    Curviloft (Beta) Plugin Tutorial
    45 Posts 21 Posters 60.6k Views 21 Watching
      tfdesign
      This is a great thread, but is anyone else experiencing problems with pages loading, supposedly because of the sheer amount of image files having to load? I'm finding this thread pretty slow to view. 😞
        robert111
        charly can you make tuot for this modeling with subdivide and smooth
        thanks charly
        • charly2008C Offline
          charly2008
          Hi Curviloft Fans,
          some CurviArt variations from a basic form.
          Charly
            jose-91
            very impressive. thanks for posting these examples!
            • brookefoxB Offline
              brookefox
              Thanks, Charly. I hope to tame the powerful beast with the insights you have shared, or at least not be consumed by it.
              ~ Brooke
                brookefox
                When I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
                ~ Brooke
                  lapx
                  Charly,
                  I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number?
                  also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this.
                  How can this be done? See attached skp file.
                  column.skp
                    Lapx
                    Is this the result you seek?
                    Select the three 'profiles' of edges and run CurviLoft.
                    The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form...
                      brookefox
                      The start point may not matter depending on the Vx setting.
                      Note the black previews which if I orbit during, causes the whole operation to be discarded.
                      The first pics show 1,2,3 from the bottom up.
                      Here from the top down.
                      ~ Brooke
                      • micioneM Offline
                        micione
                        Hi all,
                        Watching this tutorial, I found the window (red arrow) in the photo.
                        Does anybody know tell me the path to find it?
                        Thanks in advance
                        • micioneM Offline
                          micione
                          Sorry,
                          photo.
                            charly2008
                            Hi Roberto,
                            you will find it in the Tools menu.
                            Charly
                            • micioneM Offline
                              micione
                              Charly,
                              Thank you very much.
                              (I tried to send a private message, but evidently you have not received).
                                ccs1987
                                Awesome tutorials
                                Sketchup 8 pro
                                Vray
                                Intel Xeon W3520 2.67Ghz
                                12Gb Ram
                                Nvdia Quadro FX 1800
                                • LanaL Offline
                                  Lana
                                  Very good . I learned a lot here . Thank you all .
                                  • sketchartist023S Offline
                                    sketchartist023
                                    I have not been able to manipulate the GUI interface with this tool, so I am left with overlapping issues in my model 😕 I am not sure what to do, but wow this tool is amazing so far! My concept is taking a plane lettering and then using a half circle guide flow to reform it to a rectangle below the lettering facing the same direction. SO, just a morphed half loop from letter to poly. But always get overlapping and face issues since I cannot use the points on the GUI. I wish I could do this stuff above! Will keep trying 😄
                                      If you'd like help, upload an example SKP file so we can see what you are trying to do.
                                      • 2 / 3
