    [WIP] turfstone pavers
    18 Posts 8 Posters 3.3k Views 8 Watching
    • novenaN Offline
      novena
      hi guys, thanks for your comments!!!
      solo, the grass is done with maxwell's grass feature, I think it is not possible to apply a collision control, but I did some corrections to the density map to correct the issue...
      massimo, much appreciated πŸ˜„
      gilles, πŸ˜†
      best
      V
      http://hdzarkitektur.wordpress.com/
      • KrisidiousK Offline
        Krisidious
        total realism... very nice.
        By: Kristoff Rand
        • novenaN Offline
          novena
          thanks so much krisidious!!!
          • omiKronO Offline
            omiKron
            Reality OWN'D ! πŸ‘ πŸ‘
              tom72
              great! about grass: how did you added it?
                tom72
                ah ok, maxwell's plug in.
                Can anybody indicate a tutorial for DOF in v-ray for SU?
                tnx
                T
                • CarlohC Offline
                  Carloh
                  very nice Victor! did you use the SSS-grass material for this one?
                    tom72
                    @novena: I'll try and let u know
                    • novenaN Offline
                      novena
                      Tomasso, hope that tutorial is helpful...
                      best
                      V
                      • novenaN Offline
                        novena
                        hi guys!
                        here comes another test image, same scene tested at night time...
                        for this one used a HDRI for illumination, the lamp is the HEB II 150-150 model from TAL (technical architectural lighting)
                        hope you like it
                        best
                        V
                        • soloS Offline
                          Nice!!
                          • omiKronO Offline
                            omiKron
                            Wow that's stunning ! I guess that fitted into a more complex scene with 3D buildings and urban equipment would take a lot of time to render unless using a render-farm will solve the time problem πŸ˜† Anyway... nowadays you can't even notice the difference between some renders and reality, just that renders are much cleaner than the real thing, that's why you achieved making a scene and a render that looks like a real picture β˜€ πŸ‘ πŸ‘
                            • novenaN Offline
                              novena
                              Solo, I really appreciate your comment!!
                              omiKron, thanks a lot!!!!
                              best
                              V
                              • novenaN Offline
                                novena
                                hi again!
                                omiKron, thanks for your comment!!
                                tom72, thanks a lot, yes, grass is made with the maxwell's grass feature...
                                about DOF in vray: you have to create a z depth pass, then in photoshop use that pass to give the depth to your render using the lens blur filter...
                                the following tutorial is for 3D max but it should work similar with SU + vray
                                http://www.onnovanbraam.com/index.php?tutorials/depth_of_field/
                                Carloh, much appreciated! I used SSS (single sided) material for grass, and a texture for the blades shared by Peter Guthrie in this tutorial:
                                http://www.peterguthrie.net/blog/2009/04/vray-grass-tutorial-part-2/
                                thanks again, best
                                V
