    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 161.0k Views 95 Watching
      From the web site: "Symmetrical sculpting mode using with user-defined work plane"
      Is this done by creating a component of half the model, copying and mirroring it? I can't seem to find any other way to do it.
      • soloS Offline
        solo
        No, it's more like a cutting plane.
        http://www.solos-art.com
          I wish the tutorials were available.
          Ah. I see. Split it with the Zorro-like tool.
          • soloS Offline
            solo
            See gif by Rich to explain.
              The GIF doesn't display for me. Sorry.
              • mitcorbM Offline
                mitcorb
                Just deployed this plugin last night.
                Highly usable. Very intuitive.
                Wish there was a way to automatically de-select unwanted, or non-compliant faces and keep the selection to proceed with selective smoothing, or subdividing. In my case using Shift/Brush Select does not deselect. Sketchup version 7.1, Dinosaur computer.
                • P Offline
                  publied
                  nice tools. orga(s)nic!
                  hire me@ http://www.publied.it !
                  • massimoM Offline
                    massimo Moderator
                    Just played few minutes...Amazingly fast and really a spectacular set of tools.๐Ÿ˜ฎ ๐Ÿ‘
                    Waiting for the registration key. ๐ŸŽ‰ ๐Ÿ˜„
                    • FrederikF Offline
                      Frederik
                      Can't see the gif... ๐Ÿ˜ž
                      Checking the link I get the message "You are not authorised to download this attachment."
                      I assume it's from a secret part of the SCF... ๐Ÿ’š
                      Cheers
                      Kim Frederik
                        You're damn right but give me ten minutes and I'll sort it out!
                        • unclebimU Offline
                          unclebim
                          I really like the plugin and intend to purchase it. I have tested the texturing which is great but I noticed that when loaded Artisan blocks SketchUp's Texture submenu options - Position, Reset Position, Projected, Edit Texture Image. If I want to use these options, I have to disable Artisan via Preferences dialog and restart SketchUp. Is that ok and am I missing something or is it a bug?
                          Regards
                          Serafim
                            Regards
                            Serafim
                            Sounds like the old menu-grey-out problem.
                            Do you have any Fredo plugins installed? If so, have you updated them all?
                            Do you have a very large number of plugins installed?
                              Texture context-menu is OK with Artisan for me...
                              Are there any other context-menu items missing/grayed-out ?
                              If so this is a known issue from having too many 'commands' loading - there are fixes updates / available, and a script by AlexM to optimize if not eliminate the issue http://forums.sketchucation.com/viewtopic.php?p=252413#p252413
                              • unclebimU Offline
                                unclebim
                                Thank you thomthom and TIG, I have Fredo's plugins and all my plugins are updated. I have indeed too much of them loaded so I shall try to resolve that. I also have some component related items graying out like Explode, which happens with Tgi3D loaded. I have to cleanup the pligins obviously.
                                • G Offline
                                  gulcanocali
                                  Hi unclebim,
                                  Could you please give us more details about the problem you mention when Tgi3D is loaded? You can also write to our Support team from our website.
                                  We have not observed such behaviour ourselves. Could you please uninstall Tgi3D only and see if the problem goes away? We would appreciate your feedback so that we can resolve the issue, if any, quickly.
                                  Gulcan Ocali
                                  Product Manager
                                  http://www.Tgi3D.com
                                  • unclebimU Offline
                                    unclebim
                                    Thank you all, I have managed to get both Artisan and Tgi3D working without graying out context menu items, I have installed the Alex M script that TIG pointed to and deleted two dozens of files from the Plugins folder. So there is no problem with Artisan or Tgi3D.
                                    Regards
                                    Serafim
                                      muddpuddle
                                      Just ordered! ๐Ÿ˜„
                                      Artisan is a great addition to Sketchup.
                                      Thanks!
                                        Lobster
                                        Congratulations on releasing this plugin! I can't imagine how much dedication was required.
                                        Thanks for providing an upgrade for what seems like a totally different kettle of fish, and it is good to get an evaluation period. Six days left and a bit of work to do.....artisan evaluation resize.png
                                        will be signing up as soon as my latest work cheque clears.
                                        Regards
                                        Sam
                                        • Gus RG Offline
                                          Gus R
                                          Dale,
                                          Great plugin and the upgrade price from SDS was very economical.
                                          I have a slight problem though which I hope I can describe. I make a proxy from a group and then copy the component for use in another part of the model. Everything's fine and when I update the proxy with higher iterations the component off to the side updates accordingly. However, when I close SU and then return to the skp and update that same proxy the component shoots off to one side and can sometimes be mirrored or even up or down along the z axis.
                                          Am I doing something wrong and/or has this been touched upon anywhere in Sketchucation?
                                          Anyone else encounter this or has an answer would be appreciated.
                                          Thx.
                                          www.instagram.com/gusrobatto/
                                          www.facebook.com/gusrobatto
                                            museummaker
                                            https://lh6.googleusercontent.com/_Mbz1E6DAT2U/TXvt2xxDMGI/AAAAAAAAFEM/suLDClJQk3I/s912/head-1.jpg
                                            Amazing plug in, my trial is almost over but will definitely buy this one, it is so much fun and really calls up a different level of creativity-- like having SU on steroids.
                                            THANK YOU!
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 14
                                            • 15
                                            • 7 / 15
