    Generate face from closed spline object
    20 Posts 8 Posters 2.7k Views 8 Watching
    • brookefoxB Offline
      brookefox
      Uh, why does sandbox from contours work here? I tried it myself and it did, but I thought contours were by definition at the same elevation, not warped through Z as this shape is, either vertically or laid flat, where SFC works.
      ~ Brooke
        Sandbox from Contours makes a point cloud from all the vertices in the selection and triangulates that. It does not adhere to the edges. You can see that when you feed it contours from a steep terrain and there's few vertices, the generated geometry will often create faces that intersects the contour edges.
          some other solutions
          Bezier Splines
          Ferrari
          With Ferrari the PushPull Multiple can maybe problematic due the number of triangles!
          It's more for a no coplanar closed curve! (tensile surface)
            brookefox
            Thanks for the explanation. A case where the tool is more capable than the description? Certainly something like yours should be a part of the description, at least for me, if they would like to personalize it.
            Thanks, Pilou. I will try those also.
            ~ Brooke
              I think Pilou used Ferrari to skin the loop
                brookefox
                Help us out here, Pilou, re: fredo6 BZ. Did you re-draw it or transform it or what? If I convert it to classic I have no option to face it (and I get a slightly different curve). (I know there are two sets of icons; interestingly my Cadfather set does not show a what looks like a facing option (for 'dogbone' or 'tbone') which the standard set has.)
                For that matter, please help with the ferrari plug as well. I used it once wit the default settings and the curve as drawn and I got something seemingly useless. I undid all the way but the tool was inactive.
                ~ Brooke
                  brookefox
                  OK, thanks, Rich. I'm hoping he'll wander back here to fill in the gaps.
                  OK, Ferrari, too performs differently on the flat, and seems to have some quirks, but it did do a nice job with default settings on the flat.
                  ~ Brooke
                  • EarthMoverE Offline
                    EarthMover
                    Soap Skin & Bubble works perfectly with the orientation as drawn. (Just skin, no bubble) Quick follow me to make the frame and Joint Push Pull to create the pane depth.
                    Content Creator at Skapeup
                      brookefox
                      Neat. Looks good.
                      "Is it double-paned?" said the horse's ass.
                      ~ Brooke
                        So many ways to skin a cat. πŸ˜„
                          @Brooke
                          Sorry I had token the F-Spline of Fredo6, draw it and close it before the last click with F9
                          So Surface is automatically created! 😎
                          That was for the left drawing πŸ˜„
                          For the right drawing, I Copy Move only the curve (F-Splined) and calculate the surface with Ferrari! πŸ˜‰
                          That was very different methods πŸ˜„
                          But there are again a mystery, how see the hidden lines of the surface of the F-Spline of Fredo6 method 😲
                          We can see sides by a push pull but the "top" surface ? (Maybe a future DOh ? )
                          • gillesG Offline
                            gilles
                            Isn't it a plane face?
                              yes πŸ˜„
