    Brionvega radio Ts522
    42 Posts 19 Posters 3.2k Views 19 Watching
    • massimoM Offline
      massimo Moderator
      All done in Thea, projection & scale.
      care to explain black material on face of radio?
      Sorry missed this one. Here you have a screenshot of the black mat. The map in the reflectance & roughness slots is the same (used some grungy greyscale texture), just more contrast directly in Thea for the roughness's one. The bump map is a noise texture.πŸ˜„
        Thanks for sharing the settings. πŸ‘
        • marked001M Offline
          marked001
          I really need some lessons in creating materials.. can someone arrange that? πŸ˜„ amazing stuff, as usual.
          http://www.revision21vis.com
          instagram: revi21on
          • olisheaO Offline
            olishea
            ah it was adding the texture to roughness slot that was throwing me off! Nice work!
            Is roughness without texture essentially a noise map?
            oli
            • beginnerB Offline
              beginner
              massimo,
              The model looks great...
              The metal and paint are even better πŸ‘
              Regards, SU 'beginner'
              • massimoM Offline
                massimo Moderator
                Thanks again guys. πŸ˜„
                Well basically roughness is related to the fuzziness of the specular reflectance & transmittance. A value of "0" is a perfect mirror, by increasing the value you'll reach a diffuse-like look. Also if you use a map the white parts are rough and blacks are shining.
                • StinkieS Offline
                  Stinkie
                  Fantastic. πŸ‘ I'd love to take a look at that plastic material. It looks great, especially in the second pic.
                  • olisheaO Offline
                    olishea
                    That's what i was looking for, cheers. I love the roughness feature.
                    oli
                    • massimoM Offline
                      massimo Moderator
                      Thanks Gregory and Tom. πŸ˜„
                      Playing a bit with Magic bullet photolooks. An amazing tool. πŸ‘
                      • GarethG Offline
                        Gareth
                        Massimo,
                        i once said i'd never speak to you ever again if you kept posting such amazing work....
                        ....i lied....!! πŸ˜†
                        πŸ‘
                        • massimoM Offline
                          massimo Moderator
                          πŸ˜†
                          • StinkieS Offline
                            Stinkie
                            I like it. πŸ‘
                            • jo-keJ Offline
                              jo-ke
                              Wow 😲
                              absolutely great work!! πŸ‘
                              http://www.zz7.de
                              • massimoM Offline
                                massimo Moderator
                                • cheddaC Offline
                                  chedda
                                  Great object,great model and a great render. Very Dieter Rams.
                                  Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                  • massimoM Offline
                                    massimo Moderator
                                    Thanks chedda. πŸ˜„
                                    Very Dieter Rams
                                    Indeed. Was designed in 1964 by Marco Zanuso + Richard Sapper as you probably already know.πŸ˜‰
                                    • hellnbakH Offline
                                      hellnbak
                                      Well, it's not a classic car, but it is a classic, and incredibly well done πŸ‘
                                      • massimoM Offline
                                        massimo Moderator
                                        Thank you Steve. πŸ˜„
                                          SketchyJon
                                          Very nice! Great attention to detail.
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks Jon. πŸ˜„
                                            • 2 / 3
