    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 181.3k Views 54 Watching
    • TIGT Online
      @jim said:
      in cmd.set_validation_proc (and other places) you want to give the full scope of the suitable? method since it is being called from SketchUp outside the scope of your module.
      Also, combine the MF_ bits.
      > cmd=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
      > if TIG;;Smart_offsetter.suitable?()
      > MF_ENABLED
      > else
      > MF_DISABLED | MF_GRAYED
      > end
      Thanks, knew it was obvious... This only affected MACs though ???
      This was collecting dust on a virtual dust, until Pilou reminded me that I'd written it, so sometimes things get 'forgotten'... ๐Ÿ˜’
      • TIGT Online
        Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
        Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
        Seems to be especially for MACs ๐Ÿ˜„
          Jim
          I am not sure - it was just a guess and I don't have a Mac. Did you try it? ๐Ÿ˜†
          • TIGT Online
            I don't have a MAC either. ๐Ÿ˜•
            Driven's reported issue was on a MAC and Jeff had other issues on a MAC too...
            Hopefully this recent v1.2 [...20121221b.rbz !] will address the suitable? check and MF_ issues with the menus/toolbar...
            It still works fine on a PC, but then v1.1 did too ๐Ÿ˜• ๐Ÿ˜„
            • elmerE Offline
              elmer
              Nice Christmas gift Tig, thanks a lot, it works perfectly on my Mac.
              • alvisA Offline
                alvis
                Thanx TIG
                • guanjinG Offline
                  guanjin
                  TIG: Merry Christmas
                  I come from China, is to learn
                  • jeff hammondJ Offline
                    jeff hammond
                    Hi Tig
                    i'm still getting the same greyed out problem.
                    is there anything i can type in the console or ?? to help figure out what the problem is?
                    thanks
                    dotdotdot
                    • TIGT Online
                      Is there no difference at all - if you have nothing preselected, or one edge preselected, or one face preselected, or lots of things [including some edges] preselected ?
                      The menu/toolbar are only enabled if there's at least one face in the current selection.
                      The context-menu only appears if there's at least one face in the current selection.
                      Copy/paste+<enter> these into the Ruby Console and report the results:
                      with nothing preselected TIG::Smart_offsetter.suitable?()
                      with one edge preselected TIG::Smart_offsetter.suitable?()
                      with one face preselected TIG::Smart_offsetter.suitable?()
                      with lots of things [including some edges] preselected TIG::Smart_offsetter.suitable?()
                      with one edge preselected TIG::Smart_offsetter.dialog()
                      with one face preselected TIG::Smart_offsetter.dialog()
                      ๐Ÿ˜•
                        jeff hammond
                        oops ๐Ÿ˜ณ
                        it actually is working now..
                        it's just the toolbar that remains greyed out at all times but the menu item becomes available once an appropriate selection has been made..
                        (which, for me personally, is fine.. i more likely than not wont want the toolbar anyway.. i think id use it with a modifier key added to my offset shortcut)
                        dotdotdot
                          jeff hammond
                          here are these results.. (since you took the time to write them.. i better take the time to report ๐Ÿ˜‰ )
                          false
                          false
                          true
                          true (drew two squares and selected all)
                          warning- PreSelect Face[s !]
                          ruby - nil
                          (works as expected)
                          dotdotdot
                            jeff hammond
                            uh.. not sure what the deal is but..
                            upon entering all of that stuff in the console, the toolbar is now working
                            ๐Ÿ˜•
                            [edit] but then.. i quit sketchup then relaunched and the toolbar is greyed out again regardless of selection.. the menu item is working though
                            dotdotdot
                            • Chris FullmerC Offline
                              voodoo. definitely voodoo at work here.
                              All my Plugins I've written
                                jeff hammond
                                ha.. that darn voodoo! ๐Ÿ˜„
                                some more info:
                                so here's what the deal with the toolbar is.. (in this example, i have 3 squares with faces drawn)
                                โ€ขcmmdA (select all)
                                โ€ขtoolbar remains greyed out (menu item is live)
                                โ€ขdo something else (rotate, pan, etc)
                                โ€ขtoolbar becomes active
                                โ€ขdeselect all
                                โ€ขtoolbar remains active (menu item greys out)
                                โ€ขdo something else (switch tool, orbit, etc)
                                โ€ขtoolbar greys out
                                so it appears, on mac, that something has to happen other than simply selecting in order to jump start the toolbar into updating it's state
                                dotdotdot
                                  ccbiggs
                                  Hey Tig,
                                  I am getting the same thing Jeff has. But since Jeff actually knows what he is doing, he can do the ruby troubleshooting. Will stay tuned to see what you fellas figure out.
                                  It works great on my windows machine at home.
                                  Thanks Tig
                                  Update
                                  Jeff says his works. It does not work on my mac.
                                  false
                                  false
                                  true
                                  true
                                  TIG.Smart_offset:
                                  PreSelect Face[s] !
                                  Offset [+/-ve=out/
                                  My drop down "Tools" Menu works with a face preselected. The toolbar does not.
                                  Nothing works with just edges selected.
                                  If you need me to check anything else, and I do not get right back to ya, I am not ignoring you I am just here there and everywhere today.
                                  • TIGT Online
                                    Here's v1.3 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                                    Removed 'suitable?' method, to suit MACs, more error traps etc.
                                    Try this and report back... ๐Ÿ˜’
                                      ccbiggs
                                      It works the same for me. With a face selected the drop down tools menu item will work but the single icon toolbar will not.
                                      • TIGT Online
                                        Which is weird... because they BOTH use 'cmd' and share the same enabled/grayed code...
                                        To check that the toolbar WILL work somehow... can you please edit the file 'TIG-Smart_offset.rb' on your MAC with a plain text editor [BBedit???] and find the three lines starting at #117 reading:
                                        		cmd.set_validation_proc{
                                        			Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
                                        and change them to read
                                        		#cmd.set_validation_proc{
                                        			#Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
                                        i.e. add a # in front of each of the three lines to disable them.
                                        Now the tool's command should always be 'enabled' in the menu & the toolbar button, if you try to use it without a Face in the Selection you'll get an error messagebox...
                                        Let me know how this goes...
                                        Incidentally, BEFORE [& after] you make the changes... do you get the tool's context-menu item IF there's a Face in the Selection ?
                                          jeff hammond
                                          that does the trick.. the toolbar is always active now and i'll just receive an error if i try to run the tool without an appropriate selection..
                                          [context menu works also.. but it worked prior to disabling the above lines]
                                          dotdotdot
                                          • TIGT Online
                                            OK !
                                            The current tool [v1.3] works just fine for PCs... but it baulks on a MAC with some of the enable/grayed code for the toolbar button - which is weird... ๐Ÿ˜•
                                            The editing of the three lines of code in the script to disable them with a leading #... as indicated in the preceding posts... will fix it for MAC users...
                                            I'll see if I can get a version working properly for PC and MAC without this cludge ! ๐Ÿ˜ž
                                            In the meantime, please report any issues...
                                            Merry Xmas ๐Ÿ˜„
                                            Apocalypse averted! ๐Ÿ˜›
                                            Phew! ๐Ÿ˜‰
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
