    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • panixiaP
      panixia
      Dirt jumping bike trails.
      Sub-d concept
      3d printed version 😛
      • panixiaP
        panixia
        @thomthom said:
        I just need to make sure it doesn't have any other unintended side-effects.
        Please no, or at least make this as an option one can toggle on/off, because in general hidden geometry is BAD. 😐
        IMHO it would be a more clean workflow to do all the modeling avoiding hidden geometry and only at the last stage, when finalizing geometry for rendering, select all the smoothed edges (select all geometery and then run "selection toys -> select only -> soft edges") and turn them invisible.
        @vizan said:
        Thank you for your attention to this!
        I noticed that the FredoCorner plugin does this automatically.
        Fredo corner plugin has an option for this in "rounding parameters->borders->inner edges" and you can toggle.
        I think that's a good approach, because it can be adapted for different workflows.
        • V
          Vizan
          @thomthom said:
          @vizan said:
          It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
          I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
          I found a solution to this problem
          https://www.youtube.com/watch?v=eBCDTTtv2Hc
            The solution is making the edges not only soft+smooth, but also hidden?
              rspierenburg
              That and using a Vray Toon Material that renders the subd'ed edges.
              • V
                Vizan
                Yes, here I showed how this can be done with the additional selection_edge and Curic Deep Select plugins https://www.youtube.com/watch?v=eBCDTTtv2Hc
                • panixiaP
                  panixia
                  As I said you cand do that using "selection toys" as well.
                    This feels like a V-Ray bug to me. I'd expect soft edges also to not be rendered along with hidden edges.
                    • V
                      Vizan
                      Unfortunately it is, but it is not critical for me. Of course I wanted this feature to work correctly.
                      • V
                        Vizan
                        Here are my examples of using the SubD tool, in part or in full;)
                        • panixiaP
                          panixia
                          Nice furniture models. 👍
                          • V
                            Vizan
                            Thanks, I'm still studying 😄
                            • C
                              Callegari_hr
                              Maybe you are stil studying but you are no student any more. 👍 😉
                              Great modelling.
                              • HornOxxH
                                HornOxx
                                @callegari_hr said:
                                ...maybe you are stil studying but you are no student any more...
                                and I think, Vizan may change his profile from "beginner" to "advanced" 😄 👍 👍 great works
                                never trust a skinny cook
                                • V
                                  Vizan
                                  @pbacot said:
                                  Beautiful work, Vivan. Does it take V-ray to show the subD edge overlay?
                                  Of course not, the functionality of the SubD plugin allows you to do this without Vray, but with Vray effectively)) I am equal to the masters at http://www.3ddd.ru, and I want to represent SketchUp models at the same level.
                                  https://3ddd.ru/3dmodels/show/vincent_contemporary_sofa
                                  https://3ddd.ru/3dmodels/show/sofa_amsterdam_2_seater
                                  https://3ddd.ru/3dmodels/show/thonet_520_chair_set
                                  • pbacotP
                                    Beautiful work, Vizan. Does it take V-ray to show the subD edge overlay?
                                      Coolresults! 😎
                                      • alvisA
                                        alvis
                                        Beautiful furniture. It’s always nice to see talent modeling furniture 👍
                                          Great topology Vizan! And gorgeous VfSU scenes. Loving the velvet material!
                                          • HornOxxH
                                            HornOxx
                                            @hornoxx said:
                                            @thomthom said:
                                            That's a brilliant model!! 😄
                                            @cotty said:
                                            I like his song "Du findest keine Freunde mit Salat, du findest keine Freunde mit Salat, ..." 😉
                                            Nice model!
                                            Thank you Thomas and Cotty - glad you like the model
                                            Cotty, I only know the Simpson´s Salat song version so far 😆
                                            https://www.youtube.com/watch?v=7yA4TJ8s5I4
                                            Just to complete this Bender thing, I've made some new facial expressions just by changing Bender´s eyes and his tooth lines, which is quite funny
                                            I have posted these on the 3D Warehouse If someone wants them
                                            https://3dwarehouse.sketchup.com/model.html?id=854df1f5-7dbc-41f4-9291-9a0439ff5dc4
                                            edit 3-20-2020 - Corona Virus time 😞
                                            Corona
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 83
                                            • 84
                                            • 68 / 84
