    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 140.5k Views 95 Watching
    • ely862meE Offline
      ely862me
      Make sure u have checked the spam folder too.
      Elisei (sketchupper)
      Come and See EliseiDesign
        reymond
        no mail in my spam folder 😕
        Sketchup & Vray Trainer
        • ely862meE Offline
          ely862me
          @xrok1 said:
          i have however noticed the vertex tool has quirks, have you noticed this?
          Explode those curves and it should work, also after the operation delete the coplanar lines.
          No worries things will sort out, u still have 13 days of use 😉 !
            krash88
            @whaat said:
            @krash88 said:
            @whaat said:
            @krash88 said:
            Great piece of work, thank you! However, while I can crease whole faces I can't un-crease whole faces. I have to do it one edge at a time. Any thoughts?
            hmmm....works fine for me. I just hold shift and click on the face while using the crease tool....
            I've tried on simple and complex models. Could it be because I'm using 7.1? I'll also try a complete restart also. Either way I'm happy to have the upgrade 😄
            Do you get any error messages in the Ruby Console when you try to uncrease?
            No errors. Ok, it all seems to depend on exactly where the cursor is when I un-crease. If I click on a place on the face that coincides with the smoothed mesh then it doesn't work. Just a quirk of Sketchup I guess. All is fine and thanks for the help!
              Speaker
              Could someone convert those proxies, so I could open them in SU 7 please.
              http://www.youtube.com/user/latvietis1234
              • boofredlayB Offline
                boofredlay
                Here you go.
                Proxie Sample-1_SU6.skp
                comparatif_SU6.zip
                  Speaker
                  Just got into a problem- my laptop has a few broken arrow keys. That did not bother me before, becuse I don't use them almost never anyway, but how do I adjust the sculpt tools strenght now? 😕 It looks like only the radius is adjustable throught the VCB.
                  • W Offline
                    Whaat
                    @speaker said:
                    Actually you can type in 's' to adjust the strength. (eg. 10s) Did I not mention this in the Quick Reference guide? 😳
                    • N Offline
                      nektares
                      yay! finally available! i bought it right away! thanks for the discount! now let´s try this amazing plugin!
                        From the web site: "Symmetrical sculpting mode using with user-defined work plane"
                        Is this done by creating a component of half the model, copying and mirroring it? I can't seem to find any other way to do it.
                        • soloS Offline
                          No, it's more like a cutting plane.
                            I wish the tutorials were available.
                            Ah. I see. Split it with the Zorro-like tool.
                            • soloS Offline
                              See gif by Rich to explain.
                                The GIF doesn't display for me. Sorry.
                                • mitcorbM Offline
                                  mitcorb
                                  Just deployed this plugin last night.
                                  Highly usable. Very intuitive.
                                  Wish there was a way to automatically de-select unwanted, or non-compliant faces and keep the selection to proceed with selective smoothing, or subdividing. In my case using Shift/Brush Select does not deselect. Sketchup version 7.1, Dinosaur computer.
                                    publied
                                    nice tools. orga(s)nic!
                                    hire me@ http://www.publied.it !
                                    • massimoM Offline
                                      massimo Moderator
                                      Just played few minutes...Amazingly fast and really a spectacular set of tools.😮 👍
                                      Waiting for the registration key. 🎉 😄
                                      • FrederikF Offline
                                        Frederik
                                        Can't see the gif... 😞
                                        Checking the link I get the message "You are not authorised to download this attachment."
                                        I assume it's from a secret part of the SCF... 💚
                                        Cheers
                                        Kim Frederik
                                          You're damn right but give me ten minutes and I'll sort it out!
                                          • unclebimU Offline
                                            unclebim
                                            I really like the plugin and intend to purchase it. I have tested the texturing which is great but I noticed that when loaded Artisan blocks SketchUp's Texture submenu options - Position, Reset Position, Projected, Edit Texture Image. If I want to use these options, I have to disable Artisan via Preferences dialog and restart SketchUp. Is that ok and am I missing something or is it a bug?
                                            Regards
                                            Serafim
                                            • 14
                                            • 15
                                            • 7 / 15
