    Followfy 0.2 (2014-05-15)
    18 Posts 11 Posters 8.9k Views 11 Watching
      CAUL
      Followfy is a script intended to solve some special cases where the native FollowMe fails to produce solids. Followfy works like FollowMe and can be used for any path (except loops), however, the solidsolving behaviour only works for planar paths.
      Usage: Select path and profile. Run Followfy from the Plugins menu. The selection may include edges from the profile surface; if the profile and path are stuck together triple click may be used. For predictable results the profile should be at either end of the path.
      Installation: Drop the file in the Plugins folder.
      The example .skp below shows some instances where Followfy produces solids while FollowMe doesn't.
      examples.skp
      CAUL_Followfy_0.2.rb
        Very nice. Your plugin works quite well. May I ask for a modification/addition? Would it be possible to have it also Smooth/Soften curves like the native Follow Me tool does?
        • Rich O BrienR Online
          Hi Caul,
          Awesome script. Thanks for sharing.
          I took some liberties and added you to the Plugin Author pool and uploaded the script to the PluginStore.
            One more inside the toolbox! 😎
            And cool the unic selection + one click! πŸ‘
            ps Maybe an info Message "Followfy is calculating" will be fine for complex path/profile ! πŸ€“
            Followfy is meaning something ?
              Does this normal ? (Followme works, Followfy not! )
              Put the profile at an extremity of the path don't change the result!
              followfy_fail.skp
              • massimoM Offline
                massimo Moderator
                Pilou, from the very fist post of the thread:
                • massimoM Offline
                  massimo Moderator
                  πŸ‘ πŸ˜„
                    Aaaaaaaaaaaaaah ! 😳
                    And this also don't work because I don't put it at the extremity! 😳
                    Now all is fine!
                    Advantage against the FollowMe in this case: select by triple click! 😎
                    • mitcorbM Offline
                      mitcorb
                      Nice tool, Caul.
                      @Pilou: "Followfy is meaning something ?" Straightforward answer is similar to the suffix in Quantify- which means apply a quantity to. Or Signify. It's a somewhat informal attachment commonly done in English, but new for the word follow.
                        cadmunkey
                        Great! could have done with having this yesterday as I had a component in a model that 'follow me' just wouldn't work on.
                        • Bob JamesB Offline
                          Bob James
                          Great addition to the toolbox πŸ‘
                            @Mitcorb Thx! πŸ‘
                            • sdmitchS Offline
                              sdmitch
                              CAUL,
                              Having written a similar plugin almost three years ago, I was very curious as to how you did yours. About the only similarity was the projecting of points on bisecting planes at the corners.
                              It is impossible to test for all possible things that could go wrong so when I seemed to find a situation that causes a failure in the mergeCoPlanarFaces method, I thought you might like to know.
                              Left clicking anywhere in the model causes this results to appear.
                              Adding the next statement eliminates the failure but typically, collecting the edges to be deleted and deleting them after all edges are processed, usually works best.
                                  es.each { |e|
                              		next unless e.faces[0] && e.faces[1]
                                      vs = e.faces[0].vertices + e.faces[1].vertices
                                      p = Geom;;fit_plane_to_points vs
                                      cop = vs.all? { |v| v.position.on_plane? p }
                                      e.erase! if cop
                              cop failure.skp
                              http://sdmitch.blogspot.com/
                                CAUL
                                Interesting, how did you approach the problem?
                                Thanks for the feedback! The mergeCoplanar-method was/is a disaster waiting to happen. I will release an updated version soon.
                                  CAUL
                                  That's on the TODO-list.
                                  As it happens, almost all time is spent trying to build the geometry with the api method add_face. In this release the geometry is built with triangles. The next release will use rectangles when appropriate (which is almost always) and that will roughly double the speed.
                                  • sdmitchS Offline
                                    sdmitch
                                    It is called Edge Follow Me and can be found in the plugins store. It was written in request of a tool that would use an edge/curve profile and do an extrusion.
                                    • MatheronM Offline
                                      Matheron
                                      Thank you very much, what a great plugin!
                                      Followfy is remarkably more solid than native followme for any tested planar nonlooping path.
                                      Please consider adding solidsolving for non-planar paths.
                                      • xiombargX Offline
                                        xiombarg
                                        Nice! Great plugin.
