    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 257.9k Views 54 Watching
      Jaijai22 Newcomers
      hello where i find the link for plug in I cant see the link, would you mind putting the link down below . thank you
        Rich O Brien Moderator @Jaijai22
        @Jaijai22 said in [PLUGIN] Voronoi + Conic Curve:
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        Or install directly in SketchUp using Sketchucation Tools
        N 1 Reply Last reply
        • N
          neapandele @Rich O Brien
          If anyone is using SketchUp 2024 and Voronoi plugin stops working, then delauney3.rb file must be edited and any occurence of "TRUE" and "FALSE" should be replaced with "true" and "false". Like in this example:
          triang[0] = [p1 - 1, p2 - 1, p3 - 1]
          complete[0] = FALSE
          ntri = 1
          should become
          complete[0] = false
          ntri = 1
          Cheers!
          M R K 3 Replies Last reply πŸ‘
          Reply Quote 2
            Michelle_20002307 @neapandele
            @neapandele I did this but it doesn't work anyway
              rv1974 @neapandele
              @neapandele worked, thank you so much!
              p.s. one of the buggiest plugins ever.
              • K
                komzone @neapandele
                @neapandele Thank you!
                The instruction works
                • G
                  group of designer Newcomers
                  how to downlode these plugins.
                    Rich O Brien Moderator @group of designer
                    @group-of-designer Install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                    • H
                      hshieds1 Newcomers
                      do you know if this plug in will work on 2026 version as im struggling to get it to work
                      R 1 Reply Last reply
                        rv1974 @hshieds1
                        @hshieds1 its unusable due to constant crashes anyway, get fredo spline instead
                          @hshieds1
                          Have you tried the simple edit for the delauney3.rb script [which it needs] to make it suitable for the newer versions of SketchUp's Ruby ?
                          It is explained a few posts above this - https://community.sketchucation.com/topic/136273/plugin-voronoi-conic-curve/131
                          • C
                            Claire Creeke Newcomers
                            thankyou this worked for me πŸ™‚
                            • 7 / 7
