    Brionvega radio Ts522
    42 Posts 19 Posters 2.5k Views 19 Watching
    • alvisA Offline
      alvis
      Master ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
      • massimoM Offline
        massimo Moderator
        Thanks Alvydas. ๐Ÿ˜„
        • olisheaO Offline
          olishea
          nicely done, care to explain black material on face of radio?
          wait....how did you get the smears/fingerprints on metal?!!! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
          oli
          • soloS Offline
            Oli, coming to base-camp? if yes I will show you a Thea trick, easy way to do dirt and smudges
            • olisheaO Offline
              olishea
              Oh no its 15th....I dunno I may do it, it just means I'll have to eat beans on toast til Xmas (cheap food to us brits!) I'm so tempted....I should just go and not tell my family. Just leave a note on my bed, "Gone to Colorado to see the lads" ๐Ÿ˜† It all depends if I can afford it but would love to go. Hmmmm flights...manchester>colorado!
              edit: christ looks like it's over a grand just for the flights, don't think I can do it. ๐Ÿ˜ข
              oli
              • massimoM Offline
                massimo Moderator
                Maybe this could help? ๐Ÿ˜„
                • FrederikF Offline
                  Frederik
                  Massimo - you must be from a different planet... ๐Ÿ˜„
                  Like others already have said these renders are outstanding... ๐Ÿ‘
                  Cheers
                  Kim Frederik
                  • massimoM Offline
                    massimo Moderator
                    ๐Ÿ˜„ Thank you Kim.
                    • olisheaO Offline
                      olishea
                      massimo thanks for the screenie....looks great, did you already map the texture in SU? or scale in Thea?
                      Very convincing and a fantastic model ๐Ÿ‘
                      oli
                      • massimoM Offline
                        massimo Moderator
                        All done in Thea, projection & scale.
                        Sorry missed this one. Here you have a screenshot of the black mat. The map in the reflectance & roughness slots is the same (used some grungy greyscale texture), just more contrast directly in Thea for the roughness's one. The bump map is a noise texture.๐Ÿ˜„
                          Thanks for sharing the settings. ๐Ÿ‘
                          • marked001M Offline
                            marked001
                            I really need some lessons in creating materials.. can someone arrange that? ๐Ÿ˜„ amazing stuff, as usual.
                            http://www.revision21vis.com
                            instagram: revi21on
                            • olisheaO Offline
                              olishea
                              ah it was adding the texture to roughness slot that was throwing me off! Nice work!
                              Is roughness without texture essentially a noise map?
                              oli
                              • beginnerB Offline
                                beginner
                                massimo,
                                The model looks great...
                                The metal and paint are even better ๐Ÿ‘
                                Regards, SU 'beginner'
                                • massimoM Offline
                                  massimo Moderator
                                  Thanks again guys. ๐Ÿ˜„
                                  Well basically roughness is related to the fuzziness of the specular reflectance & transmittance. A value of "0" is a perfect mirror, by increasing the value you'll reach a diffuse-like look. Also if you use a map the white parts are rough and blacks are shining.
                                  • StinkieS Offline
                                    Stinkie
                                    Fantastic. ๐Ÿ‘ I'd love to take a look at that plastic material. It looks great, especially in the second pic.
                                    • olisheaO Offline
                                      olishea
                                      That's what i was looking for, cheers. I love the roughness feature.
                                      oli
                                      • massimoM Offline
                                        massimo Moderator
                                        Thanks Gregory and Tom. ๐Ÿ˜„
                                        Playing a bit with Magic bullet photolooks. An amazing tool. ๐Ÿ‘
                                        • GarethG Offline
                                          Gareth
                                          Massimo,
                                          i once said i'd never speak to you ever again if you kept posting such amazing work....
                                          ....i lied....!! ๐Ÿ˜†
                                          ๐Ÿ‘
                                          • massimoM Offline
                                            massimo Moderator
                                            ๐Ÿ˜†
                                            • 2 / 3
