    Generate face from closed spline object
    20 Posts 8 Posters 2.8k Views 8 Watching
      Shpox
      Hi guys. I'm after a bit of help with an organic spline shape I'm hoping to make into a window. I'm rendering in v-ray so I guess the edges don't really matter if they're triangulated but wondering if there's a tool to do this or an easy way out πŸ˜‰
      • fuzzionF Offline
        fuzzion
        Not sure what you really want but can use TGI3d plugin - mesh and for frame you could use 'tube along path' plugin
        "Only the dead have seen the end of war" - Plato
          Try Fredo's great CurviLoft
          http://forums.sketchucation.com/viewtopic.php?t=28586
          (Because the spline is not planar, is it?)
            Shpox
            Didn't have any luck with curviloft afaik. I've attached the .skp incase you wanted a quick look.
            Window.skp
            • fuzzionF Offline
              fuzzion
              Enjoy your pringle chips πŸ˜‰
              Windowedit.skp
                I see - didn't work for me either.
                I got something by using Sandbox Tools - From Countours. I had to rotate the shape 90 degrees to be parallel with the ground plane though.
                Window2.skp
                  Shpox
                  El Delicouso! 😍 Did you manage this with TIG 3d? Have to save up for that one. I used cleanup on both yours and thom thoms models. Both work but his has less faces so might go with his πŸ˜‰ Will show you how the render turns out πŸ˜„
                  Genuis my man. Have to say, this is one of the best modelling communities I've been too. I've been working in max and it just isn't to same. I cannot get over the time factor and ease for sketchup. Thanks for the support πŸ˜„
                  • brookefoxB Offline
                    brookefox
                    Uh, why does sandbox from contours work here? I tried it myself and it did, but I thought contours were by definition at the same elevation, not warped through Z as this shape is, either vertically or laid flat, where SFC works.
                    ~ Brooke
                      Sandbox from Contours makes a point cloud from all the vertices in the selection and triangulates that. It does not adhere to the edges. You can see that when you feed it contours from a steep terrain and there's few vertices, the generated geometry will often create faces that intersects the contour edges.
                        some other solutions
                        Bezier Splines
                        Ferrari
                        With Ferrari the PushPull Multiple can maybe problematic due the number of triangles!
                        It's more for a no coplanar closed curve! (tensile surface)
                          brookefox
                          Thanks for the explanation. A case where the tool is more capable than the description? Certainly something like yours should be a part of the description, at least for me, if they would like to personalize it.
                          Thanks, Pilou. I will try those also.
                          ~ Brooke
                          • Rich O BrienR Online
                            I think Pilou used Ferrari to skin the loop
                              brookefox
                              Help us out here, Pilou, re: fredo6 BZ. Did you re-draw it or transform it or what? If I convert it to classic I have no option to face it (and I get a slightly different curve). (I know there are two sets of icons; interestingly my Cadfather set does not show a what looks like a facing option (for 'dogbone' or 'tbone') which the standard set has.)
                              For that matter, please help with the ferrari plug as well. I used it once wit the default settings and the curve as drawn and I got something seemingly useless. I undid all the way but the tool was inactive.
                              ~ Brooke
                                brookefox
                                OK, thanks, Rich. I'm hoping he'll wander back here to fill in the gaps.
                                OK, Ferrari, too performs differently on the flat, and seems to have some quirks, but it did do a nice job with default settings on the flat.
                                ~ Brooke
                                • EarthMoverE Offline
                                  EarthMover
                                  Soap Skin & Bubble works perfectly with the orientation as drawn. (Just skin, no bubble) Quick follow me to make the frame and Joint Push Pull to create the pane depth.
                                  Content Creator at Skapeup
                                    brookefox
                                    Neat. Looks good.
                                    "Is it double-paned?" said the horse's ass.
                                    ~ Brooke
                                      So many ways to skin a cat. πŸ˜„
                                        @Brooke
                                        Sorry I had token the F-Spline of Fredo6, draw it and close it before the last click with F9
                                        So Surface is automatically created! 😎
                                        That was for the left drawing πŸ˜„
                                        For the right drawing, I Copy Move only the curve (F-Splined) and calculate the surface with Ferrari! πŸ˜‰
                                        That was very different methods πŸ˜„
                                        But there are again a mystery, how see the hidden lines of the surface of the F-Spline of Fredo6 method 😲
                                        We can see sides by a push pull but the "top" surface ? (Maybe a future DOh ? )
                                        • gillesG Offline
                                          gilles
                                          Isn't it a plane face?
                                            yes πŸ˜„
