    [WIP] turfstone pavers
    18 Posts 8 Posters 3.5k Views 8 Watching
    • massimoM
      massimo Moderator
      Looking good. πŸ‘
      • gillesG
        gilles
        πŸ’š
        • novenaN
          novena
          hi guys, thanks for your comments!!!
          solo, the grass is done with maxwell's grass feature, I think it is not possible to apply a collision control, but I did some corrections to the density map to correct the issue...
          massimo, much appreciated πŸ˜„
          gilles, πŸ˜†
          best
          V
          http://hdzarkitektur.wordpress.com/
          • KrisidiousK
            Krisidious
            total realism... very nice.
            By: Kristoff Rand
            • novenaN
              novena
              thanks so much krisidious!!!
              • omiKronO
                omiKron
                Reality OWN'D ! πŸ‘ πŸ‘
                • T
                  tom72
                  great! about grass: how did you added it?
                  • T
                    tom72
                    ah ok, maxwell's plug in.
                    Can anybody indicate a tutorial for DOF in v-ray for SU?
                    tnx
                    T
                    • CarlohC
                      Carloh
                      very nice Victor! did you use the SSS-grass material for this one?
                      • T
                        tom72
                        @novena: I'll try and let u know
                        • novenaN
                          novena
                          Tomasso, hope that tutorial is helpful...
                          best
                          V
                          • novenaN
                            novena
                            hi guys!
                            here comes another test image, same scene tested at night time...
                            for this one used a HDRI for illumination, the lamp is the HEB II 150-150 model from TAL (technical architectural lighting)
                            hope you like it
                            best
                            V
                            • soloS
                              Nice!!
                              • omiKronO
                                omiKron
                                Wow that's stunning ! I guess that fitted into a more complex scene with 3D buildings and urban equipment would take a lot of time to render unless using a render-farm will solve the time problem πŸ˜† Anyway... nowadays you can't even notice the difference between some renders and reality, just that renders are much cleaner than the real thing, that's why you achieved making a scene and a render that looks like a real picture β˜€ πŸ‘ πŸ‘
                                • novenaN
                                  novena
                                  Solo, I really appreciate your comment!!
                                  omiKron, thanks a lot!!!!
                                  best
                                  V
                                  • novenaN
                                    novena
                                    hi again!
                                    omiKron, thanks for your comment!!
                                    tom72, thanks a lot, yes, grass is made with the maxwell's grass feature...
                                    about DOF in vray: you have to create a z depth pass, then in photoshop use that pass to give the depth to your render using the lens blur filter...
                                    the following tutorial is for 3D max but it should work similar with SU + vray
                                    http://www.onnovanbraam.com/index.php?tutorials/depth_of_field/
                                    Carloh, much appreciated! I used SSS (single sided) material for grass, and a texture for the blades shared by Peter Guthrie in this tutorial:
                                    http://www.peterguthrie.net/blog/2009/04/vray-grass-tutorial-part-2/
                                    thanks again, best
                                    V
