    [WIP] turfstone pavers
    18 Posts 8 Posters 3.4k Views 8 Watching
    • novenaN
      novena
      hi everyone,
      here comes a test with turfstone pavers for a project I'm currently working on...
      sketchup + maxwell render standalone plugin for sketchup (this image is done with the free version)
      best
      V
      p.s. there's a couple of blades growing on the concrete 😳
      http://hdzarkitektur.wordpress.com/
      • soloS
        solo
        Caught my eye too.
        Looking great however, what we need is a collision control setting to avoid such issues.
        http://www.solos-art.com
        • massimoM
          massimo Moderator
          Looking good. πŸ‘
          • gillesG
            gilles
            πŸ’š
            • novenaN
              novena
              hi guys, thanks for your comments!!!
              solo, the grass is done with maxwell's grass feature, I think it is not possible to apply a collision control, but I did some corrections to the density map to correct the issue...
              massimo, much appreciated πŸ˜„
              gilles, πŸ˜†
              best
              V
              • KrisidiousK
                Krisidious
                total realism... very nice.
                By: Kristoff Rand
                • novenaN
                  novena
                  thanks so much krisidious!!!
                  • omiKronO
                    omiKron
                    Reality OWN'D ! πŸ‘ πŸ‘
                    • T
                      tom72
                      great! about grass: how did you added it?
                      • T
                        tom72
                        ah ok, maxwell's plug in.
                        Can anybody indicate a tutorial for DOF in v-ray for SU?
                        tnx
                        T
                        • CarlohC
                          Carloh
                          very nice Victor! did you use the SSS-grass material for this one?
                          • T
                            tom72
                            @novena: I'll try and let u know
                            • novenaN
                              novena
                              Tomasso, hope that tutorial is helpful...
                              best
                              V
                              • novenaN
                                novena
                                hi guys!
                                here comes another test image, same scene tested at night time...
                                for this one used a HDRI for illumination, the lamp is the HEB II 150-150 model from TAL (technical architectural lighting)
                                hope you like it
                                best
                                V
                                • soloS
                                  solo
                                  Nice!!
                                  • omiKronO
                                    omiKron
                                    Wow that's stunning ! I guess that fitted into a more complex scene with 3D buildings and urban equipment would take a lot of time to render unless using a render-farm will solve the time problem πŸ˜† Anyway... nowadays you can't even notice the difference between some renders and reality, just that renders are much cleaner than the real thing, that's why you achieved making a scene and a render that looks like a real picture β˜€ πŸ‘ πŸ‘
                                    • novenaN
                                      novena
                                      Solo, I really appreciate your comment!!
                                      omiKron, thanks a lot!!!!
                                      best
                                      V
                                      • novenaN
                                        novena
                                        hi again!
                                        omiKron, thanks for your comment!!
                                        tom72, thanks a lot, yes, grass is made with the maxwell's grass feature...
                                        about DOF in vray: you have to create a z depth pass, then in photoshop use that pass to give the depth to your render using the lens blur filter...
                                        the following tutorial is for 3D max but it should work similar with SU + vray
                                        http://www.onnovanbraam.com/index.php?tutorials/depth_of_field/
                                        Carloh, much appreciated! I used SSS (single sided) material for grass, and a texture for the blades shared by Peter Guthrie in this tutorial:
                                        http://www.peterguthrie.net/blog/2009/04/vray-grass-tutorial-part-2/
                                        thanks again, best
                                        V
