    [Plugin] Add Layer [1.1.0]
    58 Posts 23 Posters 17.4k Views 23 Watching
      @otb designworks said:
      I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new scene, regardless of visibility settings, but this scene is visible on all existing and new layers. It is as if I had used the + button in the Scene Palette.
      It was installed through the Sketchucation Plugin
      Thoughts?
      I am confused πŸ˜•
      This Plugin opens a dialog so you can make a new Layer or modify the behaviors of a selected existing Layer.
      The Layer's 'behavior' relates to Scene tabs, and it is in three parts.
      • Visible in selected [current] Scene tab only
      • Visible/Hidden in existing Scene tab
      • Visible/Hidden in new Scene tabs
        It does not create Scenes ?
      You seems to be jumbling Layer and Scene πŸ˜•
      Please clarify...
      • O
        otb designworks
        I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new layer, regardless of visibility settings, but this layer is visible on all existing and new scenes. It is as if I had used the + button in the Layer Palette.
        Thoughts?
        Cheers, Chuck
        OTB Designworks is on Youtube
        • O
          otb designworks
          Yeah, TIG, you had every right to be confused as my original post was, in fact jumbling layers and scenes. I have edited it to reflect what I am seeing correctly.
          In short, no matter the settings I choose in the plugin, I get a new layer that is visible on all existing and new scenes.
          Sorry for the confusion.
          Cheers, Chuck
            OK, maybe Jim needs to test/comment...
              Jim
              Are you hitting the Apply button?
              • O
                otb designworks
                I am. It is creating the layer after I do, but the layer visibility is as if I set it to always visible for existing and new scenes, regardless of what I input. I went back to using your old create hidden layer plugin which has been indispensable to me for years and it works fine in SU2015
                Cheers, Chuck
                • O
                  otb designworks
                  Well, no I wasn't actually. I just went back and realized that I created the new layer name, made my visibility chooses, and then hit done. doh.
                  It is amazing how well it works when one hits apply first.
                  Thanks guys, I'm sorry to waste everyone's time
                  Cheers, Chuck
                    Jim
                    Not wasted at all - the fact that my guess was correct validates a suspicion I had that the plugin is not as intuitive as it needs to be. Thanks for reporting.
                    I find the core of many plugins can be written in few lines of code. It is far more difficult to create a good user experience.
                    • O
                      otb designworks
                      I think it pretty slick how you have set up so one can make multiple changes without closing the dialogue. I guess I just assumed that the apply button was for changing the attributes of an existing layer and that, if I was making a new layer, that the done button would create the layer with the choices made as a default. Love the plugin, btw! Thanks for updating it.
                      Cheers, Chuck
                        sketchydog
                        This is NOT working for the primary task. Add a new layer for This Scene Only.
                        When I do this, the layer shows up in every scene. Nothing different than making a new layer narmally.
                        What is going on?
                        SU 2015/Win 7 64 bit
                          Jim
                          What is going on?
                          Make sure to press the Apply button?
                          • JClementsJ
                            JClements
                            Would it be possible to have a button (or mouse-over) in the UI which would display a temporary dialog with a summary of which layers have the "Add Layer's HIDDEN attribute" assigned to them and their type of HIDDEN attribute (eg. for a specific scene only, new scenes, etc.)?
                            • O
                              otb designworks
                              Hi Jim,
                              I am experiencing an odd behavior with your Plugin.
                              If I open the Plugin window everything works as expected.
                              If I close the window, however, I can never get it to come back on without completely quitting SU and starting over.
                              Also, I flip between SU and LO with command/tab shortcut on my Mac. If the Plugin window is open while I am doing this, then, when I flip from LO to SU, the curser is unable to click or change tools unless I click up in the menu bar first. If the Plugin window is not open, then everything works as expected.
                              I am using SU 15.0.9349 and LO 15.0.9349 and OS X 10.10.1
                              Cheers, Chuck
                                jwhida
                                I get the following error when I have multiple sketchup documents open (Document1, Document2).
                                The error occurs when I try to use this tool in Document 2, and have previously created a new layer '-section-PLAN-L0' using this tool in Document 1.
                                Error; #<ArgumentError; '-section-PLAN-L0' not valid values in list.>
                                /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/SKUI/listbox.rb;207;in `value='
                                /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;37;in `main'
                                /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;205;in `block in <module;AddLayer>'
                                SketchUp;1;in `call'
                                Using SU-2015-15.3.329 on OSX Yosemite 10.10.2
                                • B
                                  balaskes
                                  I really whish for an option in the dialogue box to choose layer visibility states in future creations of scenes to behave as they would normaly do, meaning copying exact layer visibility states from the scene used as the creation source. As it is now the dialogue offers you to choose eiter visible or invisible layer states in future scene creations. If this is implemented I will save a lot of time an be extremely greatfull!! Thanks!!!
                                  • greenskpG
                                    greenskp
                                    When i rename a layer - 00_Equip --> 00_Equip.01 - and Add Layer[1.1.0] is open, if i closed and open it again, the ruby console show me the following error:
                                    Error; #<ArgumentError; '00_Equip' not valid values in list.>
                                    D;/Plugins/jf_add_layer/SKUI/listbox.rb;207;in `value='
                                    D;/plugins/jf_add_layer/main.rb;37;in `main'
                                    D;/Plugins/jf_add_layer/main.rb;205;in `block in <module;AddLayer>'
                                    • jujuJ
                                      juju
                                      have you tried 00_Equip --> 00_Equip_01 ?
                                        Jim
                                        I updated the plugin to fix this error. The version is 1.1.1.
                                        Note however the dialog needs closed and reopened to recognize a renamed layer.
                                        • greenskpG
                                          greenskp
                                          Thank you Jim. Working fine now.
                                            ASistGar
                                            Thanks so much!! Running perfectly
                                            • 2 / 3
