    [Plugin] Add Layer [1.1.0]
    58 Posts 23 Posters 17.0k Views 23 Watching
      Jim
      @nortti said:
      Thank you for the 'Add Layer' plugin! This is a huge time saver. Although, when I select "Layer visible on selected scene only" it does not create a layer. Am I missing something? Still even without this feature it's a success.
      Thanks for any help in getting this fully working.
      Mac OSX 10.9.2 / SketchUp Pro 2013
      You should get a dialog if you select this option an there are no Scenes in the model. If there are Scenes in the model, then please try to select this option while the Ruby Console window is open. Are there any errors shown?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        @tt_su said:
        Note that in SU older than 2014 creating layers with the special flag might cause SU to trigger the Fix Model dialog. That warning is a bug - nothing was messed up, it was the validation code that was wrong. And the Fix Model dialog will reset the flag unfortunately.
        The only flag causing an issue is "LAYER_HIDDEN_BY_DEFAULT", isn't it?
        • JQLJ Offline
          JQL
          Ahhh! So that's why my models needed fixing everytime!...
          www.casca.pt
          Visit us on facebook!
            Jim
            @otb designworks said:
            Awesome! Any way to change the layer behavior after it has been created?
            For instance, if I make a layer and choose for it to be hidden for new scenes, but then I change my mind and want it visible for new scenes, is that possible to change?
            thanks!
            I could implement editing by using a Listbox instead of a Textbox...
            But then I'd need a dialog for the new layer name...
            Or perhaps not even have the add new layer option - just have the plugin be a layer behavior editor.
              Jim
              @techdave02 said:
              There add scenes layer that works / on only that scene or you can update it to work in other scenes works well for dimensions http://sketchucation.com/forums/viewtopic.php?f=10%26amp;t=36583
              Error 404 (Not Found)!!1
              (sketchuptips.blogspot.ca)
              The option to make the layer "visible on the selected scene only" should work, no?
              That's my blog you linked to - and this plugin is an update to the one you linked to.
                ktkoh
                I downloaded this plugin from the SU Store for the purpose of learning the SKUI interface.
                However while testing I was not able to get the check box "Layer visible on selected Scene only" to create a new layer.
                Error; #<NameError; undefined local variable or method `txt_LayerName' for JF;;AddLayer;Module>
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;155;in `add_layer'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;110;in `block in main'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;82;in `call'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;82;in `block in trigger_event'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;78;in `each'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;78;in `trigger_event'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;357;in `event_control_callback'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;311;in `callback_handler'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;269;in `block in add_callback'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;203;in `call'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;203;in `show_modal'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;203;in `show'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;145;in `main'
                C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;185;in `block in <module;AddLayer>'
                -e;1;in `call'
                The other options worked as expected. Note: this also failed in 2013 with a slightly different error message.
                Keith
                  Jim
                  Keith - I am looking into this, but can not reproduce it in any version from 2008 thru 2014.
                    Jim
                    Keith - I believe this is fixed in version 1.0.1. Let me know.
                    Thanks for taking the time to report the error.
                      ktkoh
                      Yes it is fixed now.
                      Keith
                        jiminy-billy-bob
                        @jim said:
                        I don't mind, but I really think you should implement this in Layers Panel natively
                        Done!
                        404 Not Found
                        (sketchucation.com)
                        Thanks a lot πŸ˜‰
                          Jim
                          Updated to version 1.1.0 using a Dropdown for selecting and changing the visibility properties.
                            dedmin
                            Win7 - Personalization - Set Custom text size (DPI)- 125%
                              Jim
                              Thanks for the report - I am researching a fix.
                              • tt_suT Offline
                                tt_su
                                Jim, what version of SKUI are you using? I thought I had it fixed, because I use 125% scaling on my Win7 MacBook pro due to the retina screen.
                                  Jim
                                  SKUI/version.rb says "0.1.0"
                                  • tt_suT Offline
                                    tt_su
                                    I haven't been updating SKUI version - as I haven't made a release of it. I mean, are you using the latest committed version from GitHub?
                                      Jim
                                      I thought so, but 3 files have been updated in SKUI and not in Add Layer:
                                      core.rb
                                      embed_skui.rb
                                      js/ui.js
                                      But those changes are related to FILE encoding, and browser detection.
                                        I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new scene, regardless of visibility settings, but this scene is visible on all existing and new layers. It is as if I had used the + button in the Scene Palette.
                                        It was installed through the Sketchucation Plugin
                                        Thoughts?
                                        I am confused πŸ˜•
                                        This Plugin opens a dialog so you can make a new Layer or modify the behaviors of a selected existing Layer.
                                        The Layer's 'behavior' relates to Scene tabs, and it is in three parts.
                                        • Visible in selected [current] Scene tab only
                                        • Visible/Hidden in existing Scene tab
                                        • Visible/Hidden in new Scene tabs
                                          It does not create Scenes ?
                                        You seems to be jumbling Layer and Scene πŸ˜•
                                        Please clarify...
                                        • O Offline
                                          otb designworks
                                          I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new layer, regardless of visibility settings, but this layer is visible on all existing and new scenes. It is as if I had used the + button in the Layer Palette.
                                          Thoughts?
                                          Cheers, Chuck
                                          OTB Designworks is on Youtube
                                          • O Offline
                                            otb designworks
                                            Yeah, TIG, you had every right to be confused as my original post was, in fact jumbling layers and scenes. I have edited it to reflect what I am seeing correctly.
                                            In short, no matter the settings I choose in the plugin, I get a new layer that is visible on all existing and new scenes.
                                            Sorry for the confusion.
                                            Cheers, Chuck
                                            • 2 / 3
