    [Plugin] Add Layer [1.1.0]
    58 Posts 23 Posters 17.0k Views 23 Watching
      Jim
      Keith - I believe this is fixed in version 1.0.1. Let me know.
      Thanks for taking the time to report the error.
      • K Offline
        ktkoh
        Yes it is fixed now.
        Keith
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          @jim said:
          I don't mind, but I really think you should implement this in Layers Panel natively
          Done!
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=53906%26amp;p=519458#p519458
          Thanks a lot πŸ˜‰
            Jim
            Updated to version 1.1.0 using a Dropdown for selecting and changing the visibility properties.
              dedmin
              Win7 - Personalization - Set Custom text size (DPI)- 125%
                Jim
                Thanks for the report - I am researching a fix.
                • tt_suT Offline
                  tt_su
                  Jim, what version of SKUI are you using? I thought I had it fixed, because I use 125% scaling on my Win7 MacBook pro due to the retina screen.
                    Jim
                    SKUI/version.rb says "0.1.0"
                    • tt_suT Offline
                      tt_su
                      I haven't been updating SKUI version - as I haven't made a release of it. I mean, are you using the latest committed version from GitHub?
                        Jim
                        I thought so, but 3 files have been updated in SKUI and not in Add Layer:
                        core.rb
                        embed_skui.rb
                        js/ui.js
                        But those changes are related to FILE encoding, and browser detection.
                          @otb designworks said:
                          I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new scene, regardless of visibility settings, but this scene is visible on all existing and new layers. It is as if I had used the + button in the Scene Palette.
                          It was installed through the Sketchucation Plugin
                          Thoughts?
                          I am confused πŸ˜•
                          This Plugin opens a dialog so you can make a new Layer or modify the behaviors of a selected existing Layer.
                          The Layer's 'behavior' relates to Scene tabs, and it is in three parts.
                          • Visible in selected [current] Scene tab only
                          • Visible/Hidden in existing Scene tab
                          • Visible/Hidden in new Scene tabs
                            It does not create Scenes ?
                          You seems to be jumbling Layer and Scene πŸ˜•
                          Please clarify...
                          • O Offline
                            otb designworks
                            I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new layer, regardless of visibility settings, but this layer is visible on all existing and new scenes. It is as if I had used the + button in the Layer Palette.
                            Thoughts?
                            Cheers, Chuck
                            OTB Designworks is on Youtube
                            • O Offline
                              otb designworks
                              Yeah, TIG, you had every right to be confused as my original post was, in fact jumbling layers and scenes. I have edited it to reflect what I am seeing correctly.
                              In short, no matter the settings I choose in the plugin, I get a new layer that is visible on all existing and new scenes.
                              Sorry for the confusion.
                              Cheers, Chuck
                                OK, maybe Jim needs to test/comment...
                                  Jim
                                  Are you hitting the Apply button?
                                  • O Offline
                                    otb designworks
                                    I am. It is creating the layer after I do, but the layer visibility is as if I set it to always visible for existing and new scenes, regardless of what I input. I went back to using your old create hidden layer plugin which has been indispensable to me for years and it works fine in SU2015
                                    Cheers, Chuck
                                    • O Offline
                                      otb designworks
                                      Well, no I wasn't actually. I just went back and realized that I created the new layer name, made my visibility chooses, and then hit done. doh.
                                      It is amazing how well it works when one hits apply first.
                                      Thanks guys, I'm sorry to waste everyone's time
                                      Cheers, Chuck
                                        Jim
                                        Not wasted at all - the fact that my guess was correct validates a suspicion I had that the plugin is not as intuitive as it needs to be. Thanks for reporting.
                                        I find the core of many plugins can be written in few lines of code. It is far more difficult to create a good user experience.
                                        • O Offline
                                          otb designworks
                                          I think it pretty slick how you have set up so one can make multiple changes without closing the dialogue. I guess I just assumed that the apply button was for changing the attributes of an existing layer and that, if I was making a new layer, that the done button would create the layer with the choices made as a default. Love the plugin, btw! Thanks for updating it.
                                          Cheers, Chuck
                                            sketchydog
                                            This is NOT working for the primary task. Add a new layer for This Scene Only.
                                            When I do this, the layer shows up in every scene. Nothing different than making a new layer narmally.
                                            What is going on?
                                            SU 2015/Win 7 64 bit
                                            • 2 / 3
