    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 262.7k Views 54 Watching
    • TIGT
      @mackbrae said:
      no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
      It says in the earlier post - PLEASE GET/USE THE LATEST VERSION...
      FROM THE PluginStore...
      When it is downloaded, then that is in RBZ format.
      https://sketchucation.com/pluginstore?pln=VoronoiXY
      Dice en la página anterior - POR FAVOR, OBTENGA / UTILICE LA VERSIÓN MÁS RECIENTE...
      DESDE EL PluginStore...
      Cuando se descarga, entonces está en formato RBZ.
      • Y
        yashmishra
        using voronoi is giving me error 'no guide points in selection; although i have guide point in selection
          Post your SKP (save as V6 for a more large audiance)
          and look all my videos or images "page 4"
          • M
            Munene
            How do you download this extension
            • jujuJ
              juju
              Please make some effort before asking questions, the link is on this very same page just 3 posts above yours.
              • P
                phongzenkj
                Nide Plugin! 👍 , thank you.
                • A
                  aymanechi Newcomers
                  i can t launch these extensions in sketchup and i don t know why
                  i tried to convrt theme to a .RBZ format but it didn t work
                  and how can i put them bth in the same extension ?
                    What version of SketchUp are you using? You listed a non-existent version in your forum profile.
                    How did you try to convert them to .rbz files?
                    • J
                      Jaijai22 Newcomers
                      hello where i find the link for plug in I cant see the link, would you mind putting the link down below . thank you
                        Rich O Brien Moderator @Jaijai22
                        @Jaijai22 said in [PLUGIN] Voronoi + Conic Curve:
                        SketchUp Plugins | PluginStore | SketchUcation
                        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                        (sketchucation.com)
                        Or install directly in SketchUp using Sketchucation Tools
                        N 1 Reply Last reply
                        • N
                          neapandele @Rich O Brien
                          If anyone is using SketchUp 2024 and Voronoi plugin stops working, then delauney3.rb file must be edited and any occurence of "TRUE" and "FALSE" should be replaced with "true" and "false". Like in this example:
                          triang[0] = [p1 - 1, p2 - 1, p3 - 1]
                          complete[0] = FALSE
                          ntri = 1
                          should become
                          complete[0] = false
                          ntri = 1
                          Cheers!
                          M R K 3 Replies Last reply 👍
                          Reply Quote 2
                          • M
                            Michelle_20002307 @neapandele
                            @neapandele I did this but it doesn't work anyway
                            • R
                              rv1974 @neapandele
                              @neapandele worked, thank you so much!
                              p.s. one of the buggiest plugins ever.
                              • K
                                komzone @neapandele
                                @neapandele Thank you!
                                The instruction works
                                • G
                                  group of designer Newcomers
                                  how to downlode these plugins.
                                    Rich O Brien Moderator @group of designer
                                    @group-of-designer Install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                                    • H
                                      hshieds1 Newcomers
                                      do you know if this plug in will work on 2026 version as im struggling to get it to work
                                      R 1 Reply Last reply
                                      • R
                                        rv1974 @hshieds1
                                        @hshieds1 its unusable due to constant crashes anyway, get fredo spline instead
                                        • TIGT
                                          @hshieds1
                                          Have you tried the simple edit for the delauney3.rb script [which it needs] to make it suitable for the newer versions of SketchUp's Ruby ?
                                          It is explained a few posts above this - https://community.sketchucation.com/topic/136273/plugin-voronoi-conic-curve/131
                                          • C
                                            Claire Creeke Newcomers
                                            thankyou this worked for me 🙂
                                            • 6
                                            • 7
                                            • 7 / 7
