    Brionvega radio Ts522
    42 Posts 19 Posters 2.5k Views 19 Watching
    • olisheaO Offline
      olishea
      massimo thanks for the screenie....looks great, did you already map the texture in SU? or scale in Thea?
      Very convincing and a fantastic model πŸ‘
      oli
      • massimoM Offline
        massimo Moderator
        All done in Thea, projection & scale.
        care to explain black material on face of radio?
        Sorry missed this one. Here you have a screenshot of the black mat. The map in the reflectance & roughness slots is the same (used some grungy greyscale texture), just more contrast directly in Thea for the roughness's one. The bump map is a noise texture.πŸ˜„
          Thanks for sharing the settings. πŸ‘
          • marked001M Offline
            marked001
            I really need some lessons in creating materials.. can someone arrange that? πŸ˜„ amazing stuff, as usual.
            http://www.revision21vis.com
            instagram: revi21on
            • olisheaO Offline
              olishea
              ah it was adding the texture to roughness slot that was throwing me off! Nice work!
              Is roughness without texture essentially a noise map?
              oli
              • beginnerB Offline
                beginner
                massimo,
                The model looks great...
                The metal and paint are even better πŸ‘
                Regards, SU 'beginner'
                • massimoM Offline
                  massimo Moderator
                  Thanks again guys. πŸ˜„
                  Well basically roughness is related to the fuzziness of the specular reflectance & transmittance. A value of "0" is a perfect mirror, by increasing the value you'll reach a diffuse-like look. Also if you use a map the white parts are rough and blacks are shining.
                  • StinkieS Offline
                    Stinkie
                    Fantastic. πŸ‘ I'd love to take a look at that plastic material. It looks great, especially in the second pic.
                    • olisheaO Offline
                      olishea
                      That's what i was looking for, cheers. I love the roughness feature.
                      oli
                      • massimoM Offline
                        massimo Moderator
                        Thanks Gregory and Tom. πŸ˜„
                        Playing a bit with Magic bullet photolooks. An amazing tool. πŸ‘
                        • GarethG Offline
                          Gareth
                          Massimo,
                          i once said i'd never speak to you ever again if you kept posting such amazing work....
                          ....i lied....!! πŸ˜†
                          πŸ‘
                          • massimoM Offline
                            massimo Moderator
                            πŸ˜†
                            • StinkieS Offline
                              Stinkie
                              I like it. πŸ‘
                              • jo-keJ Offline
                                jo-ke
                                Wow 😲
                                absolutely great work!! πŸ‘
                                http://www.zz7.de
                                • massimoM Offline
                                  massimo Moderator
                                  • cheddaC Offline
                                    chedda
                                    Great object,great model and a great render. Very Dieter Rams.
                                    Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                    • massimoM Offline
                                      massimo Moderator
                                      Thanks chedda. πŸ˜„
                                      Very Dieter Rams
                                      Indeed. Was designed in 1964 by Marco Zanuso + Richard Sapper as you probably already know.πŸ˜‰
                                      • hellnbakH Offline
                                        hellnbak
                                        Well, it's not a classic car, but it is a classic, and incredibly well done πŸ‘
                                        • massimoM Offline
                                          massimo Moderator
                                          Thank you Steve. πŸ˜„
                                            SketchyJon
                                            Very nice! Great attention to detail.
                                            • 2 / 3
