    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 161.0k Views 95 Watching
    • ely862meE Offline
      ely862me
      @xrok1 said:
      i have however noticed the vertex tool has quirks, have you noticed this?
      Explode those curves and it should work, also after the operation delete the coplanar lines.
      @reymond said:
      no mail in my spam folder
      No worries things will sort out, u still have 13 days of use 😉 !
      Elisei (sketchupper)
      Come and See EliseiDesign
        krash88
        @whaat said:
        @krash88 said:
        @whaat said:
        @krash88 said:
        Great piece of work, thank you! However, while I can crease whole faces I can't un-crease whole faces. I have to do it one edge at a time. Any thoughts?
        hmmm....works fine for me. I just hold shift and click on the face while using the crease tool....
        I've tried on simple and complex models. Could it be because I'm using 7.1? I'll also try a complete restart also. Either way I'm happy to have the upgrade 😄
        Do you get any error messages in the Ruby Console when you try to uncrease?
        No errors. Ok, it all seems to depend on exactly where the cursor is when I un-crease. If I click on a place on the face that coincides with the smoothed mesh then it doesn't work. Just a quirk of Sketchup I guess. All is fine and thanks for the help!
          Speaker
          Could someone convert those proxies, so I could open them in SU 7 please.
          http://www.youtube.com/user/latvietis1234
          • boofredlayB Offline
            boofredlay
            Here you go.
            Proxie Sample-1_SU6.skp
            comparatif_SU6.zip
              Speaker
              Just got into a problem- my laptop has a few broken arrow keys. That did not bother me before, becuse I don't use them almost never anyway, but how do I adjust the sculpt tools strenght now? 😕 It looks like only the radius is adjustable throught the VCB.
              • W Offline
                Whaat
                @speaker said:
                Actually you can type in 's' to adjust the strength. (eg. 10s) Did I not mention this in the Quick Reference guide? 😳
                • N Offline
                  nektares
                  yay! finally available! i bought it right away! thanks for the discount! now let´s try this amazing plugin!
                    From the web site: "Symmetrical sculpting mode using with user-defined work plane"
                    Is this done by creating a component of half the model, copying and mirroring it? I can't seem to find any other way to do it.
                    • soloS Offline
                      No, it's more like a cutting plane.
                        I wish the tutorials were available.
                        Ah. I see. Split it with the Zorro-like tool.
                        • soloS Offline
                          See gif by Rich to explain.
                            The GIF doesn't display for me. Sorry.
                            • mitcorbM Offline
                              mitcorb
                              Just deployed this plugin last night.
                              Highly usable. Very intuitive.
                              Wish there was a way to automatically de-select unwanted, or non-compliant faces and keep the selection to proceed with selective smoothing, or subdividing. In my case using Shift/Brush Select does not deselect. Sketchup version 7.1, Dinosaur computer.
                                publied
                                nice tools. orga(s)nic!
                                hire me@ http://www.publied.it !
                                • massimoM Offline
                                  massimo Moderator
                                  Just played few minutes...Amazingly fast and really a spectacular set of tools.😮 👍
                                  Waiting for the registration key. 🎉 😄
                                  • FrederikF Offline
                                    Frederik
                                    Can't see the gif... 😞
                                    Checking the link I get the message "You are not authorised to download this attachment."
                                    I assume it's from a secret part of the SCF... 💚
                                    Cheers
                                    Kim Frederik
                                      You're damn right but give me ten minutes and I'll sort it out!
                                      • unclebimU Offline
                                        unclebim
                                        I really like the plugin and intend to purchase it. I have tested the texturing which is great but I noticed that when loaded Artisan blocks SketchUp's Texture submenu options - Position, Reset Position, Projected, Edit Texture Image. If I want to use these options, I have to disable Artisan via Preferences dialog and restart SketchUp. Is that ok and am I missing something or is it a bug?
                                        Regards
                                        Serafim
                                          Regards
                                          Serafim
                                          Sounds like the old menu-grey-out problem.
                                          Do you have any Fredo plugins installed? If so, have you updated them all?
                                          Do you have a very large number of plugins installed?
                                            Texture context-menu is OK with Artisan for me...
                                            Are there any other context-menu items missing/grayed-out ?
                                            If so this is a known issue from having too many 'commands' loading - there are fixes updates / available, and a script by AlexM to optimize if not eliminate the issue http://forums.sketchucation.com/viewtopic.php?p=252413#p252413
                                            • 14
                                            • 15
                                            • 7 / 15
