    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Brionvega radio Ts522
    42 Posts 19 Posters 1.3k Views 19 Watching
    • massimoM Offline
      massimo Moderator
      πŸ˜„ Thank you Kim.
      • olisheaO Offline
        olishea
        massimo thanks for the screenie....looks great, did you already map the texture in SU? or scale in Thea?
        Very convincing and a fantastic model πŸ‘
        oli
        • massimoM Offline
          massimo Moderator
          All done in Thea, projection & scale.
          care to explain black material on face of radio?
          Sorry missed this one. Here you have a screenshot of the black mat. The map in the reflectance & roughness slots is the same (used some grungy greyscale texture), just more contrast directly in Thea for the roughness's one. The bump map is a noise texture.πŸ˜„
            Thanks for sharing the settings. πŸ‘
            • marked001M Offline
              marked001
              I really need some lessons in creating materials.. can someone arrange that? πŸ˜„ amazing stuff, as usual.
              http://www.revision21vis.com
              instagram: revi21on
              • olisheaO Offline
                olishea
                ah it was adding the texture to roughness slot that was throwing me off! Nice work!
                Is roughness without texture essentially a noise map?
                oli
                • beginnerB Offline
                  beginner
                  massimo,
                  The model looks great...
                  The metal and paint are even better πŸ‘
                  Regards, SU 'beginner'
                  • massimoM Offline
                    massimo Moderator
                    Thanks again guys. πŸ˜„
                    Well basically roughness is related to the fuzziness of the specular reflectance & transmittance. A value of "0" is a perfect mirror, by increasing the value you'll reach a diffuse-like look. Also if you use a map the white parts are rough and blacks are shining.
                    • StinkieS Offline
                      Stinkie
                      Fantastic. πŸ‘ I'd love to take a look at that plastic material. It looks great, especially in the second pic.
                      • olisheaO Offline
                        olishea
                        That's what i was looking for, cheers. I love the roughness feature.
                        oli
                        • massimoM Offline
                          massimo Moderator
                          Thanks Gregory and Tom. πŸ˜„
                          Playing a bit with Magic bullet photolooks. An amazing tool. πŸ‘
                          • GarethG Offline
                            Gareth
                            Massimo,
                            i once said i'd never speak to you ever again if you kept posting such amazing work....
                            ....i lied....!! πŸ˜†
                            πŸ‘
                            • massimoM Offline
                              massimo Moderator
                              πŸ˜†
                              • StinkieS Offline
                                Stinkie
                                I like it. πŸ‘
                                • jo-keJ Offline
                                  jo-ke
                                  Wow 😲
                                  absolutely great work!! πŸ‘
                                  http://www.zz7.de
                                  • massimoM Offline
                                    massimo Moderator
                                    • cheddaC Offline
                                      chedda
                                      Great object,great model and a great render. Very Dieter Rams.
                                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                      • massimoM Offline
                                        massimo Moderator
                                        Thanks chedda. πŸ˜„
                                        Very Dieter Rams
                                        Indeed. Was designed in 1964 by Marco Zanuso + Richard Sapper as you probably already know.πŸ˜‰
                                        • hellnbakH Offline
                                          hellnbak
                                          Well, it's not a classic car, but it is a classic, and incredibly well done πŸ‘
                                          • massimoM Offline
                                            massimo Moderator
                                            Thank you Steve. πŸ˜„
                                            • 2 / 3
