    Keyboard Shortcuts
    45 Posts 16 Posters 14.2k Views 16 Watching
    • EarthMoverE
      EarthMover
      So what are everyone's most used keyboard shortcuts that you've created yourself?
      I like to keep a lot of mine on the left side of my keyboard so I can do a lot while the mouse is in the right hand. I also use a lot of Shift+letter shortcuts, since my hand is always on Shift for panning.
      W = Move
      E = Rotate
      R = Scale
      S = FredoScale
      Z = Last Camera Position
      Shift + C = Close Component / Group
      Shift + R = Rectangle Tool
      Alt + R = Rotated Rectangle Tool
      Shift + P = Smart Push Pull
      Alt + A = Adjust Tool (TIG 2D tools)
      Alt + D = Divide Face (Thom's Edge Tools)
      Shift + W = Weld
      Shift + Q = Quad Face Loop
      Shift + Spacebar = Select Curve
      Shift + G = Make Group
      Shift + F = Flip Face Normals
      F2 = Vertex Tools
      F5 = Select Edges by Length
      F6 = Make Faces
      F7 = Arc Centerpoint Finder
      U = Extrude Edge by Vector (TIG)
      These are the main shortcuts I use and have used them so much that I can pretty much select any of those tools with my eyes closed. If you haven't gotten into the habit of using customized shortcuts, then I would start now and make it a habit to practice using them. Once you get it down to muscle memory, your whole modeling process will speed up tremendously.
      Content Creator at Skapeup
        W= Plugins/Weld
        Alt+T= Plugins/Tube Along Path
        Alt+U= Plugins/[JF] Unfold
        Alt+P= Plugins/Purge...
        Alt+G= Edit/Make Component...
        F9= Plugins/[TBD] TimeTrack/Setup
        F10= Plugins/[TBD] TimeTrack/Go
        F11= Plugins/[TBD] TimeTrack/Stop
        F12= Plugins/[TBD] TimeTrack/Total
        Alt+X= Plugins/Xray Selection (toggle)
        E= Edit/Delete Guides
        F2= Edit/Item/Flip Along/Component's Red
        F3== Edit/Item/Flip Along/Component's Green
        F4 Edit/Item/Flip Along/Component's Blue
        Shift+F2= Edit/Item/Flip Along/Red Direction
        Shift+F3= Edit/Item/Flip Along/Green Direction
        Shift+F4= Edit/Item/Flip Along/Blue Direction
        D= Plugins/Get Dimensions
        • Chris FullmerC
          F3 = Ruby Console
          F5 = Web Console
          F4 = I assign to whatever plugin I am working on at the moment
          O = Offset
          F = FollowMe
          H = Hide Rest of Model
          ctrl-H = Hide Similar omponents
          X = explode
          ctrl-F = paste in place (that's an old Illustrator shortcut)
          ctrl-R = Reverse Faces
          Z = zoom window (NOT ZOOM TOOL, WHICH IS (nearly) USELESS)
          V = View Hidden
          All my Plugins I've written
          • GaieusG
            Not too many custom ones actually as getting used to them will make it harder to work on others' machines...
            O = Offset
            F = Follow me
            Ctrl+H = Hide rest of model
            Shift+Ctrl+H = Hide similar
            Shift+Ctrl+S = Save toolbar locations
            Shift+Ctrl+S = Save toolbar locations= Restore toolbar locations
            Shift+Ctrl+V = Paste in place
            V = Launch Vertex edit
            (and here, "inside", I configured all the Move, Rotate etc. tools to do what they would do with native SU as ThomThom programmed it in a way that outside Vertex tools they still behave as native tools)
            • thomthomT
              Ctrl + Shift + V - Place In Place
              Ctrl + H - Hidden Geometry
              Shift + C - Hide Similar Components
              Shift + G - Make Group
              V - Hide Rest of Model
              X - X-Ray mode
              Ctrl + 1 - Select Only Faces
              Ctrl + 2 - Select Only Edges
              Ctrl + 3 - Select Only Groups
              Ctrl + 4 - Select Only Components
              Ctrl + Shift + 1 - Deselect Faces
              Ctrl + Shift + 2 - Deselect Edges
              Ctrl + Shift + 3 - Deselect Groups
              Ctrl + Shift + 4 - Deselect Components
              | - Profile Builder
              N - Probes->Normals (for flipping Normals, and Normal queries)
              Ctrl + D - Purge
              Ctrl + R - Cleanup Local Context
              Ctrl + Shift + W - RotaScale
              F12 - Vertex Tools
              I can't get anything done without shortcuts set up. Drives me mad to use other people's computers. Especially when they have all custom set of shortcuts. (4 to draw rectangle... gaarg!)
              • GaieusG
                • Chris FullmerC
                  I try hard to get used to the default shortcuts.
                  O for orbit, H for Hand, F for offset - those ones drive me nuts though. That is what the mouse is for. No need for shortcuts there. And I use follow me lots more than offset. Anyhow, that is why I always reset those shortcuts
                  I also prefer q for rotate and r for rectangle. But I have finally gotten used to them being the opposite by default.
                  • GaieusG
                    Wait a minute, Chris, Q IS the default for Rotate and R IS the default for Rectangle (or am I misunderstanding something?).
