    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 238.8k Views 54 Watching
      Or find in by searching the PluginStore...
      The first-post's 'Download' button is a direct link to that entry !
      • HornOxxH Offline
        HornOxx
        Hi All, I am also so dull and can't find your working download (I would like to use this tool on my private Make 2017 and, if possible, on Pro2019). So I´m looking forward to any patient help 😄
        never trust a skinny cook
          Try the Download button in this post:
          https://sketchucation.com/forums/viewtopic.php?p=538039#p538039
          • HornOxxH Offline
            HornOxx
            ... thanks again TIG 👍 your Link worked fine 😄
              mackbrae
              no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
                It says in the earlier post - PLEASE GET/USE THE LATEST VERSION...
                FROM THE PluginStore...
                When it is downloaded, then that is in RBZ format.
                https://sketchucation.com/pluginstore?pln=VoronoiXY
                Dice en la página anterior - POR FAVOR, OBTENGA / UTILICE LA VERSIÓN MÁS RECIENTE...
                DESDE EL PluginStore...
                Cuando se descarga, entonces está en formato RBZ.
                • Y Offline
                  yashmishra
                  using voronoi is giving me error 'no guide points in selection; although i have guide point in selection
                    Post your SKP (save as V6 for a more large audiance)
                    and look all my videos or images "page 4"
                      Munene
                      How do you download this extension
                      • jujuJ Offline
                        juju
                        Please make some effort before asking questions, the link is on this very same page just 3 posts above yours.
                          phongzenkj
                          Nide Plugin! 👍 , thank you.
                            aymanechi Newcomers
                            i can t launch these extensions in sketchup and i don t know why
                            i tried to convrt theme to a .RBZ format but it didn t work
                            and how can i put them bth in the same extension ?
                              What version of SketchUp are you using? You listed a non-existent version in your forum profile.
                              How did you try to convert them to .rbz files?
                                Jaijai22 Newcomers
                                hello where i find the link for plug in I cant see the link, would you mind putting the link down below . thank you
                                  Rich O Brien Moderator @Jaijai22
                                  @Jaijai22 said in [PLUGIN] Voronoi + Conic Curve:
                                  SketchUp Plugins | PluginStore | SketchUcation
                                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                  (sketchucation.com)
                                  Or install directly in SketchUp using Sketchucation Tools
                                  N 1 Reply Last reply Reply Quote 0
                                  • N Offline
                                    neapandele @Rich O Brien
                                    If anyone is using SketchUp 2024 and Voronoi plugin stops working, then delauney3.rb file must be edited and any occurence of "TRUE" and "FALSE" should be replaced with "true" and "false". Like in this example:
                                    triang[0] = [p1 - 1, p2 - 1, p3 - 1]
                                    complete[0] = FALSE
                                    ntri = 1
                                    should become
                                    complete[0] = false
                                    ntri = 1
                                    Cheers!
                                    M R K 3 Replies Last reply 👍 Reply Quote 2
                                      Michelle_20002307 @neapandele
                                      @neapandele I did this but it doesn't work anyway
                                        rv1974 @neapandele
                                        @neapandele worked, thank you so much!
                                        p.s. one of the buggiest plugins ever.
                                          komzone @neapandele
                                          @neapandele Thank you!
                                          The instruction works
                                            group of designer Newcomers
                                            how to downlode these plugins.
                                            • 7 / 7
