    [Plugin] Add Layer [1.1.0]
    58 Posts 23 Posters 17.0k Views 23 Watching
      dedmin
      Win7 - Personalization - Set Custom text size (DPI)- 125%
        Jim
        Thanks for the report - I am researching a fix.
        • tt_suT Offline
          tt_su
          Jim, what version of SKUI are you using? I thought I had it fixed, because I use 125% scaling on my Win7 MacBook pro due to the retina screen.
            Jim
            SKUI/version.rb says "0.1.0"
            • tt_suT Offline
              tt_su
              I haven't been updating SKUI version - as I haven't made a release of it. I mean, are you using the latest committed version from GitHub?
                Jim
                I thought so, but 3 files have been updated in SKUI and not in Add Layer:
                core.rb
                embed_skui.rb
                js/ui.js
                But those changes are related to FILE encoding, and browser detection.
                  @otb designworks said:
                  I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new scene, regardless of visibility settings, but this scene is visible on all existing and new layers. It is as if I had used the + button in the Scene Palette.
                  It was installed through the Sketchucation Plugin
                  Thoughts?
                  I am confused πŸ˜•
                  This Plugin opens a dialog so you can make a new Layer or modify the behaviors of a selected existing Layer.
                  The Layer's 'behavior' relates to Scene tabs, and it is in three parts.
                  • Visible in selected [current] Scene tab only
                  • Visible/Hidden in existing Scene tab
                  • Visible/Hidden in new Scene tabs
                    It does not create Scenes ?
                  You seems to be jumbling Layer and Scene πŸ˜•
                  Please clarify...
                  • O Offline
                    otb designworks
                    I am running mac 10.9.5 and SU2015. This plugin is not working at all on my system. It will create a new layer, regardless of visibility settings, but this layer is visible on all existing and new scenes. It is as if I had used the + button in the Layer Palette.
                    Thoughts?
                    Cheers, Chuck
                    OTB Designworks is on Youtube
                    • O Offline
                      otb designworks
                      Yeah, TIG, you had every right to be confused as my original post was, in fact jumbling layers and scenes. I have edited it to reflect what I am seeing correctly.
                      In short, no matter the settings I choose in the plugin, I get a new layer that is visible on all existing and new scenes.
                      Sorry for the confusion.
                      Cheers, Chuck
                        OK, maybe Jim needs to test/comment...
                          Jim
                          Are you hitting the Apply button?
                          • O Offline
                            otb designworks
                            I am. It is creating the layer after I do, but the layer visibility is as if I set it to always visible for existing and new scenes, regardless of what I input. I went back to using your old create hidden layer plugin which has been indispensable to me for years and it works fine in SU2015
                            Cheers, Chuck
                            • O Offline
                              otb designworks
                              Well, no I wasn't actually. I just went back and realized that I created the new layer name, made my visibility chooses, and then hit done. doh.
                              It is amazing how well it works when one hits apply first.
                              Thanks guys, I'm sorry to waste everyone's time
                              Cheers, Chuck
                                Jim
                                Not wasted at all - the fact that my guess was correct validates a suspicion I had that the plugin is not as intuitive as it needs to be. Thanks for reporting.
                                I find the core of many plugins can be written in few lines of code. It is far more difficult to create a good user experience.
                                • O Offline
                                  otb designworks
                                  I think it pretty slick how you have set up so one can make multiple changes without closing the dialogue. I guess I just assumed that the apply button was for changing the attributes of an existing layer and that, if I was making a new layer, that the done button would create the layer with the choices made as a default. Love the plugin, btw! Thanks for updating it.
                                  Cheers, Chuck
                                    sketchydog
                                    This is NOT working for the primary task. Add a new layer for This Scene Only.
                                    When I do this, the layer shows up in every scene. Nothing different than making a new layer narmally.
                                    What is going on?
                                    SU 2015/Win 7 64 bit
                                      Jim
                                      What is going on?
                                      Make sure to press the Apply button?
                                      • JClementsJ Offline
                                        JClements
                                        Would it be possible to have a button (or mouse-over) in the UI which would display a temporary dialog with a summary of which layers have the "Add Layer's HIDDEN attribute" assigned to them and their type of HIDDEN attribute (eg. for a specific scene only, new scenes, etc.)?
                                        • O Offline
                                          otb designworks
                                          Hi Jim,
                                          I am experiencing an odd behavior with your Plugin.
                                          If I open the Plugin window everything works as expected.
                                          If I close the window, however, I can never get it to come back on without completely quitting SU and starting over.
                                          Also, I flip between SU and LO with command/tab shortcut on my Mac. If the Plugin window is open while I am doing this, then, when I flip from LO to SU, the curser is unable to click or change tools unless I click up in the menu bar first. If the Plugin window is not open, then everything works as expected.
                                          I am using SU 15.0.9349 and LO 15.0.9349 and OS X 10.10.1
                                          Cheers, Chuck
                                            jwhida
                                            I get the following error when I have multiple sketchup documents open (Document1, Document2).
                                            The error occurs when I try to use this tool in Document 2, and have previously created a new layer '-section-PLAN-L0' using this tool in Document 1.
                                            Error; #<ArgumentError; '-section-PLAN-L0' not valid values in list.>
                                            /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/SKUI/listbox.rb;207;in `value='
                                            /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;37;in `main'
                                            /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;205;in `block in <module;AddLayer>'
                                            SketchUp;1;in `call'
                                            Using SU-2015-15.3.329 on OSX Yosemite 10.10.2
                                            • 2 / 3