                    • thomthomT
                      If I had enough keys on the keyboard, hands to reach them all and the memory for it I'd use shortcuts for everything. I loathe having to use the toolbar.
                      • Chris FullmerC
                        Hehe, oops. I got it backwards. I used to use R for rotate, and Q was an open key so I assigned it to rectangle (which I rarely use). Obviously I've gotten used to it how it is now, I can't even recall what is what anymore.
                        @Thom +1!
                        I also dislike the right click menu. Its like a toolbar I can't ever find anything on. (I use it to open entitiy info if its not open. I can always rememeber that one is at the top).
                        • thomthomT
                          I do like the context-menu - but I want to be able to choose which items to have there. I've edited meny of the plugins I have to reduce the number of items down to just what I want. It is a very handy place to have semi-frequent command - always at the mouse position. It's the fifth position in Fitt's Law - the one which is the quickest to access.
                          • GaieusG
                            Well, Thom, my "bottleneck" seems to be memory as I still have free keys on my keyboard.
                            πŸ˜†
                            • thomthomT
                              You can send over to me. Not that I have a good brain memory myself - but I think my muscle memory is better. Which is why I can't stand most of the keyboards that are sold these days - they all muck about with the key positions. Logitec, which used to have great keyboards messed up all their layouts. I got a Microsort keyboard ( I wanted a wireless one with mulitmedia keys as well ), but as it turns out, they also mucked about with the keys - not their position, but their size. ESC and the F1-12 buttons. grumble If only Logitech had provided updated drivers for my old keyboard ... and I could fix the connectors for the charger.
                              My kingdom for a decent keyboard!
                              </rant>
                              • TIGT
                                I use most of the 'defaults', plus several of my own.
                                My main changes / additions are...
                                G=make-Group
                                B=make-component [it's Block in ACAD]
                                Alt+B=close-edit
                                D=tapemeasure-tool [Dimension in ACAD]
                                T=Text [as in ACAD]
                                Alt+T=Texture
                                Ctrl+D=Divide
                                H=Hide
                                Shift+H=unHide
                                Ctrl+Alt+H=Hide-rest-of-model-toggle
                                K=locK
                                Shift+K=unlocK
                                R=Rotate [as in ACAD]
                                Alt+R=Rectangle
                                Alt+Shift+R=3pt-Rectangle
                                Shift+R=miRRoR
                                Q=reverse-faces
                                Alt+Q=orient-faces
                                U=Unselect-sll
                                Ctrl+Shift+V=paste-in-place
                                J=weld [Join in ACAD]
                                =delete-all-guides
                                • EarthMoverE
                                  EarthMover
                                  Very cool to see others shortcuts. A few I think I will adapt into my workflow. All seem very logic. This should also be a good thread to give new users a good idea for setting up their own shortcuts.
                                  A few other I use all the time but forgot to add are -
                                  Shift + V - Paste in place
                                  Shift + H - Hide selection
                                  Alt + H = Unhide selection
                                  H = Show hidden geometry.
                                  I think my most invaluable one is changing Z from the zoom tool to View last camera position. This is especially useful in an interior or when getting stuck in a wall. I just tap Z and I'm back where I was.
                                  • thomthomT
                                    I actually like and use the Zoom tool, it provides finer control than the mousewheel when I need it.
                                    • GaieusG
                                      Zooming AND setting the FOV (with the Shift key).
                                        W = Weld
                                        X = Explode
                                        H = Hidden Geometry
                                        O = Offset
                                        F = Follow Me
                                        Shift + G = Group
                                        EEby..... = 1/2/3/4/5/6/7/8/9
                                        CTRL + S = Fredoscale
                                        V = Vertex Tools
                                        Shift + O = Offset on Surface
                                        Shift + L = Line on Surface
                                        Shift + A = Arc on Surface
                                        Shift + C = Circle on Surface
                                        Shift + E = Erase on Surface
                                        • jeff hammondJ
                                          jeff hammond
                                          I use all of the defaults (just became used to them over the years even if some aren't very logical.)
                                          The self assigned ones are:
                                          X - Xray
                                          Shift X - Back edges
                                          W - weld
                                          Shift A- arc:center + 2pts
                                          Shift H- hidden geometry
                                          Shift V - paste in place
                                          Shift B - B spline
                                          U - follow me
                                          J - jpp
                                          Shift S - fredoscale
                                          Shift space - select curve
                                          Shift R - 3pt rectangle
                                          Shift Z - zoom extents
                                          V - protractor
                                          dotdotdot
                                          • jeff hammondJ
                                            jeff hammond
                                            [edit]
                                            I made a [req] a while ago that I still think would be great.
                                            Basically, I'd have a key or two [say #1 & 2] that I could assign to various tools depending on the project at hand.
                                            Maybe I need to use fredostretch a lot for the day. I'd select stretch then maybe shift-1 and 1 would now be assigned to stretch. The next day I might need lathe quite a bit so I select the lathe tool then shift-1 and 1 is now lathe. And so on and so forth.
                                            For some odd reason, it's just too big of an ordeal for me to do this via prefs so I just keep going to the icons. If this hot key idea were possible, I'm pretty sure I'd have shortcuts to lesser used functions much more often. (you know, the functions that you use once a month but when you do use them, you might use them 50 times)
                                            dotdotdot
                                            • 1 / 3
