    New plugin found at ferrari architecture
    50 Posts 20 Posters 46.9k Views 20 Watching
    • david_hD Offline
      david_h
      I'm confused on installation. Could one of you guys break it down for me? I have the Ferrari Sketch toolbar checked on the list, but it doesnt show up on the screen and I can't find it in either the plugins or tools menues. I must have the file tree set up wrong.
      Thx,
      D
        no special problem 😄
        On the Plugins folder
        an rb file launcher
        a folder with again some files 😄
        • david_hD Offline
          david_h
          okay .. .I guess i'm dumb. I admit that. I tought that is what I had and it's not working. here's my tree
          Plugins>> Ferrarisketch.rb
          Ferrarisketch (folder)
          Buttons Folder
          Ferrarisketch.rbs
          Ferrarisketchmenues
          yes? no?
          Thanks for the help.
          D
          • shuraS Offline
            shura
            Yes.
            But have a FerrariColors folder with lots of Skm inside next to it, what is that good for?
              1. First verify that Google SketchUp is installed on the computer. If not, go to “http://sketchup.google.com”.
              2. Once this archive is extrated:
              • copy the file “FerrariSketch.rb” and the folder “FerrariSketch” in the directory “C:\Program Files\Google\Google SketchUp 7\Plugins” *;
              • copy the folder “FerrariColors” in the directory “C:\Program Files\Google\Google SketchUp 7\Materials” *.
              1. Launch Google SketchUp and open the FerrariSketch tool box by selecting the option “FerrariSketch” in the menu “View -> Tollbars”.
                Other information are available in the program website using the tool box button “Help (?)”.
              • These pathnames depend on the Google SketchUp version (7 or superior) and/or the operating system (XP/Vista/7).
                You must have administrative rights on these folders.
              • david_hD Offline
                david_h
                thank you . ..
                Could you take that a little slower please?
                • dereiD Offline
                  derei
                  Can anyone post a step-by-step tutorial about how to use this plugin? I tried to use it, but failed. The help button send me to their website's homepage.
                  What I did:
                  1. selected 4 edges loop (no face inside)
                  2. the menu has opened and I input a Inflating Force of 5
                    here I get an error in RubyConsole:
                  Error; #<FloatDomainError; NaN>
                  (eval);286;in `ceil'
                  (eval);286;in `create_cartesian_mesh'
                  (eval);250;in `create_mesh'
                  (eval);887;in `ferrariSketch_menu_select'
                  C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;11
                  1. selected the edges again and pressed Calculate
                    here I get another error:
                  Error; #<NoMethodError; undefined method `length' for nil;NilClass>
                  (eval);649;in `simulate'
                  (eval);1016;in `ferrariSketch_menu_run'
                  C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;23
                  (eval);286;in `call'
                  (eval);286
                  1. NOTHING CREATED
                  What I do wrong ?
                  DESIGNER AND ARTIST DEREI.UK
                    grim
                    some pdf tutorials attached
                    FeSk demo arch[1].pdf
                    FeSk demo conoid[1].pdf
                    FeSk demo conoids[1].pdf
                    FeSk demo hypar[1].pdf
                    • majidM Offline
                      majid
                      seems interesting, but no way to download the plugin.
                      if it is free, so any way to put a direct link here please?
                        Try this version...
                        http://forums.sketchucation.com/viewtopic.php?p=286168#p286168
                        Grim uploaded it here but I'm not sure if this is the latest?
                        • majidM Offline
                          majid
                          it seems something is wrong with the attached file... 😕
                          opps it was my fault, once again I unzipped it and now it works 👍
                            Extracted you get 2 folders, FerrariSketch and FerrariColors
                            The plugin is in the FerrariSketch Folder. I didn't install it as I've no use for it but what problem do you have?
                            • dereiD Offline
                              derei
                              PROBLEM SOLVED !! I had a set.rb file in Plugins folder, which is needed for a SVG export plugin. That messed up something in SketchUp. I renamed it and everything went fine.
                              Sorry for putting you on fire.
                              • Alan FraserA Offline
                                Alan Fraser
                                I only just came across this one. Not on this thread, I might add...I just checked to see if it had been mentioned before, as it's not on the index.
                                It's quite a useful script. It's designed as a tensile fabric plugin, but can also be used as a soapskin bubble if you increase the inflation pressure.
                                3D Figures
                                  Sure and it has better results in many cases! 🤓 😄
                                  • StatlerS Offline
                                    Statler
                                    Tried to install, followed the instructions, I believe, but it just gives me a long list of errors.
                                    Maybe Mr. Filou has any idea what I did wrong? Error text attached.
                                    Thank you!
                                    errors.txt
                                      Object not found!
                                      (de.sergeferrari.com)
                                      It's a plugin created in 2010 so maybe not able to run on the 2015! 😉
                                      Try it with old versions http://help.sketchup.com/en/article/60107
                                      • E Offline
                                        Einstein
                                        I installed Ferrari on SketchUp 2020 and it gets me an error at SketchUp lauchup:
                                        Error: #<SyntaxError: c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:335: syntax error, unexpected tINTEGER, expecting ']'
                                        g = [Geom::Point3d.new 0, 0, 0]
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:752: invalid multibyte char (UTF-8)
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:879: invalid multibyte char (UTF-8)>
                                        C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in eval' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in require'
                                        C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in require'
                                        C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in load' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in register_extension'
                                        C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in `<top (required)>'
                                        The Ferrari toolbar appears in the UI but if I select some edge loops to try to create a tensile structure, nothing happens.
                                        Can someone help me, please?
                                          As you can deduce from this thread it's an old script, and appears to be incompatible with newer SketchUp versions...
                                          Because it's scrambled [RBS] you cannot get it fixed without the author's input and I think he been inactive for some time...
                                          So I suspect you're out of luck...
                                          BUT there are newer extensions which will probably do what you want ?
                                          e.g. the PluginStore has Fredo's CurviLoft and my ExtensionTools...
                                            You must select a welded closed curve...
                                            if that not works
                                            As it's an old plugin there is not adapted to the new versions!
                                            Load the 2017 Make linked to the previous post...
                                            It's working perfectly! 😄
                                            Else try the Soap Bubble Tensile Structure
                                            • 2 / 3
