    [PLUGIN] Voronoi + Conic Curve
    138 Posts 54 Posters 236.3k Views 53 Watching
      mackbrae
      no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
        It says in the earlier post - PLEASE GET/USE THE LATEST VERSION...
        FROM THE PluginStore...
        When it is downloaded, then that is in RBZ format.
        https://sketchucation.com/pluginstore?pln=VoronoiXY
        Dice en la página anterior - POR FAVOR, OBTENGA / UTILICE LA VERSIÓN MÁS RECIENTE...
        DESDE EL PluginStore...
        Cuando se descarga, entonces está en formato RBZ.
        • Y Offline
          yashmishra
          using voronoi is giving me error 'no guide points in selection; although i have guide point in selection
            Post your SKP (save as V6 for a more large audiance)
            and look all my videos or images "page 4"
              Munene
              How do you download this extension
              • jujuJ Offline
                juju
                Please make some effort before asking questions, the link is on this very same page just 3 posts above yours.
                  phongzenkj
                  Nide Plugin! 👍 , thank you.
                    aymanechi Newcomers
                    i can t launch these extensions in sketchup and i don t know why
                    i tried to convrt theme to a .RBZ format but it didn t work
                    and how can i put them bth in the same extension ?
                      What version of SketchUp are you using? You listed a non-existent version in your forum profile.
                      How did you try to convert them to .rbz files?
                        Jaijai22 Newcomers
                        hello where i find the link for plug in I cant see the link, would you mind putting the link down below . thank you
                          Rich O Brien Moderator @Jaijai22
                          @Jaijai22 said in [PLUGIN] Voronoi + Conic Curve:
                          SketchUp Plugins | PluginStore | SketchUcation
                          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                          (sketchucation.com)
                          Or install directly in SketchUp using Sketchucation Tools
                          N 1 Reply Last reply Reply Quote 0
                          • N Offline
                            neapandele @Rich O Brien
                            If anyone is using SketchUp 2024 and Voronoi plugin stops working, then delauney3.rb file must be edited and any occurence of "TRUE" and "FALSE" should be replaced with "true" and "false". Like in this example:
                            triang[0] = [p1 - 1, p2 - 1, p3 - 1]
                            complete[0] = FALSE
                            ntri = 1
                            should become
                            complete[0] = false
                            ntri = 1
                            Cheers!
                            M R K 3 Replies Last reply 👍 Reply Quote 2
                              Michelle_20002307 @neapandele
                              @neapandele I did this but it doesn't work anyway
                                rv1974 @neapandele
                                @neapandele worked, thank you so much!
                                p.s. one of the buggiest plugins ever.
                                  komzone @neapandele
                                  @neapandele Thank you!
                                  The instruction works
                                    group of designer Newcomers
                                    how to downlode these plugins.
                                      Rich O Brien Moderator @group of designer
                                      @group-of-designer Install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                                      • H Offline
                                        hshieds1 Newcomers
                                        do you know if this plug in will work on 2026 version as im struggling to get it to work
                                        R 1 Reply Last reply Reply Quote 0
                                          rv1974 @hshieds1
                                          @hshieds1 its unusable due to constant crashes anyway, get fredo spline instead
                                          • 7 / 7
