    Keyboard Shortcuts
    45 Posts 16 Posters 11.3k Views 16 Watching
    • Chris FullmerC Offline
      F3 = Ruby Console
      F5 = Web Console
      F4 = I assign to whatever plugin I am working on at the moment
      O = Offset
      F = FollowMe
      H = Hide Rest of Model
      ctrl-H = Hide Similar omponents
      X = explode
      ctrl-F = paste in place (that's an old Illustrator shortcut)
      ctrl-R = Reverse Faces
      Z = zoom window (NOT ZOOM TOOL, WHICH IS (nearly) USELESS)
      V = View Hidden
        Not too many custom ones actually as getting used to them will make it harder to work on others' machines...
        O = Offset
        F = Follow me
        Ctrl+H = Hide rest of model
        Shift+Ctrl+H = Hide similar
        Shift+Ctrl+S = Save toolbar locations
        Shift+Ctrl+S = Save toolbar locations= Restore toolbar locations
        Shift+Ctrl+V = Paste in place
        V = Launch Vertex edit
        (and here, "inside", I configured all the Move, Rotate etc. tools to do what they would do with native SU as ThomThom programmed it in a way that outside Vertex tools they still behave as native tools)
          Ctrl + Shift + V - Place In Place
          Ctrl + H - Hidden Geometry
          Shift + C - Hide Similar Components
          Shift + G - Make Group
          V - Hide Rest of Model
          X - X-Ray mode
          Ctrl + 1 - Select Only Faces
          Ctrl + 2 - Select Only Edges
          Ctrl + 3 - Select Only Groups
          Ctrl + 4 - Select Only Components
          Ctrl + Shift + 1 - Deselect Faces
          Ctrl + Shift + 2 - Deselect Edges
          Ctrl + Shift + 3 - Deselect Groups
          Ctrl + Shift + 4 - Deselect Components
          | - Profile Builder
          N - Probes->Normals (for flipping Normals, and Normal queries)
          Ctrl + D - Purge
          Ctrl + R - Cleanup Local Context
          Ctrl + Shift + W - RotaScale
          F12 - Vertex Tools
          I can't get anything done without shortcuts set up. Drives me mad to use other people's computers. Especially when they have all custom set of shortcuts. (4 to draw rectangle... gaarg!)
              I try hard to get used to the default shortcuts.
              O for orbit, H for Hand, F for offset - those ones drive me nuts though. That is what the mouse is for. No need for shortcuts there. And I use follow me lots more than offset. Anyhow, that is why I always reset those shortcuts
              I also prefer q for rotate and r for rectangle. But I have finally gotten used to them being the opposite by default.
                Wait a minute, Chris, Q IS the default for Rotate and R IS the default for Rectangle (or am I misunderstanding something?).
                  If I had enough keys on the keyboard, hands to reach them all and the memory for it I'd use shortcuts for everything. I loathe having to use the toolbar.
                    Hehe, oops. I got it backwards. I used to use R for rotate, and Q was an open key so I assigned it to rectangle (which I rarely use). Obviously I've gotten used to it how it is now, I can't even recall what is what anymore.
                    @Thom +1!
                    I also dislike the right click menu. Its like a toolbar I can't ever find anything on. (I use it to open entitiy info if its not open. I can always rememeber that one is at the top).
                      I do like the context-menu - but I want to be able to choose which items to have there. I've edited meny of the plugins I have to reduce the number of items down to just what I want. It is a very handy place to have semi-frequent command - always at the mouse position. It's the fifth position in Fitt's Law - the one which is the quickest to access.
                        Well, Thom, my "bottleneck" seems to be memory as I still have free keys on my keyboard.
                          You can send over to me. Not that I have a good brain memory myself - but I think my muscle memory is better. Which is why I can't stand most of the keyboards that are sold these days - they all muck about with the key positions. Logitec, which used to have great keyboards messed up all their layouts. I got a Microsort keyboard ( I wanted a wireless one with mulitmedia keys as well ), but as it turns out, they also mucked about with the keys - not their position, but their size. ESC and the F1-12 buttons. grumble If only Logitech had provided updated drivers for my old keyboard ... and I could fix the connectors for the charger.
                          My kingdom for a decent keyboard!
                          </rant>
                            I use most of the 'defaults', plus several of my own.
                            My main changes / additions are...
