    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 252.0k Views 54 Watching
      maoxx
      nice
        Pawatamit1994
        not getting the download link plss help
          Gábor
          Click the "Download" button at the first post of this topic. On the next page click "Download" near the description of the plugin.
            Or find in by searching the PluginStore...
            The first-post's 'Download' button is a direct link to that entry !
            • HornOxxH Offline
              HornOxx
              Hi All, I am also so dull and can't find your working download (I would like to use this tool on my private Make 2017 and, if possible, on Pro2019). So I´m looking forward to any patient help 😄
              never trust a skinny cook
                Try the Download button in this post:
                https://sketchucation.com/forums/viewtopic.php?p=538039#p538039
                • HornOxxH Offline
                  HornOxx
                  ... thanks again TIG 👍 your Link worked fine 😄
                    mackbrae
                    no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
                      It says in the earlier post - PLEASE GET/USE THE LATEST VERSION...
                      FROM THE PluginStore...
                      When it is downloaded, then that is in RBZ format.
                      https://sketchucation.com/pluginstore?pln=VoronoiXY
                      Dice en la página anterior - POR FAVOR, OBTENGA / UTILICE LA VERSIÓN MÁS RECIENTE...
                      DESDE EL PluginStore...
                      Cuando se descarga, entonces está en formato RBZ.
                      • Y Offline
                        yashmishra
                        using voronoi is giving me error 'no guide points in selection; although i have guide point in selection
                          Post your SKP (save as V6 for a more large audiance)
                          and look all my videos or images "page 4"
                            Munene
                            How do you download this extension
                            • jujuJ Offline
                              juju
                              Please make some effort before asking questions, the link is on this very same page just 3 posts above yours.
                                phongzenkj
                                Nide Plugin! 👍 , thank you.
                                  aymanechi Newcomers
                                  i can t launch these extensions in sketchup and i don t know why
                                  i tried to convrt theme to a .RBZ format but it didn t work
                                  and how can i put them bth in the same extension ?
                                    What version of SketchUp are you using? You listed a non-existent version in your forum profile.
                                    How did you try to convert them to .rbz files?
                                      Jaijai22 Newcomers
                                      hello where i find the link for plug in I cant see the link, would you mind putting the link down below . thank you
                                        Rich O Brien Moderator @Jaijai22
                                        @Jaijai22 said in [PLUGIN] Voronoi + Conic Curve:
                                        Or install directly in SketchUp using Sketchucation Tools
                                        N 1 Reply Last reply Reply Quote 0
                                        • N Offline
                                          neapandele @Rich O Brien
                                          If anyone is using SketchUp 2024 and Voronoi plugin stops working, then delauney3.rb file must be edited and any occurence of "TRUE" and "FALSE" should be replaced with "true" and "false". Like in this example:
                                          triang[0] = [p1 - 1, p2 - 1, p3 - 1]
                                          complete[0] = FALSE
                                          ntri = 1
                                          should become
                                          complete[0] = false
                                          ntri = 1
                                          Cheers!
                                          M R K 3 Replies Last reply 👍 Reply Quote 2
                                            Michelle_20002307 @neapandele
                                            @neapandele I did this but it doesn't work anyway
                                            • 7 / 7
