    New plugin found at ferrari architecture
    50 Posts 20 Posters 45.9k Views 20 Watching
    • pep75P Offline
      pep75
      Thank you Grim!!!!!
      • david_hD Offline
        david_h
        I'm confused on installation. Could one of you guys break it down for me? I have the Ferrari Sketch toolbar checked on the list, but it doesnt show up on the screen and I can't find it in either the plugins or tools menues. I must have the file tree set up wrong.
        Thx,
        D
          no special problem 😄
          On the Plugins folder
          an rb file launcher
          a folder with again some files 😄
          • david_hD Offline
            david_h
            okay .. .I guess i'm dumb. I admit that. I tought that is what I had and it's not working. here's my tree
            Plugins>> Ferrarisketch.rb
            Ferrarisketch (folder)
            Buttons Folder
            Ferrarisketch.rbs
            Ferrarisketchmenues
            yes? no?
            Thanks for the help.
            D
            • shuraS Offline
              shura
              Yes.
              But have a FerrariColors folder with lots of Skm inside next to it, what is that good for?
                1. First verify that Google SketchUp is installed on the computer. If not, go to “http://sketchup.google.com”.
                2. Once this archive is extrated:
                • copy the file “FerrariSketch.rb” and the folder “FerrariSketch” in the directory “C:\Program Files\Google\Google SketchUp 7\Plugins” *;
                • copy the folder “FerrariColors” in the directory “C:\Program Files\Google\Google SketchUp 7\Materials” *.
                1. Launch Google SketchUp and open the FerrariSketch tool box by selecting the option “FerrariSketch” in the menu “View -> Tollbars”.
                  Other information are available in the program website using the tool box button “Help (?)”.
                • These pathnames depend on the Google SketchUp version (7 or superior) and/or the operating system (XP/Vista/7).
                  You must have administrative rights on these folders.
                • david_hD Offline
                  david_h
                  thank you . ..
                  Could you take that a little slower please?
                  • dereiD Offline
                    derei
                    Can anyone post a step-by-step tutorial about how to use this plugin? I tried to use it, but failed. The help button send me to their website's homepage.
                    What I did:
                    1. selected 4 edges loop (no face inside)
                    2. the menu has opened and I input a Inflating Force of 5
                      here I get an error in RubyConsole:
                    Error; #<FloatDomainError; NaN>
                    (eval);286;in `ceil'
                    (eval);286;in `create_cartesian_mesh'
                    (eval);250;in `create_mesh'
                    (eval);887;in `ferrariSketch_menu_select'
                    C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;11
                    1. selected the edges again and pressed Calculate
                      here I get another error:
                    Error; #<NoMethodError; undefined method `length' for nil;NilClass>
                    (eval);649;in `simulate'
                    (eval);1016;in `ferrariSketch_menu_run'
                    C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;23
                    (eval);286;in `call'
                    (eval);286
                    1. NOTHING CREATED
                    What I do wrong ?
                    DESIGNER AND ARTIST DEREI.UK
                      grim
                      some pdf tutorials attached
                      FeSk demo arch[1].pdf
                      FeSk demo conoid[1].pdf
                      FeSk demo conoids[1].pdf
                      FeSk demo hypar[1].pdf
                      • majidM Offline
                        majid
                        seems interesting, but no way to download the plugin.
                        if it is free, so any way to put a direct link here please?
                          Try this version...
                          http://forums.sketchucation.com/viewtopic.php?p=286168#p286168
                          Grim uploaded it here but I'm not sure if this is the latest?
                          • majidM Offline
                            majid
                            it seems something is wrong with the attached file... 😕
                            opps it was my fault, once again I unzipped it and now it works 👍
                              Extracted you get 2 folders, FerrariSketch and FerrariColors
                              The plugin is in the FerrariSketch Folder. I didn't install it as I've no use for it but what problem do you have?
                              • dereiD Offline
                                derei
                                PROBLEM SOLVED !! I had a set.rb file in Plugins folder, which is needed for a SVG export plugin. That messed up something in SketchUp. I renamed it and everything went fine.
                                Sorry for putting you on fire.
                                • Alan FraserA Offline
                                  Alan Fraser
                                  I only just came across this one. Not on this thread, I might add...I just checked to see if it had been mentioned before, as it's not on the index.
                                  It's quite a useful script. It's designed as a tensile fabric plugin, but can also be used as a soapskin bubble if you increase the inflation pressure.
                                  3D Figures
                                    Sure and it has better results in many cases! 🤓 😄
                                    • StatlerS Offline
                                      Statler
                                      Tried to install, followed the instructions, I believe, but it just gives me a long list of errors.
                                      Maybe Mr. Filou has any idea what I did wrong? Error text attached.
                                      Thank you!
                                      errors.txt
                                        Object not found!
                                        (de.sergeferrari.com)
                                        It's a plugin created in 2010 so maybe not able to run on the 2015! 😉
                                        Try it with old versions http://help.sketchup.com/en/article/60107
                                        • E Offline
                                          Einstein
                                          I installed Ferrari on SketchUp 2020 and it gets me an error at SketchUp lauchup:
                                          Error: #<SyntaxError: c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:335: syntax error, unexpected tINTEGER, expecting ']'
                                          g = [Geom::Point3d.new 0, 0, 0]
                                          c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:752: invalid multibyte char (UTF-8)
                                          c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:879: invalid multibyte char (UTF-8)>
                                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in eval' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in require'
                                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in require'
                                          C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in load' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in register_extension'
                                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in `<top (required)>'
                                          The Ferrari toolbar appears in the UI but if I select some edge loops to try to create a tensile structure, nothing happens.
                                          Can someone help me, please?
                                            As you can deduce from this thread it's an old script, and appears to be incompatible with newer SketchUp versions...
                                            Because it's scrambled [RBS] you cannot get it fixed without the author's input and I think he been inactive for some time...
                                            So I suspect you're out of luck...
                                            BUT there are newer extensions which will probably do what you want ?
                                            e.g. the PluginStore has Fredo's CurviLoft and my ExtensionTools...
                                            • 2 / 3
