    Curviloft (Beta) Plugin Tutorial
    45 Posts 21 Posters 58.9k Views 21 Watching
      robert111
      thanks charly , you are very generous
      • charly2008C Offline
        charly2008
        Hi Pilou,
        I didn't understand your english sentences not correct.
        Charly
          Maybe it's more clear like this 😄
          (click image if scroll bar)
            It's a pity
            we can use component for Curviloft ☀
            but alas Edit component don't make tranformations on the result 😮
            Or I miss something 😉
              charly2008
              Pilou,
              I understood it still not likely. The Curviloft object is a new group. The two components remain as components. The Curviloft object you can edit and change. Or you explode all objects and then you can change the result as you want.
              Charly
                That is the problem 😄
                Imagine : you have your gem
                Just edit the component (face) and you will have an infinities of variation without pain 😉
                But alas that is not possible 😞
                Here example with Component Stringer
                I modify just the component and all is modified
                and here with Curviloft
                  czloser
                  so cool
                    jbrfrk
                    thank u so much charle
                    J=K
                      tfdesign
                      This is a great thread, but is anyone else experiencing problems with pages loading, supposedly because of the sheer amount of image files having to load? I'm finding this thread pretty slow to view. 😞
                      My book "Let's SketchUp!" Download from here
                        robert111
                        charly can you make tuot for this modeling with subdivide and smooth
                        thanks charly
                          charly2008
                          Hi Curviloft Fans,
                          some CurviArt variations from a basic form.
                          Charly
                            jose-91
                            very impressive. thanks for posting these examples!
                            • brookefoxB Offline
                              brookefox
                              Thanks, Charly. I hope to tame the powerful beast with the insights you have shared, or at least not be consumed by it.
                              ~ Brooke
                                brookefox
                                When I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
                                ~ Brooke
                                  lapx
                                  Charly,
                                  I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number?
                                  also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this.
                                  How can this be done? See attached skp file.
                                  column.skp
                                    Lapx
                                    Is this the result you seek?
                                    Select the three 'profiles' of edges and run CurviLoft.
                                    The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form...
                                      brookefox
                                      The start point may not matter depending on the Vx setting.
                                      Note the black previews which if I orbit during, causes the whole operation to be discarded.
                                      The first pics show 1,2,3 from the bottom up.
                                      Here from the top down.
                                      ~ Brooke
                                      • micioneM Offline
                                        micione
                                        Hi all,
                                        Watching this tutorial, I found the window (red arrow) in the photo.
                                        Does anybody know tell me the path to find it?
                                        Thanks in advance
                                        • micioneM Offline
                                          micione
                                          Sorry,
                                          photo.
                                            charly2008
                                            Hi Roberto,
                                            you will find it in the Tools menu.
                                            Charly
                                            • 2 / 3
