    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 85.3k Views 43 Watching
    • E Offline
      Enachi
      For some reason this plugin is not working with my SU v8. I've installed latest version of bst and hos 1.6.1. Even so, when I activate the plugin, then the tool and then I go for the wall, this is simple selected in blue color (not orange as I've seen on tutorial) and doesn't let me to select the circle, that would make the hole.
      Any suggestion?
      Thank you.
        tak2hata
        Any suggestion?
        Thank you.
        Hi,enachi.
        The face and solid must be in same Group or Component or Model.
        It is rule of this plugin.
        If this is not solution for your trouble,Please show ruby console from 'menu' -> 'Window' -> 'Ruby console'
        And work some with this plugin,the error message will show when error is happened.
        or Download the example.skp that Dave R uploaded in this topics.and test it.
        Please reply the result.
        Thanks.
        by TAK2HATA
        • E Offline
          Enachi
          Tnx tak2hata , it is working fine now. My mistake was that I had both of the items, the wall and the circle made as components, not only the wall, in my case.
          • irwanwrI Offline
            irwanwr
            Thanks.
            thank you in advance for this plugin.
            i still didn't get it though.
            say, if i have a window as component and a wall as a group, i can't make a hole on the wall with the shape of the window component?
              Thanks.
              This tool is a general hole punching tool using 'solids' to make holes in forms. If you want a window or door component to punch a hole in wall that has two faces, I suggest that you use a normal 'cutting-component' which will glue onto the front face and cut a hole, then use my context-menu tool 'Hole Punching Tool...' to punch the wall with a matching hole - this also has the advantage that the 'hole' is linked to the component and moves/copies with it etc...
              • irwanwrI Offline
                irwanwr
                where can i find that context-menu tool, sir?
                [edit] never mind, sir. i already found your Hole Punching Tool. thank you very much. ๐Ÿ˜„
                • guanjinG Offline
                  guanjin
                  Great, thank you such a good tool
                  I come from China, is to learn
                    durrroy
                    I could never get it to work
                      Are you asking for help or just making a statement?
                      Since the plugin does work for others, it probably has to do with the way you've installed it. You could post a screen shot of your Plugins folder so someone could help you.
                        Or they way he's using it. Not possible to know until we have further information to what exactly doesn't work.
                        • irwanwrI Offline
                          irwanwr
                          it works for me
                            tak2hata
                            I update this to v1.62.
                            Add new function: Multiple hole punching.
                            Enjoy!
                            Hi,durrroy.
                            And ComponentInstance for hole must have hole option.
                            Thanks.
                            by TAK2HATA
                              cocotier
                              it doesn't work
                                @cocotier said:
                                it doesn't work
                                Sorry but your post goes into the 'most useless' category !
                                Please explain 'how' it doesn't work...
                                Any Error messages ?
                                Doesn't it do what you expect ?
                                If you have the Ruby Console open are there any messages etc etc...
                                Does your PC explode... or what ?
                                Help us to help you ๐Ÿ˜’
                                • simon le bonS Offline
                                  simon le bon
                                  Update in Jan 03,2012
                                  :Add new function,Punching multiple holes.
                                  It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                                  this new enhancement is working very fine ๐Ÿ‘
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
                                  Congratulations dear tak2hata ๐Ÿ‘ ๐Ÿ‘ You've mastered herein a pretty good tool โ˜€
                                  @cocotier
                                  Please remember that
                                  This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
                                  Update in Dec 14 ,2011:
                                  Hole on unoccluded faces group(Tentative)
                                  The group or component walls we want to pierce don't have to be solid anymore ๐Ÿ‘
                                  simon
                                  • irwanwrI Offline
                                    irwanwr
                                    ๐Ÿ‘ the new feature works well for me too. thank you.
                                      boilingsnow
                                      Hi,tak2hata.
                                      Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
                                        jorge2011
                                        excellent and thank you very much.
                                        Two requests for future versions.
                                        You can add a function: projecting faces in a solid?
                                        You can add a function to hole or project a face, in multiple solid?
                                          tak2hata
                                          Hi,I did not change title of topic in Jan 03,2012.I modeified title.
                                          Hi,boilingsnow.
                                          hole of component
                                          The componet for hole must have cut openning option.
                                          Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
                                          Hi,jorge2011.
                                          I will consider your Proposal.
                                          Thanks.
                                          by TAK2HATA
                                          • guanjinG Offline
                                            guanjin
                                            Creating the Component Selection cutting openings, holes can not be achieved? ? ?
                                            • 6
                                            • 7
                                            • 4 / 7
