    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    SketchUp 2015 is 64bit
    302 Posts 74 Posters 37.8k Views 74 Watching
      david.
      Ha! Too simple. That's it, thanks!
      • tt_suT Offline
        tt_su
        @tig said:
        We are actually doing a favor to any users who were having problems installing v2015 in its initial format, and to the tardy SketchUp/Trimble guys - by announcing their updated version, which has been available since the end of last week, but which Trimble have failed to publicize thus far !
        The issue was not installer crash - it was a crash upon launching SketchUp once it had been installed. This was happening on certain custom locations such as root of a drive or unicode paths. The patch prevent the crash and let SketchUp work in the root of a drive. Though installing to unicode paths will still fail to load the Ruby StdLib so some extensions might not work.
        • tt_suT Offline
          tt_su
          @driven said:
          does 'check for update' work?
          or is it not in that pipeline yet?
          john
          It wonΒ΄t be pushed to existing users like most of our normal maintenance releases has been. This is because if you where affected you would not have been able to update because SketchUp would crash upon launch. If you where able to start SketchUp then you have no need for this update.
          This is more of a hotfix than a maintenance release.
            driven
            @tt
            so the advice for us to pass on to those who crash on first start-up, should be to...
            submit the bug-splat for the download link?
            or
            simply re-download?
            john
              Glad that's been clarified - elsewhere I was sure someone said it was a crash when installing M0, rather than a BugSplat when starting M0...
              So you don't need M1 unless you were having problems starting M0.
              Of course unless you submitted a splat-report for M0, then you won't learn of M1's existence unless you read this post, or you decide to try downloading the installer again - but why would you? - with no announcement you'll expect it to be the same as the one you had already - so you'll just remain pissed-off with SketchUp and bemoan the lack of an update - which is actually there, but which has been secretly launched, so you haven't found out about it... πŸ˜’
              The Release Notes are still confusingly out of step, for anyone who decides to check their version against those... versions are shown for M0 [15.0...] not M1 [15.1...]
              • hellnbakH Offline
                hellnbak
                I hate problems (duh!), but so far 2015 has been well worth dealing with any that have popped up (and there have been surprisingly few for such a major rebuild)
                Yay Trimble Team, thanks for all your hard work (take tomorrow off for a job well done πŸ˜‰ )
                Now I'll take off my cheerleader outfit and go back to bed
                hope that didn't excite anybody
                • jujuJ Offline
                  juju
                  @tig said:
                  The first v2015 Maintenance Release M1 is now out.
                  If you download the appropriate installer from the usual SketchUp pages, then you will find it's now 15.1...
                  But currently Trimble have not been able to update their Release Notes which still speak of 15.0...
                  πŸ˜’
                  I understand that the main changes were made to fix issues experienced by a few PC/MAC users who could not install 15.0... without a crash ! and to fix another rare crash with some users when trying some Layout fly-outs...
                  @tig said:
                  http://www.sketchup.com/download/all
                  Thanks for the heads up!
                  • ntxdaveN Offline
                    ntxdave
                    πŸ˜’
                    Interesting - my version still says 15.0 and when I clicked on the Check for Updates link, it says I have the most current version.........
                      This update [M1 -- 15.1...] is more in the nature of a 'hotfix'...
                      [Says Trimble]
                      So it does not register as an update if you check from within SketchUp 2015.
                      Their logic is... if you get to the point where you can check for an update within SketchUp v2015, then it has not done a BugSplat as it opened - so you don't need the update !
                      If you already have v2015 loading and working OK then 15.0... is fine - no need to update !
                      If you have BugSplats when running v2015 then download and install 15.1... from the ../downloads/all link I already provided in an earlier post...
                      • ntxdaveN Offline
                        ntxdave
                        [Says Trimble]
                        Yeah, After I went back and reread some of the posts I see no need for me to update..
                        I will continue having fun with what I have....
                        • tt_suT Offline
                          tt_su
                          @driven said:
                          @tt
                          or
                          simply re-download?
                          john
                          Just instruct them to download M1. We identified the bug so we're not in need of the crash data for that bug for M0 any more.
                          The BugSplat message is a convenience for those that do submit a splat - saves them from contacting support.
                          The US office has taken gobble gobble vacation now. πŸ˜„ I started my vacation yesterday - in London visting some friends. I would have gotten lonely to be working this week with no one replying. πŸ˜„
                          πŸ˜•
                          πŸ˜†
                            driven
                            if need someone to buy a pint for, I'm about...
                            john
                            • tt_suT Offline
                              tt_su
                              john
                              You live in London? Where abouts?
                                driven
                                East Dulwich SE22
                                I'll PM a phone number...
                                  mikey r
                                  @jim said:
                                  You can install and use differing versions of SketchUp on a computer. You can not install both the 32-bit and 64-bit version of SketchUp 2015. So if you are using a version earlier than 2015, you can install 2015 64-bit without affecting your current version.
                                  My desktop is 64 bit but laptop 32 both Windows 7. I use desktop mostly and laptop to show customers at the job. Can I install 64 at home and 32 on laptop without any sharing issues? Any benefits? Is that even an option when I purchase Pro for my 2 computers?
                                    Aerilius
                                    The 2015 license is independent of the bitness (and operating system), as is the file format. You can save a file in any install of SketchUp 2015 and open in another SketchUp 2015.
                                    • K Offline
                                      karllarsen
                                      No, I did NOT read every single post in this thread...
                                      124951.70 KB model
                                      1704 Edges
                                      563 Faces
                                      83 Components
                                      11 Groups
                                      59 Component definitions
                                      3 Layers
                                      31 Materials
                                      2 Styles
                                      Created in SketchUp 8 Pro
                                      i7-980 6-core
                                      24 GB Crucial
                                      Win 7 64-bit
                                      AMD Radeon V7800 2GB with newest driver as of this AM
                                      I can see NO increase in performance, whatsoever, in 2015 64-bit.
                                      Less is more.
                                      • jiminy-billy-bobJ Offline
                                        jiminy-billy-bob
                                        It's a legend that 64bits gives better perfs.
                                        Although, 2015 performs better when creating a lot of faces at once.
                                          slbaumgartner
                                          How do we kill this legend? It caused a roaring debate before SU 2015 went 64-bit, and here it is back again!
                                          • jeff hammondJ Offline
                                            jeff hammond
                                            124951.70 KB model
                                            1704 Edges
                                            563 Faces
                                            what do your stats say with 'show nested components' enabled?
                                            i have a feeling the model is much (much!) heavier than 1700 edges..
                                            are those 3D trees in your image?
                                            dotdotdot
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
