    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 199.8k Views 54 Watching
    • jeff hammondJ
      @tig said:
      Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
      Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
      Seems to be especially for MACs 😄
      Hi Tig
      i'm still getting the same greyed out problem.
      is there anything i can type in the console or ?? to help figure out what the problem is?
      thanks
        Is there no difference at all - if you have nothing preselected, or one edge preselected, or one face preselected, or lots of things [including some edges] preselected ?
        The menu/toolbar are only enabled if there's at least one face in the current selection.
        The context-menu only appears if there's at least one face in the current selection.
        Copy/paste+<enter> these into the Ruby Console and report the results:
        with nothing preselected TIG::Smart_offsetter.suitable?()
        with one edge preselected TIG::Smart_offsetter.suitable?()
        with one face preselected TIG::Smart_offsetter.suitable?()
        with lots of things [including some edges] preselected TIG::Smart_offsetter.suitable?()
        with one edge preselected TIG::Smart_offsetter.dialog()
        with one face preselected TIG::Smart_offsetter.dialog()
        • jeff hammondJ
          oops 😳
          it actually is working now..
          it's just the toolbar that remains greyed out at all times but the menu item becomes available once an appropriate selection has been made..
          (which, for me personally, is fine.. i more likely than not wont want the toolbar anyway.. i think id use it with a modifier key added to my offset shortcut)
          • jeff hammondJ
            here are these results.. (since you took the time to write them.. i better take the time to report 😉 )
            false
            false
            true
            true (drew two squares and selected all)
            warning- PreSelect Face[s !]
            ruby - nil
            (works as expected)
            • jeff hammondJ
              uh.. not sure what the deal is but..
              upon entering all of that stuff in the console, the toolbar is now working
              [edit] but then.. i quit sketchup then relaunched and the toolbar is greyed out again regardless of selection.. the menu item is working though
              • Chris FullmerC
                voodoo. definitely voodoo at work here.
                • jeff hammondJ
                  ha.. that darn voodoo! 😄
                  some more info:
                  so here's what the deal with the toolbar is.. (in this example, i have 3 squares with faces drawn)
                  •cmmdA (select all)
                  •toolbar remains greyed out (menu item is live)
                  •do something else (rotate, pan, etc)
                  •toolbar becomes active
                  •deselect all
                  •toolbar remains active (menu item greys out)
                  •do something else (switch tool, orbit, etc)
                  •toolbar greys out
                  so it appears, on mac, that something has to happen other than simply selecting in order to jump start the toolbar into updating it's state
                  • C
                    ccbiggs
                    Hey Tig,
                    I am getting the same thing Jeff has. But since Jeff actually knows what he is doing, he can do the ruby troubleshooting. Will stay tuned to see what you fellas figure out.
                    It works great on my windows machine at home.
                    Thanks Tig
                    Update
                    Jeff says his works. It does not work on my mac.
                    false
                    false
                    true
                    true
                    TIG.Smart_offset:
                    PreSelect Face[s] !
                    Offset [+/-ve=out/
                    My drop down "Tools" Menu works with a face preselected. The toolbar does not.
                    Nothing works with just edges selected.
                    If you need me to check anything else, and I do not get right back to ya, I am not ignoring you I am just here there and everywhere today.
                      Here's v1.3 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                      Removed 'suitable?' method, to suit MACs, more error traps etc.
                      Try this and report back... 😒
                      • C
                        ccbiggs
                        It works the same for me. With a face selected the drop down tools menu item will work but the single icon toolbar will not.
                          Which is weird... because they BOTH use 'cmd' and share the same enabled/grayed code...
                          To check that the toolbar WILL work somehow... can you please edit the file 'TIG-Smart_offset.rb' on your MAC with a plain text editor [BBedit???] and find the three lines starting at #117 reading:
                          		cmd.set_validation_proc{
                          			Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
                          and change them to read
                          		#cmd.set_validation_proc{
                          			#Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
                          i.e. add a # in front of each of the three lines to disable them.
