    New plugin found at ferrari architecture
    50 Posts 20 Posters 46.9k Views 20 Watching
      Ferrari is more versatile than Soap 😉
        Khai
        unstable ain't it?
        it's crashed SU7 twice now.. no bugsplat but a full on "not responding"
        • pep75P Offline
          pep75
          Thank you Grim!!!!!
          • david_hD Offline
            david_h
            I'm confused on installation. Could one of you guys break it down for me? I have the Ferrari Sketch toolbar checked on the list, but it doesnt show up on the screen and I can't find it in either the plugins or tools menues. I must have the file tree set up wrong.
            Thx,
            D
              no special problem 😄
              On the Plugins folder
              an rb file launcher
              a folder with again some files 😄
              • david_hD Offline
                david_h
                okay .. .I guess i'm dumb. I admit that. I tought that is what I had and it's not working. here's my tree
                Plugins>> Ferrarisketch.rb
                Ferrarisketch (folder)
                Buttons Folder
                Ferrarisketch.rbs
                Ferrarisketchmenues
                yes? no?
                Thanks for the help.
                D
                • shuraS Offline
                  shura
                  Yes.
                  But have a FerrariColors folder with lots of Skm inside next to it, what is that good for?
                    1. First verify that Google SketchUp is installed on the computer. If not, go to “http://sketchup.google.com”.
                    2. Once this archive is extrated:
                    • copy the file “FerrariSketch.rb” and the folder “FerrariSketch” in the directory “C:\Program Files\Google\Google SketchUp 7\Plugins” *;
                    • copy the folder “FerrariColors” in the directory “C:\Program Files\Google\Google SketchUp 7\Materials” *.
                    1. Launch Google SketchUp and open the FerrariSketch tool box by selecting the option “FerrariSketch” in the menu “View -> Tollbars”.
                      Other information are available in the program website using the tool box button “Help (?)”.
                    • These pathnames depend on the Google SketchUp version (7 or superior) and/or the operating system (XP/Vista/7).
                      You must have administrative rights on these folders.
                    • david_hD Offline
                      david_h
                      thank you . ..
                      Could you take that a little slower please?
                      • dereiD Offline
                        derei
                        Can anyone post a step-by-step tutorial about how to use this plugin? I tried to use it, but failed. The help button send me to their website's homepage.
                        What I did:
                        1. selected 4 edges loop (no face inside)
                        2. the menu has opened and I input a Inflating Force of 5
                          here I get an error in RubyConsole:
                        Error; #<FloatDomainError; NaN>
                        (eval);286;in `ceil'
                        (eval);286;in `create_cartesian_mesh'
                        (eval);250;in `create_mesh'
                        (eval);887;in `ferrariSketch_menu_select'
                        C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;11
                        1. selected the edges again and pressed Calculate
                          here I get another error:
                        Error; #<NoMethodError; undefined method `length' for nil;NilClass>
                        (eval);649;in `simulate'
                        (eval);1016;in `ferrariSketch_menu_run'
                        C;/PROGRA~2/Google/GOOGLE~2/Plugins/FerrariSketch/FerrariSketchmenus.rb;23
                        (eval);286;in `call'
                        (eval);286
                        1. NOTHING CREATED
                        What I do wrong ?
                        DESIGNER AND ARTIST DEREI.UK
                          grim
                          some pdf tutorials attached
                          FeSk demo arch[1].pdf
                          FeSk demo conoid[1].pdf
                          FeSk demo conoids[1].pdf
                          FeSk demo hypar[1].pdf
                          • majidM Offline
                            majid
                            seems interesting, but no way to download the plugin.
                            if it is free, so any way to put a direct link here please?
                              Try this version...
                              http://forums.sketchucation.com/viewtopic.php?p=286168#p286168
                              Grim uploaded it here but I'm not sure if this is the latest?
                              • majidM Offline
                                majid
                                it seems something is wrong with the attached file... 😕
                                opps it was my fault, once again I unzipped it and now it works 👍
                                  Extracted you get 2 folders, FerrariSketch and FerrariColors
                                  The plugin is in the FerrariSketch Folder. I didn't install it as I've no use for it but what problem do you have?
                                  • dereiD Offline
                                    derei
                                    PROBLEM SOLVED !! I had a set.rb file in Plugins folder, which is needed for a SVG export plugin. That messed up something in SketchUp. I renamed it and everything went fine.
                                    Sorry for putting you on fire.
                                    • Alan FraserA Offline
                                      Alan Fraser
                                      I only just came across this one. Not on this thread, I might add...I just checked to see if it had been mentioned before, as it's not on the index.
                                      It's quite a useful script. It's designed as a tensile fabric plugin, but can also be used as a soapskin bubble if you increase the inflation pressure.
                                      3D Figures
                                        Sure and it has better results in many cases! 🤓 😄
                                        • StatlerS Offline
                                          Statler
                                          Tried to install, followed the instructions, I believe, but it just gives me a long list of errors.
                                          Maybe Mr. Filou has any idea what I did wrong? Error text attached.
                                          Thank you!
                                          errors.txt
                                            Object not found!
                                            (de.sergeferrari.com)
                                            It's a plugin created in 2010 so maybe not able to run on the 2015! 😉
                                            Try it with old versions http://help.sketchup.com/en/article/60107
                                            • 2 / 3
