    Brionvega radio Ts522
    42 Posts 19 Posters 3.2k Views 19 Watching
      the.pjt
      wow ..... very detailed madel and ... and very nice realistic render .. and profesionall HDRI lightening
      awesome
      but how time it toooks to compelete ? .... 1 week ??? 1 year ??
      http://forums.sketchucation.com/viewtopic.php?f=81&t=48015&p=430617#p430617
      • massimoM Offline
        massimo Moderator
        Thanks the.pjt. ๐Ÿ˜„
        It was a couple of hours for each image with TR1 for something like 120-140 passes.
        You must have something wrong there. Lighting & materials look strange. ๐Ÿ˜• All seem shining, a lot of noise. Perhaps some lights intersect the model? Better you post something at Thea's forum. Also the scene or a part of it if possible.
        • alvisA Offline
          alvis
          Master ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
          • massimoM Offline
            massimo Moderator
            Thanks Alvydas. ๐Ÿ˜„
            • olisheaO Offline
              olishea
              nicely done, care to explain black material on face of radio?
              wait....how did you get the smears/fingerprints on metal?!!! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
              oli
              • soloS Offline
                Oli, coming to base-camp? if yes I will show you a Thea trick, easy way to do dirt and smudges
                • olisheaO Offline
                  olishea
                  Oh no its 15th....I dunno I may do it, it just means I'll have to eat beans on toast til Xmas (cheap food to us brits!) I'm so tempted....I should just go and not tell my family. Just leave a note on my bed, "Gone to Colorado to see the lads" ๐Ÿ˜† It all depends if I can afford it but would love to go. Hmmmm flights...manchester>colorado!
                  edit: christ looks like it's over a grand just for the flights, don't think I can do it. ๐Ÿ˜ข
                  oli
                  • massimoM Offline
                    massimo Moderator
                    Maybe this could help? ๐Ÿ˜„
                    • FrederikF Offline
                      Frederik
                      Massimo - you must be from a different planet... ๐Ÿ˜„
                      Like others already have said these renders are outstanding... ๐Ÿ‘
                      Cheers
                      Kim Frederik
                      • massimoM Offline
                        massimo Moderator
                        ๐Ÿ˜„ Thank you Kim.
                        • olisheaO Offline
                          olishea
                          massimo thanks for the screenie....looks great, did you already map the texture in SU? or scale in Thea?
                          Very convincing and a fantastic model ๐Ÿ‘
                          oli
                          • massimoM Offline
                            massimo Moderator
                            All done in Thea, projection & scale.
                            Sorry missed this one. Here you have a screenshot of the black mat. The map in the reflectance & roughness slots is the same (used some grungy greyscale texture), just more contrast directly in Thea for the roughness's one. The bump map is a noise texture.๐Ÿ˜„
                              Thanks for sharing the settings. ๐Ÿ‘
                              • marked001M Offline
                                marked001
                                I really need some lessons in creating materials.. can someone arrange that? ๐Ÿ˜„ amazing stuff, as usual.
                                http://www.revision21vis.com
                                instagram: revi21on
                                • olisheaO Offline
                                  olishea
                                  ah it was adding the texture to roughness slot that was throwing me off! Nice work!
                                  Is roughness without texture essentially a noise map?
                                  oli
                                  • beginnerB Offline
                                    beginner
                                    massimo,
                                    The model looks great...
                                    The metal and paint are even better ๐Ÿ‘
                                    Regards, SU 'beginner'
                                    • massimoM Offline
                                      massimo Moderator
                                      Thanks again guys. ๐Ÿ˜„
                                      Well basically roughness is related to the fuzziness of the specular reflectance & transmittance. A value of "0" is a perfect mirror, by increasing the value you'll reach a diffuse-like look. Also if you use a map the white parts are rough and blacks are shining.
                                      • StinkieS Offline
                                        Stinkie
                                        Fantastic. ๐Ÿ‘ I'd love to take a look at that plastic material. It looks great, especially in the second pic.
                                        • olisheaO Offline
                                          olishea
                                          That's what i was looking for, cheers. I love the roughness feature.
                                          oli
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks Gregory and Tom. ๐Ÿ˜„
                                            Playing a bit with Magic bullet photolooks. An amazing tool. ๐Ÿ‘
                                            • 2 / 3
