo
                            Hi Fredo,
                            Did you check on this? I have just done a completely fresh install of everything onto a new PC, so SU 2018 Pro, Animator 1.8b, LibFredo6 8.0b and V-Ray 3.6 and it still doesn't appear as an option to Render.
                            Kind regards
                            Mike
                            • fredo6F
                              fredo6
                              I installed VRay 3.6 and found the same results as you.
                              Actually, the API has changed and at least one method has disappeared.
                              I contacted Chaos Group to inquire about this.
                              In the meantime, I am afraid that Animator won't support VRay 3.6, as I cannot do anything on my side (note that the VRay API is not documented, and thus the integration in Sketchup was more in a beta stage).
                              Sorry for that. I hope it won't take too long.
                              Fredo
                              • fredo6F
                                fredo6
                                I just published LibFredo6 8.0c, which includes a fix for compatibility with VRay 3.6.
                                However, I noticed that VRay 3.6 may freeze after rendering a number of frames. Please report if you have this case.
                                Fredo
                                • L
                                  liam887
                                  Wow cant wait to take this for a spin!
                                  VISIT MY ONLINE GALLERY
                                  • M
                                    Mike598601
                                    Possible issue with v1.8g - tried to change layer visibility and animator just crashed on saving. Couldn't get out of animator back to sketchup.
                                    • fredo6F
                                      fredo6
                                      Do you mean bugsplat?
                                      Fredo
                                      • fredo6F
                                        fredo6
                                        New Release: Animator - v1.8h - 15 Mar 18
                                        Requirement: LibFredo6 v8.1e
                                        Minor release
                                        • bug fixing of a problem in v1.8g related to cameras and visual effects
                                        • Extension of validity
                                        See main post for RBZ files
                                        • N
                                          nuddles
                                          when I render an animation by vray,it always stop at 2′17″or 2′18″,and continue rendering next frame,however,the last image was not rendered completely. I used Sketchup 2017 pro and VFS 3.40.04
                                          • fredo6F
                                            fredo6
                                            New Release: Animator - v2.0a - 07 May 18
                                            Requirement: LibFredo6 v8.3a
                                            Major release
                                            1. Revamping of the user interface, with a dark theme, based on constructive, artistic advice from derei.
                                            1. Major functional evolutions in the Timeline
                                            • Contextual menu, with many options available about the navigation in the timeline and the manipulation of selected elements
                                            • Move and resize of several elements by dragging. You can also specify a shift for moving the start time and end time of elements, as well as align elements. When moving or resizing elements, there now inferences in the timeline to better align elements
                                            • Insertion (as well as removal) of empty space in the timeline (via contextual menu), and also at the beginning and at the end (via white arrows).
                                            • Advanced Selection panel, filtering by category and position versus the current time
                                            • Change of the time scale by Alt+mousewheel. You can reset to automatic time scaling by Alt + Click in the time track.
                                            • Name of elements displayed in the rectangles in the timeline (optional). There is an option in the Default Parameters to display names when the timeline is Horizontal or Vertical or both, or not to display name.
                                            1. New Positioner dialog box(with single icon in toolbar) allowing to load, save, delete, rename and replace positioners
                                            1. Constant acceleration, based on 2 speeds, one for start one for end, for movements: Translation, Screw, Rotate, Spin and AlongPath
                                            1. SaveNext button in the Movement Editor, allowing to save the current sequence and then go directly to the edition of a new one with the same selected object
                                            1. The visitor mode has been disabled, as it does not work.
                                            See plugin home page of Animator for Download of RBZ from the PluginStore.
                                            See Main Post of the Animator thread for more information.