                            G=make-Group
                            B=make-component [it's Block in ACAD]
                            Alt+B=close-edit
                            D=tapemeasure-tool [Dimension in ACAD]
                            T=Text [as in ACAD]
                            Alt+T=Texture
                            Ctrl+D=Divide
                            H=Hide
                            Shift+H=unHide
                            Ctrl+Alt+H=Hide-rest-of-model-toggle
                            K=locK
                            Shift+K=unlocK
                            R=Rotate [as in ACAD]
                            Alt+R=Rectangle
                            Alt+Shift+R=3pt-Rectangle
                            Shift+R=miRRoR
                            Q=reverse-faces
                            Alt+Q=orient-faces
                            U=Unselect-sll
                            Ctrl+Shift+V=paste-in-place
                            J=weld [Join in ACAD]
                            =delete-all-guides
                            • EarthMoverE Offline
                              EarthMover
                              Very cool to see others shortcuts. A few I think I will adapt into my workflow. All seem very logic. This should also be a good thread to give new users a good idea for setting up their own shortcuts.
                              A few other I use all the time but forgot to add are -
                              Shift + V - Paste in place
                              Shift + H - Hide selection
                              Alt + H = Unhide selection
                              H = Show hidden geometry.
                              I think my most invaluable one is changing Z from the zoom tool to View last camera position. This is especially useful in an interior or when getting stuck in a wall. I just tap Z and I'm back where I was.
                              Content Creator at Skapeup
                                I actually like and use the Zoom tool, it provides finer control than the mousewheel when I need it.
                                  Zooming AND setting the FOV (with the Shift key).
                                    W = Weld
                                    X = Explode
                                    H = Hidden Geometry
                                    O = Offset
                                    F = Follow Me
                                    Shift + G = Group
                                    EEby..... = 1/2/3/4/5/6/7/8/9
                                    CTRL + S = Fredoscale
                                    V = Vertex Tools
                                    Shift + O = Offset on Surface
                                    Shift + L = Line on Surface
                                    Shift + A = Arc on Surface
                                    Shift + C = Circle on Surface
                                    Shift + E = Erase on Surface
                                    • jeff hammondJ Offline
                                      I use all of the defaults (just became used to them over the years even if some aren't very logical.)
                                      The self assigned ones are:
                                      X - Xray
                                      Shift X - Back edges
                                      W - weld
                                      Shift A- arc:center + 2pts
                                      Shift H- hidden geometry
                                      Shift V - paste in place
                                      Shift B - B spline
                                      U - follow me
                                      J - jpp
                                      Shift S - fredoscale
                                      Shift space - select curve
                                      Shift R - 3pt rectangle
                                      Shift Z - zoom extents
                                      V - protractor
                                        [edit]
                                        I made a [req] a while ago that I still think would be great.
                                        Basically, I'd have a key or two [say #1 & 2] that I could assign to various tools depending on the project at hand.
                                        Maybe I need to use fredostretch a lot for the day. I'd select stretch then maybe shift-1 and 1 would now be assigned to stretch. The next day I might need lathe quite a bit so I select the lathe tool then shift-1 and 1 is now lathe. And so on and so forth.
                                        For some odd reason, it's just too big of an ordeal for me to do this via prefs so I just keep going to the icons. If this hot key idea were possible, I'm pretty sure I'd have shortcuts to lesser used functions much more often. (you know, the functions that you use once a month but when you do use them, you might use them 50 times)
                                        • Wo3DanW Offline
                                          Wo3Dan
                                          [edit]
                                          ..... Basically, I'd have a key or two [say #1 & 2] that I could assign to various tools depending on the project at hand.
                                          .......If this hot key idea were possible, I'm pretty sure I'd have shortcuts to lesser used functions much more often. (you know, the functions that you use once a month but when you do use them, you might use them 50 times)
                                          Hi Jeff,
                                          (not the perfect solution but) can't you do that with different shortcuts#1.dat to shortcuts#n.dat files. Depending on what you are planning for the day you import the appropriate *.dat file.
                                          I'm not sure whether you need to restart SU again or wheter it is implemented instantly. But at least you could import a whole bunch of "project depending" shortcuts at once.
                                          Once again, it's not perfect but it's worth a try.
                                            jaceguay
                                            I´ve made some shortcuts like Blender. Most shortcuts are positioned for stationary left hand in the keyboard. 😄
                                            g = Move
                                            v = Line
                                            x = Delete
                                            z = Section Plane
                                            t = X-Ray
                                            u = Unhide selected
                                            h = Hide
                                            f = Orbit
                                            d = Pan
                                            s = Zoom
                                            a = Select none
                                            r = Rotate
                                            e = Eraser
                                            w = Reverse face
                                            q = Rectangle
                                            Shift+F = Push-Pull
                                            Shift+D = Tape measure Tool
                                            Shift+A = Arc
                                            Shift+E = Zoom extend
                                            Shift+R = Zoom window
                                            Shift+T = Fade rest of the model
                                            Shift+Y = Fade similar components
                                            Shift+W = Look arround
                                            Ctrl+F = Folow me
                                            Ctrl+R = Offset
                                            Ctrl+D = Scale
                                            • 1 / 3
