    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 256.1k Views 54 Watching
    • jujuJ Offline
      juju
      @munene said:
      How do you download this extension
      Please make some effort before asking questions, the link is on this very same page just 3 posts above yours.
        phongzenkj
        Nide Plugin! πŸ‘ , thank you.
          aymanechi Newcomers
          i can t launch these extensions in sketchup and i don t know why
          i tried to convrt theme to a .RBZ format but it didn t work
          and how can i put them bth in the same extension ?
            What version of SketchUp are you using? You listed a non-existent version in your forum profile.
            How did you try to convert them to .rbz files?
              Jaijai22 Newcomers
              hello where i find the link for plug in I cant see the link, would you mind putting the link down below . thank you
                Rich O Brien Moderator @Jaijai22
                @Jaijai22 said in [PLUGIN] Voronoi + Conic Curve:
                SketchUp Plugins | PluginStore | SketchUcation
                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                (sketchucation.com)
                Or install directly in SketchUp using Sketchucation Tools
                N 1 Reply Last reply Reply Quote 0
                • N Offline
                  neapandele @Rich O Brien
                  If anyone is using SketchUp 2024 and Voronoi plugin stops working, then delauney3.rb file must be edited and any occurence of "TRUE" and "FALSE" should be replaced with "true" and "false". Like in this example:
                  triang[0] = [p1 - 1, p2 - 1, p3 - 1]
                  complete[0] = FALSE
                  ntri = 1
                  should become
                  complete[0] = false
                  ntri = 1
                  Cheers!
                  M R K 3 Replies Last reply πŸ‘ Reply Quote 2
                    Michelle_20002307 @neapandele
                    @neapandele I did this but it doesn't work anyway
                      rv1974 @neapandele
                      @neapandele worked, thank you so much!
                      p.s. one of the buggiest plugins ever.
                        komzone @neapandele
                        @neapandele Thank you!
                        The instruction works
                          group of designer Newcomers
                          how to downlode these plugins.
                            Rich O Brien Moderator @group of designer
                            @group-of-designer Install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                            • H Offline
                              hshieds1 Newcomers
                              do you know if this plug in will work on 2026 version as im struggling to get it to work
                              R 1 Reply Last reply Reply Quote 0
                                rv1974 @hshieds1
                                @hshieds1 its unusable due to constant crashes anyway, get fredo spline instead
                                  @hshieds1
                                  Have you tried the simple edit for the delauney3.rb script [which it needs] to make it suitable for the newer versions of SketchUp's Ruby ?
                                  It is explained a few posts above this - https://community.sketchucation.com/topic/136273/plugin-voronoi-conic-curve/131
                                    Claire Creeke Newcomers
                                    thankyou this worked for me πŸ™‚
                                    • 7 / 7
