    New plugin found at ferrari architecture
    50 Posts 20 Posters 48.1k Views 20 Watching
      1. First verify that Google SketchUp is installed on the computer. If not, go to “http://sketchup.google.com”.
      2. Once this archive is extrated:
      • copy the file “FerrariSketch.rb” and the folder “FerrariSketch” in the directory “C:\Program Files\Google\Google SketchUp 7\Plugins” *;
      • copy the folder “FerrariColors” in the directory “C:\Program Files\Google\Google SketchUp 7\Materials” *.
      1. Launch Google SketchUp and open the FerrariSketch tool box by selecting the option “FerrariSketch” in the menu “View -> Tollbars”.
        Other information are available in the program website using the tool box button “Help (?)”.
      • These pathnames depend on the Google SketchUp version (7 or superior) and/or the operating system (XP/Vista/7).
        You must have administrative rights on these folders.
      • david_hD Offline
        david_h
        thank you . ..
        Could you take that a little slower please?
        • dereiD Offline
          derei
          Can anyone post a step-by-step tutorial about how to use this plugin? I tried to use it, but failed. The help button send me to their website's homepage.
          What I did:
          1. selected 4 edges loop (no face inside)
          2. the menu has opened and I input a Inflating Force of 5
            here I get an error in RubyConsole:
          Error; #<FloatDomainError; NaN>
          (eval);286;in `ceil'
          (eval);286;in `create_cartesian_mesh'
          (eval);250;in `create_mesh'
          (eval);887;in `ferrariSketch_menu_select'
          C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;11
          1. selected the edges again and pressed Calculate
            here I get another error:
          Error; #<NoMethodError; undefined method `length' for nil;NilClass>
          (eval);649;in `simulate'
          (eval);1016;in `ferrariSketch_menu_run'
          C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;23
          (eval);286;in `call'
          (eval);286
          1. NOTHING CREATED
          What I do wrong ?
          DESIGNER AND ARTIST DEREI.UK
          • G Offline
            grim
            some pdf tutorials attached
            FeSk demo arch[1].pdf
            FeSk demo conoid[1].pdf
            FeSk demo conoids[1].pdf
            FeSk demo hypar[1].pdf
            • majidM Offline
              majid
              seems interesting, but no way to download the plugin.
              if it is free, so any way to put a direct link here please?
                Try this version...
                404 Not Found
                (forums.sketchucation.com)
                Grim uploaded it here but I'm not sure if this is the latest?
                • majidM Offline
                  majid
                  it seems something is wrong with the attached file... 😕
                  opps it was my fault, once again I unzipped it and now it works 👍
                    Extracted you get 2 folders, FerrariSketch and FerrariColors
                    The plugin is in the FerrariSketch Folder. I didn't install it as I've no use for it but what problem do you have?
                    • dereiD Offline
                      derei
                      PROBLEM SOLVED !! I had a set.rb file in Plugins folder, which is needed for a SVG export plugin. That messed up something in SketchUp. I renamed it and everything went fine.
                      Sorry for putting you on fire.
                      • Alan FraserA Offline
                        Alan Fraser
                        I only just came across this one. Not on this thread, I might add...I just checked to see if it had been mentioned before, as it's not on the index.
                        It's quite a useful script. It's designed as a tensile fabric plugin, but can also be used as a soapskin bubble if you increase the inflation pressure.
                        3D Figures
                          Sure and it has better results in many cases! 🤓 😄
                          • StatlerS Offline
                            Statler
                            Tried to install, followed the instructions, I believe, but it just gives me a long list of errors.
                            Maybe Mr. Filou has any idea what I did wrong? Error text attached.
                            Thank you!
                            errors.txt
                              Object not found!
                              (de.sergeferrari.com)
                              It's a plugin created in 2010 so maybe not able to run on the 2015! 😉
                              Try it with old versions http://help.sketchup.com/en/article/60107
                              • E Offline
                                Einstein
                                I installed Ferrari on SketchUp 2020 and it gets me an error at SketchUp lauchup:
                                Error: #<SyntaxError: c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:335: syntax error, unexpected tINTEGER, expecting ']'
                                g = [Geom::Point3d.new 0, 0, 0]
                                c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:752: invalid multibyte char (UTF-8)
                                c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:879: invalid multibyte char (UTF-8)>
                                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in eval' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in require'
                                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in require'
                                C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in load' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in register_extension'
                                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in `<top (required)>'
                                The Ferrari toolbar appears in the UI but if I select some edge loops to try to create a tensile structure, nothing happens.
                                Can someone help me, please?
                                  As you can deduce from this thread it's an old script, and appears to be incompatible with newer SketchUp versions...
                                  Because it's scrambled [RBS] you cannot get it fixed without the author's input and I think he been inactive for some time...
                                  So I suspect you're out of luck...
                                  BUT there are newer extensions which will probably do what you want ?
                                  e.g. the PluginStore has Fredo's CurviLoft and my ExtensionTools...
                                    You must select a welded closed curve...
                                    if that not works
                                    As it's an old plugin there is not adapted to the new versions!
                                    Load the 2017 Make linked to the previous post...
                                    It's working perfectly! 😄
                                    Else try the Soap Bubble Tensile Structure
                                    • E Offline
                                      Einstein
                                      Yes, I know it's old. Just wanted to give it a chance hoping it would work.
                                      TIG, I use all the plugins you pointed, but Ferrari looks so cool that I'll use the old SketchUp just for it. I think it's worth it.
                                        Install the 2017 make! ☀
                                        • majidM Offline
                                          majid
                                          So there won't be any update?
                                          • E Offline
                                            Einstein
                                            Rather not.
                                            But try contacting the developer, maybe they will help you. And let us know if you find something out:
                                            https://www.sergeferrari.com/
                                            • 2 / 3
