    SubD examples and models
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    1.7k Posts 81 Posters 1.8m Views 79 Watching
      @vizan said:
      It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
      I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
          bahri06
          My first post here... still WIP Honda CB 175
          Thanks to Pilou for all your tutorial on you tube channel
          • cottyC Offline
            cotty
            great model and impressive first post...
            my SketchUp gallery
              Cool motor bike! 😎
              (Ps these above videos are not my own videos, alas! 😉
              • HornOxxH Offline
                HornOxx
                👍 perfect! and a nice model idea 😄
                never trust a skinny cook
                • V Offline
                  Vizan
                  Thank you for your attention to this!
                  I noticed that the FredoCorner plugin does this automatically.
                    Wow - that's an impressible detailed model! Very nice topology as well! 👍 👍
                    • panixiaP Offline
                      panixia
                      Dirt jumping bike trails.
                      Sub-d concept
                      3d printed version 😛
                      • panixiaP Offline
                        panixia
                        Please no, or at least make this as an option one can toggle on/off, because in general hidden geometry is BAD. 😐
                        IMHO it would be a more clean workflow to do all the modeling avoiding hidden geometry and only at the last stage, when finalizing geometry for rendering, select all the smoothed edges (select all geometery and then run "selection toys -> select only -> soft edges") and turn them invisible.
                        Fredo corner plugin has an option for this in "rounding parameters->borders->inner edges" and you can toggle.
                        I think that's a good approach, because it can be adapted for different workflows.
                        • V Offline
                          Vizan
                          I found a solution to this problem
                          https://www.youtube.com/watch?v=eBCDTTtv2Hc
                            The solution is making the edges not only soft+smooth, but also hidden?
                              rspierenburg
                              That and using a Vray Toon Material that renders the subd'ed edges.
                              • V Offline
                                Vizan
                                Yes, here I showed how this can be done with the additional selection_edge and Curic Deep Select plugins https://www.youtube.com/watch?v=eBCDTTtv2Hc
                                • panixiaP Offline
                                  panixia
                                  As I said you cand do that using "selection toys" as well.
                                    This feels like a V-Ray bug to me. I'd expect soft edges also to not be rendered along with hidden edges.
                                    • V Offline
                                      Vizan
                                      Unfortunately it is, but it is not critical for me. Of course I wanted this feature to work correctly.
                                      • V Offline
                                        Vizan
                                        Here are my examples of using the SubD tool, in part or in full;)
                                        • panixiaP Offline
                                          panixia
                                          Nice furniture models. 👍
                                          • V Offline
                                            Vizan
                                            Thanks, I'm still studying 😄
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 83
                                            • 84
                                            • 68 / 84