                          Now the tool's command should always be 'enabled' in the menu & the toolbar button, if you try to use it without a Face in the Selection you'll get an error messagebox...
                          Let me know how this goes...
                          Incidentally, BEFORE [& after] you make the changes... do you get the tool's context-menu item IF there's a Face in the Selection ?
                          • jeff hammondJ
                            that does the trick.. the toolbar is always active now and i'll just receive an error if i try to run the tool without an appropriate selection..
                            [context menu works also.. but it worked prior to disabling the above lines]
                              OK !
                              The current tool [v1.3] works just fine for PCs... but it baulks on a MAC with some of the enable/grayed code for the toolbar button - which is weird... 😕
                              The editing of the three lines of code in the script to disable them with a leading #... as indicated in the preceding posts... will fix it for MAC users...
                              I'll see if I can get a version working properly for PC and MAC without this cludge ! 😞
                              In the meantime, please report any issues...
                              Merry Xmas 😄
                              Apocalypse averted! 😛
                              Phew! 😉
                              • simon le bonS
                                simon le bon
                                Thank you for this one really "smart" dear TIG +++
                                We were used to the quirks of the native offset tool as a fatality. It is a surprise to realize that it was not the case 😮 😮 😮
                                Merry Christmas to you too 😍
                                Simon
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG-Smart_offsetv1320121221.jpg
                                  driven
                                  I posted this on the first page and it will work on both?
                                  set validation doesn't seem to work on macs on Toolbars
                                  cmd2=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
                                  cmd2.small_icon=File.join(dir, 'TIG-Smart_offset.png')
                                  cmd2.large_icon=File.join(dir, 'TIG-Smart_offset.png')
                                  toolbar=UI;;Toolbar.new('TIG.Smart_offset')
                                  toolbar.add_item(cmd2)
                                    Here's v1.4 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                                    It now only applies toolbar enabled/grayed [validation] on PCs; on a MAC the toolbar button is always enabled, but when you attempt to use it without a suitable preselection there's an error-messagebox...
                                    This now means PC and MAC users should have a quite similar usage 😄
                                    • DareDevilD
                                      DareDevil
                                      Thanks for this advanced tool ! 👍 Nice to solve round edge offset.
                                      But I have a two requests :
                                      First, (crossing post with Pilou 😉) I think when the offset cross itself, there is a chance it make a hole. Your Smart Offset fill all the shape. It will be cool if your toll can solve this case.
                                      The second is a bonus setting to create a round offset like this :
                                      round-offset.jpgI don't know if it's "easy" to make this kind of function, perhaps crossing your offset tool and your Chamfer tool from 2D Tools.
                                        From Daredevil
                                        Original
                                        Smart_Offest
                                        Normal result wished
                                        http://sketchucation.com/forums/download/file.php?id=98395&mode=view/rokbox.jpg
                                          DareDevil/Pilou
                                          I had been following your discussions about this in the French forum...
                                          I know what you are asking for, but it is very complicated to come up with an algorithm to remove the 'hole' - it's easy for us to 'see' what's to go and what's to stay, but in code it is very complicated to ensure that the unwanted parts are removed.
                                          If anyone has any ideas [even seemingly silly ones?] I am open to suggestions...
                                          On the 'rounded corner' matter... This effectively a 'multi-fillet' tool.
                                          The main issue I see in you'd need to select just the edges to fillet and not a face, otherwise in the case you illustrated the already curved part would potentially get 'multi-filleted'...
                                          That's x6 clicks to select the ones needed with a new tool - or x2 to select face & its-edges, then x2+Ctrl+Shift to remove the face and the unwanted arc [or +x1 click to make a fence, e.g. for an 'arc' made from exploded edges...] - say x4 or x5...
                                          OR using the existing 2dFillet tool x2 per vertex = x10 clicks.
                                          But are your few extra clicks worth my lost brain-cells needed to contrive this wonder ?
                                            For the multi fillet
                                            Surely not but don't forget the pleasure to find the solution! 😉
                                            • 2 / 8
