    Brionvega radio Ts522
    42 Posts 19 Posters 2.5k Views 19 Watching
    • olisheaO Offline
      olishea
      Oh no its 15th....I dunno I may do it, it just means I'll have to eat beans on toast til Xmas (cheap food to us brits!) I'm so tempted....I should just go and not tell my family. Just leave a note on my bed, "Gone to Colorado to see the lads" ๐Ÿ˜† It all depends if I can afford it but would love to go. Hmmmm flights...manchester>colorado!
      edit: christ looks like it's over a grand just for the flights, don't think I can do it. ๐Ÿ˜ข
      oli
      • massimoM Offline
        massimo Moderator
        wait....how did you get the smears/fingerprints on metal?!!! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
        Maybe this could help? ๐Ÿ˜„
        • FrederikF Offline
          Frederik
          Massimo - you must be from a different planet... ๐Ÿ˜„
          Like others already have said these renders are outstanding... ๐Ÿ‘
          Cheers
          Kim Frederik
          • massimoM Offline
            massimo Moderator
            ๐Ÿ˜„ Thank you Kim.
            • olisheaO Offline
              olishea
              massimo thanks for the screenie....looks great, did you already map the texture in SU? or scale in Thea?
              Very convincing and a fantastic model ๐Ÿ‘
              oli
              • massimoM Offline
                massimo Moderator
                All done in Thea, projection & scale.
                care to explain black material on face of radio?
                Sorry missed this one. Here you have a screenshot of the black mat. The map in the reflectance & roughness slots is the same (used some grungy greyscale texture), just more contrast directly in Thea for the roughness's one. The bump map is a noise texture.๐Ÿ˜„
                  Thanks for sharing the settings. ๐Ÿ‘
                  • marked001M Offline
                    marked001
                    I really need some lessons in creating materials.. can someone arrange that? ๐Ÿ˜„ amazing stuff, as usual.
                    http://www.revision21vis.com
                    instagram: revi21on
                    • olisheaO Offline
                      olishea
                      ah it was adding the texture to roughness slot that was throwing me off! Nice work!
                      Is roughness without texture essentially a noise map?
                      oli
                      • beginnerB Offline
                        beginner
                        massimo,
                        The model looks great...
                        The metal and paint are even better ๐Ÿ‘
                        Regards, SU 'beginner'
                        • massimoM Offline
                          massimo Moderator
                          Thanks again guys. ๐Ÿ˜„
                          Well basically roughness is related to the fuzziness of the specular reflectance & transmittance. A value of "0" is a perfect mirror, by increasing the value you'll reach a diffuse-like look. Also if you use a map the white parts are rough and blacks are shining.
                          • StinkieS Offline
                            Stinkie
                            Fantastic. ๐Ÿ‘ I'd love to take a look at that plastic material. It looks great, especially in the second pic.
                            • olisheaO Offline
                              olishea
                              That's what i was looking for, cheers. I love the roughness feature.
                              oli
                              • massimoM Offline
                                massimo Moderator
                                Thanks Gregory and Tom. ๐Ÿ˜„
                                Playing a bit with Magic bullet photolooks. An amazing tool. ๐Ÿ‘
                                • GarethG Offline
                                  Gareth
                                  Massimo,
                                  i once said i'd never speak to you ever again if you kept posting such amazing work....
                                  ....i lied....!! ๐Ÿ˜†
                                  ๐Ÿ‘
                                  • massimoM Offline
                                    massimo Moderator
                                    ๐Ÿ˜†
                                    • StinkieS Offline
                                      Stinkie
                                      I like it. ๐Ÿ‘
                                      • jo-keJ Offline
                                        jo-ke
                                        Wow ๐Ÿ˜ฒ
                                        absolutely great work!! ๐Ÿ‘
                                        http://www.zz7.de
                                        • massimoM Offline
                                          massimo Moderator
                                          • cheddaC Offline
                                            chedda
                                            Great object,great model and a great render. Very Dieter Rams.
                                            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                            • 2 / 3
